Epi_curean
- Feb 25, 2001
My electrician tells me my 2 way light switches have 3 wires. 1w control light, 2 others control switch. What does that mean in english?
Anyone facing issue running xiaomi mi home app?
Seems like just crashes when i tried downloading and running it (in attempt to see its interface).
If new house. Then install crestron or control4.Hi All.......reporting in to home automation as i'm looking recently.
Currently i saw a few different bigger brand with their peripherals
1) Xiaomi
2) Samsung
3) LG (compatible appliance with Google Home)
What are the general IOT managed stuff you guys integrate?
I'm seeing the following
1) Light switches
2) Door lock (biometric)
3) Ambience temperature
4) Aircon (any support for non wifi models by adding a receiver/control?)
5) Curtain motor
Does Google home and Alexa comes in to provide just audio control?
Sent from Xiaomi Redmi Note 5 PRO using GAGT
not cheap... and basically you are leaving the solution to professional installers. Have $ anything also can be done.
Shouldnt we be talking about tinkering and DIY and sharing the knowledge instead of simply just recommending professional costly solutions?
New house a few grands can do home automation. if few grands is costly for new home then don't do. No one is forcing you lmao.
haha, I can do it myself. Go ahead and spend your money then. Totally unconstructive suggestions. Dont have the knowledge don't advise ok?![]()
Asus, u got use xiaomi voice?
Hi guys, I'll be getting a Livolo 3g2w switch. I opened up my current switch to check the wiring. Can you guys advise how do I map these wires to Livolo 2w switch? As I know the terminals in Livolo 2w are L1, L2, L3, L, A, and B.
I think my 2w light wires L1 and L2 should go in Livolo's A and B. And the other two lights' L1s should go to Livolo's L1 and L2. The COM should go in Livolo's L.
If it is setup this way though, I would have an extra COM wire. Also, does anyone know why are the COM terminals connected to each other?
First timer here! Please bear with me if this sounds too basic.
Photo here: i.imgur.com/N2pH17Ih.jpg
Hi, I suggest you get a licensed electrician because your proposed connection is wrong.
It is dangerous if you do not understand the wiring therefore better to get a professional.
Got it sorted with some helpThink the electrician that wired my home during the renovation made it a bit confusing.
Anyone installed hardwired smart doorbells like Ring and Hello Nest ? Where did you get the transformer from ?
I am thinking of wiring up Hello Nest and it stated requiring 16V/10VA transformer ( I do not have an existing wired chime to hitch onto , so the wiring will be a start from scratch )
Ryan
Ryan
Nice, Aqara going to support Amazon Alexa and Apple Homekit (Siri) soon
I ordered the ac transformer from rs components part number 230-4073
Used it for skybell and then after that with August doorbell.
plug-in-power-supply
