googoogaga
You’re right, i just had a look at the uk version and it’s only 13a max. I guess your search continues
Actually I wouldn't mind even if it's 13A. True 13A at 230V. That is enough to measure electricity consumption for nearly every appliance at home. Except for heater, ac, hob and Oven. 13A is also what the normal MK, Schneider and legrand sockets support.
But I don't think the ZigBee versions can even support 13A. Their rated wattage is only 2000W which is less than 10A.
storm913
anyone know if there is any wall lights like nanoleaf types, but running on tuya ZigBee?
serverxeon
What's the difference between aqara h1 smart switch Vs other brand smart switches? I see a few other brands using zigbee too.
Not sure of their difference?
Is aqara h1 different if buy from taobao?
potato13
i doubt your lights or fan is using less than 3W...
I also Think so.... But i could not figure out what was wrong already.
Change aqara smart switch - same issue.
Change normal wall switch - no issue.
I already disable and rejoin the aqara switches to the app. same issue.
So after isolate, thats the only i could think of now.
Purchase some capacitor.. pending arrive to test it out.
daniel_83
Would like to seek help to find out if the aqara h1 switches can be connected to the items below ?
1. Steigens drying rack ( new model supposedly only uses less than 1000w)
2. Smart Ceiling lights (like the yeelight ceiling lights, know that its abit dumb but require something that can be dimmable with no frills)
Steigen why need switch?
it is plugged into a 3pin plug , always on and use remote control
Would this alternative work in place of sensibo?
if windows close then I can use IR blaster to switch off air cond?
also I can include if temp < 25, I can turn off air cond
is it difficult to config the IR blaster?
ferbulous
Any trigger can be used to start custom action for the ir blaster.
If broadlink it’s directly integrated to ha
If it’s tuya one, no integration but you can use tap to run in smartlife/tuya app and it’ll show up in ‘scenes’
googoogaga
Well I continued my search and finally realized that all I need is to track electricity consumption at individual circuits directly from the mains panel. This would help me figure out if any of the heavy appliances like ac and heater are left on. Has anyone used iotawatt? They are able to track power usage for every circuit and would work in Singapore as well.
Alphas
Power consumption monitoring should be at the distribution box, there are a number of tuya/sonoff smart circuit breakers with power monitor functions.
googoogaga
Oh wow! I never knew these existed. Are these circuit breakers safe though? All our appliances will rely on this.
ferbulous
i know some friends using it, seems reliable so far.
Thinking of getting one soon because my main mcb trip when i was on holiday. Pretty useful when you’re away from home
googoogaga
The tuya smart circuit breaker like this is actually expensive. ~60 a piece.
https://a.aliexpress.com/_mNxcZ2wMy current place got ~15 of these. So am I looking at a $1k expense? More over these don't even have the power monitoring function that I need.
Alternatively this one below has power monitoring but needs to connect to the standard circuit breakers.
https://a.aliexpress.com/_mL7CicwIt's still $30 a piece. So if I need to real time monitor all of the circuits in my house I need 15 of these?
Just wondering.. first time encounter this with the sonoff motion.
Battery is still 75% but it didn't trigger when I check the MQTT dashboard. reboot still the same.
These few days HA got updates.... do you guys encounter this? What's the remedy? Thanks
It seems like the battery is low(18%) . So I changed the battery but I think it's ONLY like 1.5 months. Is too too jiak dian?
When battery is low I can't even find the binary_sensor_motion on the entity list. normal?
BTW, is there a way to quickly re-pair the zigbee device under MQTT?
Is it force remove and repair?
Thanks
stanlawj
Although you are free to do whatever you want, you're advised to only install Singapore PSB-approved circuit breakers (**) in your distribution box (DB).
Read the part in the aliexpress description: "Both models have NO overcurrent protection"
Suppose die die want to install the metering **, I'm not sure how legal this is, but I would wire them like this:
Main **
RCCB
** 1 -> Metering ** 1
** 2 -> Metering ** 2
etc
so that the PSB-approved ** with overcurrent protection is in the loop BEFORE the metering CBs. The >$1k expense sounds plausible/reasonable. Most datacentre metering PDUs cost around there or more.
googoogaga
Main **
RCCB
etc
Yes. This is what I felt as the reasonable choice considering safety. Don't feel comfortable getting AliExpress circuit breakers. But these metering one go after the circuit breaker. So I trust it should be better. Anyway I will seek my electrician input too before confirming.
With the metering only solution the cost is a more reasonable $300 ish. This would lack the feature of remotely reconnecting circuit after it breaks. But I feel it's not required for me. Just need to track usage.
Mr_Farmer
Hi all, i'm new to the thread.
wish to control my Aircon (IR) and Crestar Fan (RF) (e,g switch off aircon, switch on Fan in the middle of the night)
might also add a hygrometer and some smart switches/plugs
initially thought of getting broadlink RM4
