elvintay07
Suspended
- Jan 4, 2022
Can I ask why not many are using Tuya Switches? I heard Tuya don’t need a hub unlike Aqara.
also depends on what the smart switches going to control too, having stable power supply but there could be electrical noise in the environment too.reliability and some of them need to add capacitor too troublesome. doesn’t hurt the pocket to try if starting smart home journey
you mean Tuya switches that doesn’t need hub?also depends on what the smart switches going to control too, having stable power supply but there could be electrical noise in the environment too.
are these still available?I have some (at least 10 pieces) brand new Aqara E1 double switch (with neutral wire) to give away. I ended up re-buying without neutral wire as I didn't want to re-wire my entire home to accommodate them. PM me for details.
I thought you need a hub to work with all Aqara switches?Tuya switches are manufactured by numerous companies and factories, resulting in varying quality levels and prices. Meanwhile, Aqara switches are exclusively produce by Aqara themselves.
Assuming you are doing HA, you don't need Tuya, Aqara hub or even ikea hub.
Having a hub is actually a positive. ZigBee is far better than wifiI thought you need a hub to work with all Aqara switches?
I am thinking more device = more reliability problem? Also 1 huh per room means at least 4-5 hubs in the house.Having a hub is actually a positive. ZigBee is far better than wifi
Let me clarify the terminology before your imagination runs wild. A general smart home system consists of two key components: end devices (also known as smart devices or nodes) and a central hub or controller, sometimes simply called a hub.I am thinking more device = more reliability problem? Also 1 huh per room means at least 4-5 hubs in the house.
1 hub can connect 200 to 300 devices. You just need one per house.I am thinking more device = more reliability problem? Also 1 huh per room means at least 4-5 hubs in the house.
yes not jamming up the wifi spot is very important, unless u have a powerful router.1 hub can connect 200 to 300 devices. You just need one per house.
ZigBee device use less power, so more battery life, does not take up wifi 2.4ghz spots, so faster wifi, can also connect through walls and longer distances.
I got them. Will receive next week. But unlikely to try anytime soon.did anyone buy the aqara fp2 to try yet
Do share your feedback. I saw the review that divides the zone and ignores interference.I got them. Will receive next week. But unlikely to try anytime soon.
When we built our smart home, we looked for devices that met our requirements in terms of capability. Naturally, some devices were chosen for their aesthetically pleasing appearance, such as smart wall switches, which we interact with daily. The majority of these switches run on Zigbee or Z-Wave, but some use Wi-Fi as well. For smart switches, I recommend Zigbee or Z-Wave since they are separate from your home router, not only because a powerful router is needed but also because a smart home requires a more robust architecture. Some people set up smart homes that operate without internet or Wi-Fi for security reasons. In such cases, they may create an isolated VLAN to prevent smart devices from connecting to the internet. However, some devices with more complex capabilities are only available in Wi-Fi versions. Wi-Fi-enabled smart devices typically do not consume as much bandwidth as a mobile phone used for browsing the internet.yes not jamming up the wifi spot is very important, unless u have a powerful router.
zigbee maybe more expensive cause of the extra hub but i will opt for zigbee
Will probably take me a month+ to setup as I have not fully renovated the house.Do share your feedback. I saw the review that divides the zone and ignores interference.
But if something like ceiling fan is right above bed/couch, is it just gonna ignore the person since right in the interference area?
Seems like none of review so far tested with ceiling fan
if your is 3 stories bungalow with basement, maybe you need at least two for contingency.1 hub per house good enough? The range is ok?
Even then if you use ZigBee bulbs, switches or plug points they might act as a repeater as well. Most people only need one hub.if your is 3 stories bungalow with basement, maybe you need at least two for contingency.![]()
