sword28
anyone tried local company smart geez switches and home automation products?
local company and they have a wide range of products like aqara, and most of them can support Home Kit.
they even have a 20w heater switch (rocker type, not touch panel) for home kit.
price quite competitive with aqara
but I cannot find much information or review on them online. :(
their website is passionhome.sg.
bewarehee
Anyone knows if Aqara H1 taobao china switch can be pair with xiaomi gateway and then finally to home assistant, or I will require a aqara hub for the h1 switch?
flikmy
Hi guys, spent a ton of time reading through the posts here, have some questions:
I have Liniq tri-tone dimmable lights controllable by remote as well as some tri-tone dimmable LEDs controllable by remote as well. I'm told that smart switches in general won't work well with such dimmable lights and tend to flicker.
Is this true for the Aqara D1 switches? I intended to use them to control on/off while my Broadlink RM Pro mimics the RF remote to control tone and brightness.
Now I'm worried I won't be able to use any smart switches on them since they are dimmable.
I have a tri-tone led light (toggling off-on on power switch will change led temp) connected to aqara D1 switch. Seems to work fine with no flickering (I didn't install any capacitor either).
voux00
Planning to reno my place soon... wanna add some home automation this time, eg. Digital door lock, smart switches, curtain open/close, smart lights (LED strips, downlights & track lighting), etc.
Any reco for downlights and track lights that have cool/warm white (don't need RGB) dimmable for living room & study area that works well with Aqara ecosystem?
riftyga
Anyone tried using smart automation items from here?
https://shopee.sg/outsmartsg
Starting my reno and going to purchase smart switches / lights soon. I see most are tilted towards aqara ecosystem here, so are they any smart lights than can work well with the aqara app?
Jeff1991
Hi, need help from Aqara experts here.
I have a bunch of Aqara D1 switches (china bought) (3 gang), and I want to integrate them with Google Home.
I have tried using a Global Aqara Hub M2, but it only allows me to add Aqara D1 switches in the China region. When i switch to other regions, i can add the M2 Hub, but get an error for D1 switches saying not compatible with chosen region.
I am opened to trying out other hubs, so if anyone can recommend me a working one based on his/her experience, that would be greatly appreciated! Thank you!
Wah bro, I am having the exact same problem. Any solution to this? Or no choice have to go buy the Global version switches?
deodorant
A half solution would be use Apple HomeKit (I'm not sure if it works with Alexa/Google Home). Aqara app will say cannot add, but the switch will show up in HomeKit anyway.
Problem then of course is u can't use the switch in Aqara automations, only in HomeKit, so I guess it's recommended only if you already have bought all your hardware.
sword28
all along I thought that switches don't have region versions, only hub has,
since switch basically only need to communicate via zigbee with the hub,
but hub needs to access the network.
so it isn't true? there is china switch and global switch?
I am also doing house reno now and will be getting the switches, either via taobao to save some $ or locally for peace of mind.
actually the price difference for a switch is $3x vs $6x? quite significant saving esp if there are a lot of switches.
really appreciate the advices of bros here. thank you in advance!
lance88
Only hub have region issue.
gluexi
my tc2s can’t power on le after 2 years.
d1 still working
you are luck to last for 2 years lol. For me their so called smart switch starts to fail after 6 months of use.
i bought like 3 x 3 gangs, 5 x 2 gangs and 4 x 1 gangs. and today 90% of the switch failed to connect to the S3 hub.
I'm sure my home network is fine. i exchanged these affected switches for like 3 times with the seller and still the same issue pops up after sometime.
lesson learnt, Avoid broadlink product like TC3 at all cost.
gave up and ordered moes zigbee. wish me luck!
100ddd
does anyone have any recommendations for water heater switch (smart or not smart) that will match well (in terms of colour and style) with the aqara D1 space grey switches?
killerfly
Anybody have mixed the legrand galion grey switches with Aqara D1 grey switches at home? Possible to share if they're close enough to blend together side by side? If can share a pic?
deodorant
but bro darkzenny and jeff1991 are both having issues with switches bought from china.
I just finished my reno and I can confirm 100% global hub with aqara app cannot add and use China switches anymore. It can pass through to HomeKit no problem but it’s anyone’s guess how long this lasts.
sword28
so bro, you are now using global D1 switches? which vendor you get from?
deodorant
Global H1 mix with China H1 Pro (bought cos global H1 don’t have 3 gang). So now my automations are half bucket of water, some in aqara some in HomeKit.
Jeff1991
Last time Aqara didn't lock the region for switches. Now 100% confirm cannot alr, just as described by @deodorant . See the link below got a picture of the error msg you will receive if you try connecting China switch with Global hub.
ferbulous
Another way is still using D1 + 25a contactor wired to water heater
