batniss
What Tuya gateway hub are you using? Can sic?
Can it work with China version Aqara products? (I bought the curtains motor from Taobao)
unfortunately, I change all of my devices to Tuya to standardize things. It is way cheaper too.
previously I was on Aqara Hub followed by SmartThings with Aqara before embarking on tuya. I didnt try Tuya with Aqara hub nor vice versa before i sold all of it.
TanKianW
I am going to get the Home Assistant Yellow to start with 🤓
https://www.crowdsupply.com/nabu-casa/home-assistant-yellowHere are some of my new toys that I am going to add in my setup:
- bond hub (thanks to your intro)
- aqara P1 motion sensor
- aqara fp1 presence detection sensor
- Lytmi neo sync box
Feel free to check out the thread below when you jumped over to HA.
Will try to update the thread when I have the time.
https://forums.hardwarezone.com.sg/threads/starting-home-assistant-ha-for-new-users.6751695/
LordDeathZ
Which Aqara hub were you using previously?
Maybe I start small first, then slowly over the years as I get more knowledgable on Home Automation, then I can explore many other brands and setups.
testerjp
I've a warehouse and there's no internet there.
I plan to use a mobile router then install with a 100GB TPG.
Should i go with zigbee or wifi?
Connection reliability is my priority.
TanKianW
Regardless of which one you choose, you should go with an automation solution that runs locally and not rely on internet for cloud services.
Home Assistant will be your choice.
LordDeathZ
If a device is not supported in the region, means I must buy China version gateway hub in order to use it?
Cannot connect to global version de gateway hub?
katty91
which brand of product? Mi home? if product not in singapore server but in china server. The hub need to support China server.
why get global version hub?
katty91
Other than raspberry pi. Any other devices u can recommend to run HA on
LordDeathZ
Was initially thinking use global hub can likely integrated the entire system with Google home in the futures.
now quite clear to me I have to buy China hub if it is not supported by local server
ZigguratZ
Can I check with you, based on your experience, is Tuya products and the capacitor lasting? What's their normal life span?
Also it is difficult to change the switches and capacitors if required?
batniss
no idea, haven have one spoilt yet after more than 2 years.
i did everything myself so i will say is pretty easy.
Shadowlite
Would recommend you to engage an electrician if you are unsure / uncomfortable, as dealing with live electricity is very dangerous. 安全第一
t258jgn
How to make Mitsubishi Starmex aircon can control by wifi? Can control by Google Home?
Resale 20yr old hdb usually uses 2 wire or 3 wire for lights?
GU10 Track lights can buy from JB? Cheaper?
zenify.me
Controlling my 10yo+ starmex using Google home through a ~$8 cheap tuya wifi IR but needed to train the on/off IR signal. I am using it for simple on/off via voice command, scheduling via voice command and remote on/off when I am not at home. If you are looking to set more complex stuff like mode and exact temperature then my approach won't work for you.
zetken
Hi guys,
may i know where do you all get your magnetic track lights with smart controls?
i hope to get the white version.
batniss
i did the same.
Sensibo is another good tool but expensive
