ferbulous
1) btw, if you want to start a scene when you wake up ( not shedule base but based on presense or action) how do you guys do it? I saw some YouTube they use sensor on the bed.
2) currently my coordinator is at the center of the house. usually for 4 or 5 room if the coordinator is positioned like this do we need more routers. Also what is the acceptable LQI value. Currently my motion sensor is at 45 seems ok.
3) Do you use normal tablet or echo show? Looking for an additional for voice command and perhaps presence detection at the kitchen.
Thanks
1. there’s a few diy bed sensor solution
https://community.home-assistant.io/t/fsr-the-best-bed-occupancy-sensor/365795
https://community.home-assistant.io/t/bed-occupancy-sensor-using-parts-you-have/189490
https://community.home-assistant.io/t/zigbee-bed-occupancy-sensor/213932
http://www.lavrsen.dk/foswiki/bin/view/Kenneth/BedSensor
It really depends on the bed itself, how much it absorbs your weight etc
2. acceptable, the higher the better
3. echo show 15 can now sideload homeassistant, just a bit costly. I just use fire hd 10
TanKianW
Hi, managed to up the alexa..I did the duckdns + let's encrypt + nginx combo... should be similar rite security wise?
It is about your risk appetite. You go all cloudflare tunnel, you put your trust on them. If they are compromised, your whole network will be compromised. Though chances are slim but not “impossible”, same with nginx where you need to keep it updated and patched. Just make sure you know what is going on when you sign up for it.
There are other ways where you can also run a reverse proxy server on your own, or a fast speed VPN server on wireguard protocol.
Regardless of which method you choose, it is recommended to seggregate your internal network using VLANs to prevent external services/IOT talking to your admin/infra network in case it has been compromised.​
catwhisperer
Hi all, grateful for guidance:
Moved into my new place a year ago and got a global m2 hub and all China aqara switches (3gang) and a bunch of sensors. However, never got the sensors and switches to work well with Smartthings (the "Things" don't show up in my routines list for selection and for 3 gang switches, only the first gang appears to be triggered). I therefore gave up on Smartthings and got the global m2 hub and resigned myself to not being able to integrate my yeelight and my aqara stuff. However in the last half year of so I have not been able to add new sensors to my m2 hub and with the D1 switches being non-supported, I'm at my wits end. Will getting a China m2 hub solve my problem if I'm resigned to using only aqara ecosystem? Changing my switches is not a viable option, too expensive.
katty91
Try China server but no google home and alexa.. also won’t be able to use global products
catwhisperer
Thank you. Do I need to get the China version of the hub or can I reconnect my global hub to China server (just to be clear before I purchase)?
katty91
U can get a China version hub for ur case but it is still best to be on global server albeit the higher prices
ok thanks let me research
OK.. the new echo dot gen 4 has presence detection.
I think the objective is to turn off the lights at the kitchen when no one is there for more than 5mins.
so if I have to use this skill I need do 'automate' it via alexa right and not via HA?
Thanks
stanlawj
I am looking for smart switch for light and fan, check on shoppe but the seller told me the smart switch work on light leh don't work on ceiling fan with light.
Got any smart switch that is able to work with celling fan with light?
what is your existing fan with light? Mine is KDK, it is not a smart fan. No possible to control it like a smart device with Google Home or Apple Homekit etc. Hooking it up to a smart switch just turns it on or off but not control the KDK functions. I can't find any information about the RF remote control protocol.
Kitaro9202
KDK brand lor I just wan to on and off the fan power lor.
I think the fan use ir one
ferbulous
Thanks.
But this seems like only 10A. Any option for 15A sockets for refrigerator washer dryer Aircon etc?
Also anything with Safety Mark?
Was browsing taobao and this one popped up, comes with power monitoring it seems
https://m.tb.cn/h.U9I8kVR?tk=VyoNdf6pR2h CZ0001 「WIFI涂鸦zigbee墙壁英规插座远程定时16a电量统计智能语音家电」
点击链接直接打开 或者 淘宝搜索直接打开
ferbulous
Thanks
Either set up it in alexa app or ha
ferbulous
I think any smart switch can use with fan
Never had issues with tuya/sonoff installed at my home. Mine is the remote controlled fan with no lights though
Btw , mine is the fanco brand. No remote. It's just a rotating fan switch. Do I need to change the fan switch?
googoogaga
I think this is the Moes Zigbee switch? Although they claim 16A, i confirmed with the seller that the zigbee version can only handle 2000w max. In Singapore since our V is 230V it can only do ~9A or less. I guess the advertised 16A is only for 110V.
MOES has a wifi switch which can apparently do 3000w. This might work, but it will clog up the 2.4GHZ wifi signal at home.
There are few wifi switches which can do 3000w but all zigbee versions i found are limited to 2000w only.
Suddenly it popped up in my YT
wad3v3r
Would like to seek help to find out if the aqara h1 switches can be connected to the items below ?
1. Steigens drying rack ( new model supposedly only uses less than 1000w)
2. Smart Ceiling lights (like the yeelight ceiling lights, know that its abit dumb but require something that can be dimmable with no frills)
ferbulous
You’re right, i just had a look at the uk version and it’s only 13a max. I guess your search continues
ferbulous
Ifan04 is the better solution if you need wifi and rf control. Then you’d just to leave the wall switch on (smart switch optional)
Just 3 speed though
Saw 5 speed tuya fan controller, but that one’s only sold in india
