TanKianW
you mean I can use one of 2 options to activate?
The Trigger is correct but need to select the correct input la?
Your trigger should be correct. Actually I prefer using Geolocation trigger (condition set at certain time range) to activate welcome home light instead of just detect door opening. By the way, you can also use those cheapo ZigBee stick-on door close/open sensors for triggers.
If you want to turn off a group of devices, you can also manually add them into a group by editing the yaml config file (old method). Which could be done using "Studio Code Server" editor or "File Editor" add-ons.
https://www.home-assistant.io/integrations/group/
OR
Simply choose "Service" "Light Turn off", Targets set on all the room you classified earlier. This should be the more updated and easier method.
NOTE: Lots of Youtube channels on HA are outdated which will only confuse the new users more. Do follow on the more up to date channels since there has been a lot of changes in the new HA update this year. I normally follow the feature update briefing by "Everything Smart Home". This guy can build a whole new motion sensor on his own, mass produce and sell it online, contribute actively to the HA project on github.....is still my go-to channel for HA.​
TanKianW
Upgrading your homeassistant hardware?
I just use cheap hp thin client (t430), needed to add coral edge tpu pcie version that i can’t install on raspberry.
Anyone using wifi T8 led tube? It’s the only light i haven’t replace yet
You could simply use the USBC version of coral tpu which is much more versatile. Can use it on your Pi, a dedicated low powered machine or even a hypervisor with USB passthrough. The main reason of not using a Pi is because it is recommended to run Frigate on containers instead of HAOS.​
ferbulous
I’m sticking to pcie since they’re cheaper and works the same.
Plus i have some apps installed that requires x86 anyway.
With the chip shortage, there’s no telling when you’ll receive your coral edge tpu.
1. what is device vs entities?
2. How to amend device area?
3. What is the difference btw device vs entities area amd how to adjust?
thanks
Kitaro9202
If aircon is not smart want to make it smart possible ?
Function wise will be the same as the physical remote
seek some advice .
I only have mostly light switch and it’s zwave. Those sensor etc I want to change to zig ee since it’s so expensive and not working now.
so can you all advice if I should get sonoff signee and also pls recommend motion and door sensor that is tried and tested with HA and soniff thanks .
also zigbee input can trigger zwave Device, vice versa hor? Thanks
gonna get some later
ferbulous
thanks
1 device can have several entities
Example if it’s 3 gang switch, then got 3 entities (light switch 1 & 2, fan switch 3).
If you turn on by device, then it will toggle all 3 entities
You can edit the area with the pencil icon next to device name
ferbulous
Some brand selling wifi dongle to attach to the ac and comes with optional premium subscription to unlock more features
Easier way is just using ir/rf remote blaster.
There’s also this method of connecting esp to the ir receiver of the aircon pcb. This way you will always get the correct status of aircon even when someone’s using the physical remote.
I’ve copied this method for my remote controlled ceiling fan as well. Cheaper than buying ifan04 ($4 vs $25)
1. Question regarding the zigbee stick
I'd get the sonoff and since I'm using raspberry plus aeotec usb stick, I need a usb extender because 2 USB can't be installed on the same location side by side rite?
2. Question regarding what brand of door and motion sensor to purchase
so in general for zigbee in sg context and ease of use with Home Assistant. Tried and Tested no frills setup and reliable brand is it Tuya and Sonoff ?
Thanks
ferbulous
seek some advice .
get the sonoff zigbee usb 3.0, and i also recommend getting extra unit that can be used as zigbee routers
tuya, sonoff or aqara ones are quite reliable
yes, can trigger vice versa
Router you mean as repeater to the signal? I read all ZigBee devices like zwave are repeaters right ?
Sidetrack, what is the use case for wifi devices or we should avoid this,
you all use Alexa or Google voice ?
ferbulous
Yes they do, i woud still recommend an extra zigbee stick as router since wall switch/plug zigbee don’t seem to extend it much at least from my experience. Especially if you need to extend to 2nd floor or higher
i did share my thoughts on wifi a few post back. With wifi devices you can do a lot more customization provided you install custom firmware on it , cutting it off from the cloud
got both linked to homeassistant
Kitaro9202
Just receive the ir/rf receiver and i notice the aircon mode very limited compare to remote control lo. Now use that to on and off my fan
Bro, I buy all of these still cheaper than my ONE pc Aeotec Motion sensor which is 'broken'.
Hope I got the right stuff . Thanks
TanKianW
Save yourself the trouble, use Sensibo for A/C control. The build-in sensors/fine-control can be easily integrated onto HA too.​
TanKianW
The Sonoff ZB 3.0 USB dongle will work.
Have you checked through the compatibility list?? No rush......make informed decisions and do your research....​
https://zigbee.blakadder.com/index.html
https://www.zigbee2mqtt.io/supported-devices/
Take note that not all Aqara products could be integrated......esp the motion sensors.
Don't just buy based on brands/platforms, do check the compatibility list.
Kitaro9202
Got their app to work and use wifi?
So let say I got 4 aircon at home i need buy 4 sensibo?
