my Aqara account is set up with "Other" as the region, and have no issues with the switches showing up in Alexa.
Can share how you link your Aqara account with Alexa? Using the Aqara skill in alexa skills?
Hmm, just curious, what is the integration in Home Assistant that is subscription based ? I have been using Aqara with HA for a while, doesn't have any subscription tied to it
Ahh, yea. That's the easiest method, although you can save cost via the manual method.I think I should have clarified that the easy approach to integrate Alexa with HA will be using HA cloud which comes with monthly subscription fee.
yup, that's right.Can share how you link your Aqara account with Alexa? Using the Aqara skill in alexa skills?
For those who have gone the HA route, do you give up voice control, or is there a viable solution?
Very weird.. I managed to only see one single 2 gang switch in my Alexa devices after trying for a couple of timeI think I should have clarified that the easy approach to integrate Alexa with HA will be using HA cloud which comes with monthly subscription fee.
I just subscribe to HA's Nabu Casa, mainly for the ease and also as a small token to support the team behind Home Assistant, which I hope would help with the development of new features and supportFor those who have gone the HA route, do you give up voice control, or is there a viable solution?
Ok, quick update.
Installed Home Assistant on my raspberry pi and realized that it won't work for my usage because I have already set up all my switches on the Aqara M2 Hub. For me to connect the M2 hub to HASS require modification to the software and because the device is already updated to the latest firmware, the flashing workaround won't work as well. So HASS route is not going to work unless I want to invest in Zigbee dongle and connect my Aqara switches directly to HASS but M2 Hub will become a white elephant then.
I tried Homey to connect my switch but it seems that the 3rd party plugin for Aqara doesn't support my version of Aqara D1 switches.
I sent an email to Aqara support, their response is that D1 switches is not supported in Alexa.
Now I am basically stuck with Aqara and Homekit without any way of using Alexa as my voice control. Hopefully someone can point me in the right direction.
Try connecting your Aqara to HA via Homekit Integration.
Hello. Recently, an idea got to me.. Can I use a NFC tag to start a routine with Google Assistant? An example I wanted to explore is to place a nfc tag on my wireless charger that is connected to a smart plug, when I place my phone of the wireless charger, it reads the nfc tag and turn on the smart plug, thus starts charging my phone.
Been googling around and seems like there isn't a quick and easy way to do this on a android phone but can be done with iPhone shortcuts. Problem is my SO and I are using android and we uses Google home. Any idea would or lessons would be appreciated!
I'm using tuya system, and have a need where I like to use a door sensor to alert me if I forgot to close my service yard window. Does the zigbee door sensor have such function?
Usual case will be the window will be left open until bedtime, and at times I forgot to close it when I go to bed.
hi, can you share how you got this work?managed to find a workaround by using IFTTT to control googlehome and smart Life! works like a charm now.
Hi , i purchased the Moes non-neutral switch (i got no neutral wires pulled for the house). I have got a combination of 2-gang and 3-gang smart switches (for entire house ceiling lights and RF fan), and just normal non-smart switch (for oven and hood, and storeroom ceiling light)Smatrul, Moes, zenismart, etc
excellent. I came from Livolo, followed by Aqara btw,
No. Regardless of whether i am on neutral or not. If you are on non-neutral, make sure you use the capacitor provided with the switch.
The only time it will flicker is you did not install correctly, did not use the capacitor provided or the wrong capacitor used.
Capacitors required. Is it installed properly?Hi , i purchased the Moes non-neutral switch (i got no neutral wires pulled for the house). I have got a combination of 2-gang and 3-gang smart switches (for entire house ceiling lights and RF fan), and just normal non-smart switch (for oven and hood, and storeroom ceiling light)
My electrician just did the installation of the switches and i noticed that when the non-smart switch is turned on/off, occasionally there will be flickering of the lights.
any idea what might went wrong? electrician was saying cannot have normal and smart switch in the same household. but he is not that experience in smart switches as he said he only installed once/twice. on top of it, he was pretty skeptical that smart switches will definitely not work without neutral wire pulled but the moes switch surprised him.
item bought:
https://shopee.sg/product/372240703/11109159298
Moes non-netural switch advertised that no capacitors required.Capacitors required. Is it installed properly?
And no, one can have mix of smart and non smart switches.
Put a capacitorHi , i purchased the Moes non-neutral switch (i got no neutral wires pulled for the house). I have got a combination of 2-gang and 3-gang smart switches (for entire house ceiling lights and RF fan), and just normal non-smart switch (for oven and hood, and storeroom ceiling light)
item bought:
Hi guys, can help critique / comment a bit on my newbie HA plan?
- I don't anticipate being a power user & my entire computer/phone/watch ecosystem is Apple so I plan on just going HomeKit (thought of also just using Aqara hub but voice commands are important to me).
- I am renovating a 3br+utility resale place (identical to this one) and pretty much redoing the whole house, will probably pay extra for neutral wiring everything and do Aqara H1 switches everywhere.
Entrance/Entrance Corridor
- Aqara a100 or d100 for HomeKey
- Automation idea here is entrance corridor light to come on when I come home / unlock door, plus a motion sensor for whenever I go to the entrance cabinet area (will be where we put all our keys, wallets, cards etc).
Living/Dining
- Aqara G3 Hub, ceiling mounted where it can shoot down the corridor (I need to make sure helper don't anyhow).
- ? G3 has a IR blaster as well so it could theoretically also control the aircons? My concern is that aircon automation seems a level up in complexity cos need to check temperature, humidity, whether anyone is at home and inside living room, whether the balcony door is open, etc etc.
- Lights hooked up to H1 switches
- Undecided whether to buy a cheap iPad to use as the HomeKit hub, or use HomePods and voice control / app control on phone. I am leaning towards iPad and putting it somewhere on the living room wall.
- Still deciding on whether to do Aqara smart curtain / smart rollerblind and hook it up to light sensor (budget concerns, plus if I end up ziptraking then I won't draw/open curtains often).
- ? Master Bedroom balcony we may put zip track motorised blinds, if we do, we're considering to automate it but yet to research what brands/etc integrate into the Aqara/Homekit ecosystem well.
- ? Fans will be hooked up to H1 switches for app/voice control, but as far as I can tell this only works for on/off and not speed / direction.
- ??? For this setup it seems like dimming will be difficult to achieve? My current place (dumb switches but Philips hue bulbs) I do change the dimming & colour temp in the living/dining very often.
Kitchen
- Motion sensor to trigger kitchen counter (under top cabinet) strip
Bedrooms
- Plan to use (wireless) mini switches to turn off/on from study table, bedside table, etc.
- Undecided on whether to buy a HomePod for each room ($$$) or just use the mini switches.
- Toddler's room a G2H camera / hub (in this case repeater?)
- No other automation than this.
Bathrooms
- Motion sensor to trigger the light on automatically below a certain light level (IINM Aqara's one is combined motion + light right?)
