comcrepe
HI,
The reason i set my eyes on Aqara is because i feel that in terms of quality it is better and QC is done. I do understand that i require a hub for it to work.
My next question is hw many hub is needed since the hub connect to the router for connectivity. I think in SG context most of our hse do not have neutral line and i guess most of us uses non neutral switch. I guess non-neutral smart switch make use of the same principal as the traditional switch.
I am considering wifi switch as well but which brand is more reputable in terms of quality?
I use aqara too because I use HomeKit.
i have the aqara m2 global hub. Only one is required if your place isn’t too big and if the hub is placed centrally.
I used to have poor signal problems and checked online how to rectify the problem. Seems like aqara neutral switches can act as a Zigbee repeater. The non neutral switches like that ones I have wont help repeat the Zigbee signal.
but you can solve it by using the aqara smart bulbs. Apparently they can act as Zigbee repeaters. Much cheaper than buying an extra hub.
I added two aqara bulbs into my aqara system and I no longer have poor Zigbee signal.
next step: I’m exploring Homebridge to see how it can make HomeKit better. Some of the big players are developing an industry standard called Matter for home automation. Might be wise to keep the investment Low for now and see what happens when Matter takes off. Slated For 2022.
scenium
What app do you use when you use Aqara switch?
kimijc
Yes, that is correct.
You got any quotes yet?
Some sly contractor quote per gang - ie if you have a 3 gang switch - they'll quote you for 3 neutral wires
Each switch should only be quote as one neutral wire point regardless of how many gang it has.
FYI
Yes I do, here’s how it looks like:
Create neutral wire to 14 switches - 14*$35
Hack and conceal wiring for living, room, toilet
1.1k
They were itemised but too much for me to type out.
a pity i already carted out non-neutral switches from Taobao before the quote came out.
On that note - are D1 switches from China the same as those bought from shopee? Can they connect to m2 hub global version as well?
TIA!
kimijc
Hi there, i have the exact same plan (aqara, homekit) as your setup for my new house. Where did you buy your switches from?
ho_kuku
1.1k
TIA!
oic - then no point - neutral switches should work well too as experienced by many bro out here.
Ya, the switches should be the same regardless of shopee or taobao - and should connect to the M2 hub global version too. Actually if you're just purely using Aqara - the china version hub should work (it works with homekit too). Else - if you're using google home or alexa - you'll need to get the global version
ho_kuku
HI,
As some bros had mentioned here - it depends on how big your place is and whether you're using the switches with neutral or not. Switches with neutral wires tends to form a zigbee mesh network that can extend your coverage. I had my hub in the storeroom before - with the mesh network it can cover the whole place.
Neutral and non-neutral switches are quite different - neutral switches cut off current completely from ur equipment. Non-neutral switches just lowered the current so that ur equipment doesn't have enough power to 'power up'. Electricity still flows into your equipment 24/7 with the non neutral switches
Some bros here have good experience with Tuya wifi switches - no need for hub. @batniss switched from Aqara to Tuya and think he is quite happy with it
ho_kuku
For Homebridge - you need to have alittle patience - but in my experience it works quite well.
You'll need to spend some time looking for the better Add-on. Am running Homebridge on a synology NAS (Docker version). I read will be even a better experience if its run on a Rpi 4.
My vaccum robo still appears as a Fan in homekit - but at least it works. My Ring doorbell didn't work so well - somehow I can't trigger any automation based on doorbell events. Need to further investigate - maybe its a docker issue.
I read that Aqara supports the Matter standards - good news for aqara users
I wanted to dive into SmartThings or Home Assistance few months back - but i do have a number of 3 gangs Neutral Aqara switches - read that it doesn't work too well with those 2 platform - so gave up the idea.
Am using Homepod Mini as Homekit hub - my experience with it is not that great. They are ok - but sometimes updating status of ur smart device lags abit. I was expecting it to be instant.
scenium
Hi, Where can i get the Tuya Wifi Switch?
kimijc
Cool good to know, been finding an answer for that I guess it was in front of me already. :)
Yea, I guess no point to lay neutral wire since many cases of non-neutral that works.
I am looking to integrate with m2 global hub and tag homekit into it.
Fingers crossed!
How many homepod Mini do you have around the house?
ho_kuku
Fingers crossed!
actually ur setup and mine quite similar :)
I am using only one homepod mini - mainly as hub. For most rooms - I use google nest mini or nest audio
homepod mini as hub and only for automation purpose - ie motion trigger, scenes etc. i seldom use voice command now - as i find that it is too troublesome and also not very reliable. Sometime very frustrating too - wife prefers remote buttons or motion triggers.
aqara motion sensor has a build in lux sensor too - but as for now it is not exposed to homekit. Will be damn useful is its lux sensor is exposed - ie u can do automation like when light is below certain lux level trigger this and that. Homekit lux sensor are quite expensive
coming back to homekit - i think homepod mini may not be optimal as a hub - sometimes there is a lag on device status : maybe due to it being wifi only - I might switch to an apple tv in the future as I prefer ethernet. Maybe i am bias
jikilan
Just to share in case some of you not aware. Zemismart released a zigbee hub that can support tuya/homekit/Alexa/ google assistant not long ago.
This is the Product link.
dareaper
Hi, just to check on what you mentioned about aqara switches and google/alexa. I have aqara switches on xiaomi hub, and have not been able to link the switches via mihome to alexa/googlehome. Would having an aqara hub (global version?) solve the issue?
