TanKianW
- Apr 21, 2005
Thanks for the heads up. Lemme think about this and make sure I plan for it. Aqara sells a “human presence sensor” which could work but seems that it is only China version for now, hmm. Timer based to turn off also doesn’t make sense.
Actually I have no problem using motion sensors for turning the lights on/off for my hallway, front door, toilet. I think sensor positioning is also key. You can set the light on duration and sensitivity. I am using Philips Hue with HA, not sure if it will be the same with other systems.
The presence sensor you talking about should be the new Aqara FP1.
