ho_kuku
Bumping your questions as I've also embarked on the home automation journey and have bought Aqara M2 hub and switches and am looking at smart blind options. Was always contemplating the IKEA ones but came across the Aqara E1 roller drivers and am wondering if the China one works or we will have to wait for the device to arrive in SG officially.
a surest way to know is to create an account in the aqara app.
see the available devices for the region that you've selected.
For me- I select "Others" - and I see E1 in the list of devices
Aqara devices (except for Hubs) are region agnostic. E1 should work
MakiMaki
Thanks for reply… let the searching begin haha.. think it’s out of stock everywhere..
Evilbear
@Evilbear , quick check with you. I know you are comparing the different vac robots. If I am getting the s7 - u think ok or can explore other brand? I will use it for light mopping too. For my s6 - I’ll clean and change the mop pad for each room.
ya ok ah, but it's still taking 1 small cloth wipe the whole house. Roborock has a mopping model G10 but not in sg yet.
Evilbear
Hi,
For you Aqara Switch, do you require to add capacitor to your light? Do you experience the light to flicker? Sorry, im new to SmartHome.
So does it means that even buying from local official store in SG like Lazada or Shopee it will connect to local server or it will connect to oversea server?
What app is ST and what does it stand for?
Most likely no, I passed the aqara switches and the lights to my electrician. At the end of the day all done and no issue after 1year+
It can connect to 'Others' or 'Europe' since I think they are selling UK version.
ST stands for SmartThings, https://www.smartthings.com/
kurokaze88
Not sure whether I should answer this, you probably watched my videos already.
1. According to Aqara - 'In theory, only the oversea products (regardless they are global/US/EU/UK version) are configured be to connected with the oversea servers. But in real world, users sometime might be able to add the Chinese version products to the oversea servers, and that's mainly because these Chinese products share the same model value and hence the same configuration with the oversea products. Of course this won't be the case for all Chinese products, and that's reason we highly recommend global users to purchase "right" Aqara products that are designed to be sold and used in the local region.'
2. Yup I am using ST with Aqara non neutral switches and they are working perfectly fine for me. But I can only say for those switches that I am using. Some people say 3gang switches will have problems but some of my viewers comment it works fine using the DH I am using
3. I never use other brands before but can explore Shelly/Sonoff
4. No idea
5. Works perfectly with ST. If you don't intend to get the ikea hub then your question to work with Google home is NA.
6. You can probably check with Hanman directly
7. No experience with August locks. As long as ST has geofencing, it doesn't matter I guess.
OK thx so much for the advice! And yes I watched your vids, but was seeing a lot of by right vs by left regarding China vs Global Aqara stuff lol.
kurokaze88
Talked to some random SG dude at the Aqara subreddit and he said he was able to pair the E1 with his global M2 hub, just need to do the manual triple press thingy to connect...
TrueBeliever_jh
I watched his videos recently while waiting for my unit..
Must say I got poisoned by this smart home automation~ 😢
catwhisperer
Can only answer to q1
M2 hub work with all aqara switches - i dun think switches are tied to any region.
2 version of M2 hub available - china And global. China version is also homekit compatible. Global verison is google, alexa and homekit compatible
regarding your question 2 - you may be better off picking the official smartthings supported switch. Since u haven’t bought anything yet - why bother with DH
Hello! Can I check where to find official ST-supported switches? Does voltage matter for switches, or can I buy from say Amazon? Thank you.
ho_kuku
Bro - please see link for ST supported devices: https://www.smartthings.com/products-list
Voltage shouldn’t matter - except if you are using high powered devices - like heater etc. u’ll then need one that can support 20A
catwhisperer
Thanks! I saw the list but I didn't know if I needed to find a 220V switch like UK/EU website. Great that I can just find on Amazon!
MakiMaki
Hi all, which is the best and hassle free solution for water heater switch? I’m on Aqara and Apple HomeKit… have been looking around but totally clueless which to get.. or should I just wait longer till better options pop up and use the normal water heater switch since it’s only 1 switch? Thank you!
CrazyBlue
Hi! Newbie here.
Not strictly a Home Automation question.
Planning to get either Alexa Echo or Google Nest Audio. Was gifted an Echo Dot so was playing with it for a couple of months, fun to use to activate the Roborock. Should I stick to the Amazon ecosystem?
After that, I plan to buy either BOND (which was recommended in a reddit post): https://www.amazon.com/Automation-Ceiling-Fireplace-through-Control/dp/B071GVGVVH/
or the Broadlink RM4 Pro. Needs RF to control the fans and IR to control say.. aircon and standing fan that uses IR.
Any recommendations between these two? Or are there better options to consider (better as in cost efficient.) The BOND seems highly recommended, the range seems quite powerful and have wider RF to work with. I don't know what my existing fans RF frequency haha. While someone said the BOND IR is not so good. So I'm abit confused.
Can the Broadlink RM4 Pro RF reach the master bedroom for a standard 5room BTO? Mine is a standard squarish layout. May have to put where the walls are, so there'll be 3 walls between the living room and the MBR.
(Also saw the Alexa Echo has a Zigbee hub? would that be sufficient to work with other Zigbee devices? Or it
I also saw Aqara switches, but saw someone here mention that some new standard, Matter might be coming out next year so I'll wait out on on these HA stuff first and stick to voice activation.)
Thanks thanks
flyong
Hi,
Is anybody using the Kinetic smart switch instead of Aqara smart switch which still need wire hook up to the switch?
What is the pro and cons if using using kinetic switch? It looks cool where you can just stick the switch anywhere?
Evilbear
just use a switchbot lol
Evilbear
Hi,
its just a wireless switch that is not using battery but kinetic energy.
I got a friend that engaged Ganen before, basically the platform is just another tuya smart life reskin nothing special. He got the doorlock from them, apparently the automation keep having problems after a couple of days then he gave up asking their support already.
comcrepe
Hi! Newbie here.
Thanks thanks
Hello,
Echo
I think the Amazon smart devices are limited in our region. I might be wrong but you probably need to research a bit more just in case you wish to use it extensively.
BOND
Seems expensive. But RM products should be able to work. I have the RM 4 mini but can't seem to get it to work with my Elmark ceiling fan. So if you want to use it with fans, best to buy one RM 4 to test it with your fan. From the app, I can see the usual brands like Panasonic and KDK. But no Elmark, at least officially.
Not quite sure about Echo as a Zigbee hub. I use the Aqara hub for my switches and Philips Hue for a mixture of Hue / Ikea Tradfri and some 3rd party light strips that are certified to work with Hue. They all show up nicely on Apple HomeKit. The ikea bulbs and 3rd party light strips need to pass through homebridge for them to show up on HomeKit.
I also have AmbiClimate to control my A/C. They are not HomeKit enabled but there is unofficial support to make them HomeKit ready. It's even mentioned on the ambi climate website for users to consider using this 3rd party software. As AmbiClimates are not cheap, I got the RM4 mini to control the A/Cs in my living room. The Ambis will be for the bedroom / home office.
Edit: Found out that my elmark fan is RF. My RM4 mini does not support RF. sigh. noob mistake.
