TanKianW
Anyone using Philips WIZ wifi/bluetooth LED Ceiling Lights?
Can integrate with Google Home?
I have never use Philips WiZ, but it has an integration in Google Home. So I will think it is possible.
new.naux
Hello, I'm getting my new flat in about a year's time. I'm looking to implement smart home automation, but not sure if I can enlist the help of some smart home automation companies to work with the ID?
Any recommendations?
mero_cwj
Any Home Assistant senpais? If I'm gonna use aqara light switches paired directly with Home Assistant over zigbee, I don't need to care whether is global version or China version, as long as its zigbee right? So all the nicer China server only H1 Pro, H1M switches should be able to use with Home Assistant if I'm not gonna use it with an Aqara hub and Aqara app?
TanKianW
https://forums.hardwarezone.com.sg/...tant-ha-for-new-users.6751695/#post-141771767
https://smarthomepursuits.com/how-to-add-aqara-devices-to-home-assistant/
https://www.home-assistant.io/integrations/xiaomi_aqara/
v1hypersg
I have a Broadlink S3 hub connected to an LC1 switch for the past 1 year with no problem. Last week, all of a sudden, the LC1 cannot be detected by the S3 hub. When I clicked on the "On/Off" button via the app, the error message was "sub_buf.resp status error". I tried to delete the LC1 switch from the app and added again, but kept getting stuck at the "scanning sub-devices" error. Not sure if it is the S3 hub issue, but since day 1, the hub LED is always off, but the app always shows the S3 hub as online.
Any advice is much appreciated. Thanks.
I had the same problem as you, after checking with the technical support for broadlink and the seller from Qoo,
did their reboot, delete and add the hardware again, finally bought a new switch and got them down to install and back to normal,
2 weeks later, another switch have the same problem, that is why i asked which other brand or switches to switch to and to date, i have not decided which one to switch to,
v1hypersg
Regardless of which one you choose, you should go with an automation solution that runs locally and not rely on internet for cloud services.
Home Assistant will be your choice.
what do you mean by automation solution that runs locally ?
meaning a raspberry pi which controls them using ziggabee and not wifi ? or even bluetooth ?
deodorant
“Runs locally” means not those that depends on hey google or Siri or Alexa I guess.
TanKianW
Simply means automation that will still run without an internet connection, on a local area network.
It can run on a RasPi, x86-64, containers or VM, connected to a ZigBee/Z-wave USB dongle. The software here is Home Assistant.
bloodwater
Hello. Recently, an idea got to me.. Can I use a NFC tag to start a routine with Google Assistant? An example I wanted to explore is to place a nfc tag on my wireless charger that is connected to a smart plug, when I place my phone of the wireless charger, it reads the nfc tag and turn on the smart plug, thus starts charging my phone.
Been googling around and seems like there isn't a quick and easy way to do this on a android phone but can be done with iPhone shortcuts. Problem is my SO and I are using android and we uses Google home. Any idea would or lessons would be appreciated!
TanKianW
Not sure if it will achieve what you have in mind (w/o NFC trigger). It may sound complex for the simple task.
You could consider setting some custom trigger rules and conditions under the HA automation options to only turn on the smart switch to your charger when these conditions are met:​
  • Your mobile battery level reaches a certain level​
  • At a certain timing/time frame​
  • Your mobile enters into the geofencing area​
  • Your mobile switch to a certain wireless SSID​
  • Your phone (if support activity tracker) is detected to be stationary​
barcered
Anyone Aqara on Google Home stopped working ?
Yes. Mine had an issue recently. My Google Home app suddenly is not linked to Aqara in the app.
Although I have linked Aqara app to Google Home app successfully and it’s reflected in myaccount.google, Google Home app shows Aqara is not linked.
As such, I can’t use the routine function in Google Home but I can control my smart devices individually from both Aqara and Google Home app.
I can’t find a solution to this yet. It happens to Mi Home app, Broadlink app and Roborock app.
Anyone faced the same issues and managed to solve it? I tried unlink and relink, reinstall both app and reinstalling, and starting to a new home to link Aqara.. all didn’t work.
lvlaTr1X
Hi all,
Recently I just moved into my new house and plan to set it up mainly as an Aqara Zigbee ecosystem smart home. I am quite new to the aqara ecosystem (I used to be on zwave side of things and was running Fibaro hub w Homebridge and Habridge via raspberry pi to enable Alexa and homekit integration). Was attracted to Aqara because of the native Homekit support but never expected the difficulty in trying to set it up with Alexa as voice control.
I bought a Homey hub prior to moving in and in the end also bought an international M2 hub for my A100 door lock. Now I am setting up my D1 switches to connect to M2 hub but it seems that native Aqara Alexa support is only available in US server and D1 switches are actually not supported for that region.
My end goal is to have a straight forward smart home working with Alexa voice control as my wife and I are already very used to using voice control for its ease of use. How should I go about doing this?
A few idea I am having now is,
1.) Set up home assistant and move all the switches into that (Con: Some of the integration is subscription based and will have monthly charges)
2.) Set up in Homey and move all the Aqara devices over (Con: Some of the devices such as A100 lock are not supported via Homey plugin)
3.) Ditch Alexa and move to Google Home ecosystem (Con: I have about 5 mixture of echo dot and echo show brought over from old house, seems very wasted to be ditching them and rebuying google home just for this)
Hopefully the guru's here are able to point me in the right direction.
TLDR; I want to set up Aqara D1 switches to use with Alexa and I have M2 Hub, Homey and also the knowledge of setting up Home Assistant. What is the easiest method?
wacko
Hi all,
my Aqara account is set up with "Other" as the region, and have no issues with the switches showing up in Alexa.
Shadowlite
Hi all,
Hmm, just curious, what is the integration in Home Assistant that is subscription based ? I have been using Aqara with HA for a while, doesn't have any subscription tied to it
deodorant
Saw some earlier (as in few years ago) posts in the thread that aqara no neutral switches are unreliable and can burn out? Is that still the case in 2022?
I am considering to starter kit my current place (no neutral wires) with H1 switches and a G3 camera hub (since I need camera in living room for helper… I mean security), and controlled either by google home or apple homepod (my whole family uses iPhones so maybe stick to apple?).
Any particular pitfalls to look out for for newbie journey?
lance88
I did nothing. After several days, all back to normal. I use the other region
TanKianW
Hi all,
I will go with (1).
