Kegler
Just regular led tubes
Planning to get some tuya wifi led tube next year from taobao/alibaba. It’s the only light i haven’t replaced yet, can’t find any sold locally
I've bee asking around smart light + smart switch....seems like everyone is saying won't work .....I just want the smart switch to be able to turn back on when some turn it off....smart lights control by HA....still trying to figure why won't it work
ferbulous
just need to configure 'detached' mode (relay for the smart lights always on), then use button action as triggers to turn on/off lights
with tuya lights, it's gonna reset itself if the smart switch keeps toggled repeatedly
Kegler
How do set it in detached mode? Wiring as per normal and switch to control the smart light onoff instead of cutting the power? Is that what u mean?
What do you mean by reset if smart switch keep toggled repeatedly
ferbulous
Yes, few switches like shelly and aqara h1 has detached mode by default
Tuya wifi switches generally don't, but it can be done using custom firmware (what I'm using now)
usually if keep turn on/off for 3x, it's gonna reset the lights and give you the 'seizure blinking lights'.
could be the kids messing around or yourself accidentally triggered it
Either you put a lock on it, cover it then pair with wireless zigbee switch or
set detached mode
Kegler
set detached mode
Oh u r saying if in detached mode...toggle mutliple times will not cause seizure....the seizure is when I use relay mode right?
googoogaga
Hi. I am doing full electrical reno for my house. I would like to install some smart wall sockets that can connect via ZigBee it WiFi and help me to track power usage etc.. the one that directly goes into the wall not the smart plugs. Are there any in market? I am getting aqara hub and smart switches as well
ferbulous
That’s the way tuya firmware on zigbee/wifi bulbs generally reset. If you flash custom firmware like esphome/tasmota can just disable reset mode.
ferbulous
What's your thoughts about matter?
https://www.home-assistant.io/skyconnect/
so this device will replace our zigbee coordinator?
For regular user, yeahh now just need wait for matter supported devices
For homeassistant, meh can integrate any devices already.
It’s both matter (coming soon) and zigbee, just be sure to backup your zigbee2mqtt so you don’t need to re-pair your devices again.
would it thru our sonoff or from skymatter? if thru skymatter then our zigbee need to repair to skymatter.
can use our sonoff as 'extender' router ?
also so far my zigbee only has one device and I got a few more.
Also i'm planning to do up the FOC alexa via AWS..
how would matter affect these?
sorry so many questions.. thanks
just thinking through to prep for the upcoming changes.
potato13
try loosening the mounting screws of the affected switch by about quarter or half turn. some redditors reported the same, and this was one identified solution/root cause.
I tried. And still faces the same issue.
After sometimes reading and Google..
I found online a handful users having same issue.
base on my aga aga understanding of The problem is if your appliance start up is using lesser than 3w. It will turn off.
Solution is to add a shunt capacitor.
Now I'm not an electrician..
Anyone know any good electrician to intro?
https://community.home-assistant.io/t/aqara-wall-switch-turns-off-on-load-increase/145813/4
ferbulous
can, just install router firmware for the sonoff
matter's not related to alexa integration to ha
wacko
i doubt your lights or fan is using less than 3W...
Kitaro9202
I am looking for smart switch for light and fan, check on shoppe but the seller told me the smart switch work on light leh don't work on ceiling fan with light.
Got any smart switch that is able to work with celling fan with light?
1) btw, if you want to start a scene when you wake up ( not shedule base but based on presense or action) how do you guys do it? I saw some YouTube they use sensor on the bed.
2) currently my coordinator is at the center of the house. usually for 4 or 5 room if the coordinator is positioned like this do we need more routers. Also what is the acceptable LQI value. Currently my motion sensor is at 45 seems ok.
3) Do you use normal tablet or echo show? Looking for an additional for voice command and perhaps presence detection at the kitchen.
Thanks
ferbulous
Hi, managed to up the alexa..I did the duckdns + let's encrypt + nginx combo... should be similar rite security wise?
Cloudflare tunnel usually for users who got cgnat/can’t portforward
You could say it’s more secure since you don’t have any exposed port
I’m also using nginx because I’m running other services like jellyfin media server (streaming videos not allowed with cloudflare tunnel)
