TanKianW
Any of you got good experiences with Aqara P1 motion sensor? I have 4 of them and the reliability is absolute dog 💩, like 1-in-4 or 1-in-5 times it won’t detect me at all and then I have to be like smlj, reverse and turn on the lights myself. Wonder if it’s just me or what.
Not a Aqara P1 motion sensor user.
But I guess your motion sensors probably having poor (mesh) connection with its ZigBee router or coordinator. Which could be due to your home 2.4GHz wifi interference, try tuning it off to see if it improves. Placement of ZB router and coordinator could be another factor.
https://www.metageek.com/training/resources/zigbee-wifi-coexistence/
You can also try to configure the sensitivity settings of your motion sensors if your platform supports that.​
flikmy
Alternate (which I’m stuck with) is Apple HomeKit, CN switches can be added to HomeKit but not in Aqara app (with global server), which is passable but certain automations I can’t do at all.
Interesting. I'm actually having a different experience. Am using Global M2 hub, E1 hub and G3h hub with China-region D1 switches (including 3-gang). I can see the switches in both Apple homekit and Aqara app and have so far been quite stable. In fact, I've recently added the 6 button aqara remote switch (opple switch) which isn't meant to be supported in global aqara app and I see it on both the aqara app and homekit as well.
I'm using region=other for aqara app. Not sure if a different region setup on your global hubs makes a difference.
deodorant
Ah OK. I think the difference for you and me is that D1 is supported on both regions whereas my CN switches are H1 Pro. So I should update my statements to say that Aqara app doesn’t like / allow adding switches or devices that aren’t supported/sold in that region.
kujuta
if u added the d1 china switches to your global hub before august, it'll show up. if you unpair and try to pair it now, it wont show in aqara app.
flikmy
Wow, there's been some changes on the software side to block china region switches?
That's rather unfortunate since the items are pretty much the same and pricing on the items directly from China can be much cheaper.
Maybe I should have just taken the plunge at the start to buy all items including hub from China (everything on region=China), since it's generally cheaper and they do get more products than global regions.
thretiredDad
I’m currently using Tapo wall plug
since I’m doing renovation now
I’m reading alot here
thinking to make my home smarter
looking to replace all my wall switches to aqara wall switch
As I only want to use just one app for everything
which brand of led strip should I get?
will yeeling led strip with a with aqara?
lance88
Sometimes also experience this and the issue is the hub to sensor distance
thretiredDad
getting very confused now
if i don’t have neutral line for all my switches
I can either get non-neutral version switch or
neutral version switch but install a capacitor
if i am buying aqara device,
it is not a must to buy aqara hub
as it is also using zigbee
i can buy and use hub like smart thing
smart thing can allow me to use all aqara device and other smart device that runs zigbee
am I right?
deodorant
So just to share on my bathroom situation.
after turning on the p1 motion sensor’s “blink blue when u detect motion” it was much easier to troubleshoot. Turns out that the out of the box firmware was reporting super low light as 65000+ lux so the light-based conditions were screwed up. That got fixed with firmware update so my turn on automation is 90+% reliable now so I’m fairly happy.
The turn off automation still unsatisfactory. I bought a humidity sensor to put in the shower to use a “don’t turn off if humidity > 80%” type of condition but the issue is that the sensor only reports large (~5% or more) drops to the hub otherwise it reports only once an hour. Seems like bopian can’t really do this properly without mmWave sensor …
wacko
am I right?
since you got the first part completely wrong, I suggest no for your second question. you MUST use non-neutral switches, and add in a capacitor only if you encounter flickering issues. since you sound like a novice in this area, please stick to a proper Aqara set up (Aqara hub, and using Aqara app) to minimise your installation complexity.
thretiredDad
you sound you passed your O level
when you was 7 years old
genius and thanks for the reply
katty91
am I right?
just buy aqara hub easiest and straight forward.
there is no need to install any capacitor for aqara.
flikmy
the ones from soukystore on shop are global versions?
They normally are, but if they don't note "Global" version on the product description/photo, then you should ask the store via their chat function. They're usually quite responsive.
TrueBeliever_jh
Any smart switch for water heater to recommend? Aqara doesn’t seem to have one.
Most are wifi right?
ra[g]e
Hi guys, spent a ton of time reading through the posts here, have some questions:
I have Liniq tri-tone dimmable lights controllable by remote as well as some tri-tone dimmable LEDs controllable by remote as well. I'm told that smart switches in general won't work well with such dimmable lights and tend to flicker.
Is this true for the Aqara D1 switches? I intended to use them to control on/off while my Broadlink RM Pro mimics the RF remote to control tone and brightness.
Now I'm worried I won't be able to use any smart switches on them since they are dimmable.
Alphas
I would avoid Broadlink products like plague, since their app is very crappy. I also would not get Aqara devices since you are not sure it can connect to the correct seriver and pray that the hardware will work with geo-restrictions.
