Hi Guys,
I am starting my renovation process.
Did some reading and found it kinda confusing.
Can I seek some advise from anyone on the below questions:
Decided to go with Tuya integration since there is alot of hardware that supports Tuya integration then setup Home Assistant with Tuya Local (this will be the later stage)
Intending to purchase the below from Taobao to install in my home.
1) Buy in ceiling lights with smart control from Taobao which supports Tuya integration (
https://detail.tmall.com/item.htm?spm=a1z0d.6639537/tb.1997196601.4.57577484B7GsHe&id=660375373714)
2) Buy in Smart Switches that supports Tuya Integrations (
https://item.taobao.com/item.htm?spm=a1z0d.6639537/tb.1997196601.4.57577484XubXB9&id=626024768149)
3) Tuya Hub (
https://detail.tmall.com/item.htm?spm=a1z0d.6639537/tb.1997196601.4.57577484apGuDU&id=674839985789)
I understand that the Smart Switch/Lights communicate to the HUB via ZigBee communication in order to reach the internet to be controlled from anywhere.
1) Does my home electrical wiring needs neutral for all Tuya smart switches?
2) Is the devices tied to Region for Tuya IOT?? I previously tested for Xiaomi ceiling light and some other products, the Mobile app needs to be the same Region as the device inorder to detect it. Xiaomi region also defines where does the data stores in.
3) Voice Commands - Alexa, how can i integrate this into the Smart home concept?
4) is all this smart integrations managed on the Tuya Smart App then subseqently managed by the HACS (Tuya Local)?
Thanks very much for reading and appreciate any response.
Thank you.
