You mean your existing xiaomi gateway hub? CanDumb question, for aqara smart switch in order to work wifi must get their hub?
Cannot use existing zigbee hub?
Upgrading your homeassistant hardware?just wondering anyone here running Home Assistant
Or existing zigbee gateway.You mean your existing xiaomi gateway hub? Can
Yes, each works differently.Or existing zigbee gateway.
I buy the smart plug thought it was zigbee and wifi but then it only for WiFi.
Seem like zigbee and wifi do not exist together in 1 product
Want zigbe cost is more power saving compare to wifi lo and don't wan to jam my network i like want to play smart home in my room firstYes, each works differently.
Each zigbee (not battery powered one) extends mesh network while wifi, just connect to router
Zigbee’s great for sensors, battery last for a long time.Want zigbe cost is more power saving compare to wifi lo and don't wan to jam my network i like want to play smart home in my room first
What automation bro, i think developers already refined the automation tab to make it easier for everyonebros, I'm on z-wave
i only got 2 automations but it's very diff to config for HA..sianz
1) can share some screenshot on your setupgot 2 only
1) door lock trigger turn on light ( not sure what to select )
sian to anyhow tikam also as need to walk in and out open door test etc.
but I manual run the automation the output didn't run means selection of output is wrong( I think )
2) aeotec motion sensor trigger turn on light ( this one config issue, talking with aeotec engineers, the motion sensor dunno why sleeping )
Add actions > call service > switch on/off > select entity/deviceone by one..
1) I not so familar with what to select.. maybe bros can shed some light.
2) Maybe I wanna add a sonoff to play with zigbee, zwave too ex and didn't make much sense to spend more than 10 hrs to troublehsoot.
you mean I can use one of 2 options to activate?Add actions > call service > switch on/off > select entity/device
another
Add action > device > on/off
Yes, need to select correct action.you mean I can use one of 2 options to activate?
The Trigger is correct but need to select the correct input la?
