googoogaga
was wondering the same for my resale HDB too. Aqara hub has IR function so could be useful to control AC in MBR.
Lack of IR blaster option is a weakness for aqara. I have to get those tuya ZigBee ir blaster. They are very small and non wired. I have to maintain a dedicated wired tuya hub just for these IR blasters in my rooms. If only aqara made similar IR blasters.
elvintay07
Suspended
No get sensibo?
TenOhmOnly
I got it second hand for $100 la..lol
I recently tested the G4 again and found some limitations that I don't like:
1/ The PIR sensor's range is too short, and its angle is too narrow. As a result, when it begins recording, you often see people seemingly "teleporting" 😅.
2/ The recording time is a mere 6 seconds, which is way too short!
Naturally, everyone has different use cases, such as corner apartments, corridors, or even outdoor gates.
For those who already own a 2K camera doorbell with a wide-angle sensor and a recording duration of at least 20 seconds or more, I recommend not spending money to downgrade to the G4 solely for HomeKit compatibility. However, if you've already purchased it and it works well for you, then that's great!
TanKianW
**GOOD WATCH: A New MMWave Presence/Motion Sensor FP2 from Aqara!**
For those looking for the best possible sensors for motion/presence. The newly launched Aqara FP2 might be the answer. Or not? Watch on. This sensor will also solve the previous issues of detecting ceiling fans with the exclusion zone function. For Home Assistant users, do take note that you will need to use the "Homekit" integration for it to work. There is kind of a "good news" nearing the end of the video with "ESP32 module" found to be on the Aqara FP2 sensor board. This simply means that there might be a chance for it to be flashed with custom firmware and totally can be taken offline from the Aqara ecosystem.​
TanKianW
Can I ask why not many are using Tuya Switches? I heard Tuya don’t need a hub unlike Aqara.
Tuya? All my switches either support Tuya or from Aqara.
If using ZigBee, you need a hub. If using wifi, your APs (router) technically is the hub. If you do not want to use a Zigbee hub for each ecosystem (Tuya/Aqara), just integrating all into a Home Assistant control hub will do.
All-in-one hub and control point using ZB2MQTT on HA. So long it is supported, regardless of brands:
Personally, I deploy Philips Hue for my smart lights, some random Tuya products (Near, Sonoff, No brand OEMs) or Aqara for some of my sensors and switches. Recommend users to move to Home Assistant if looking for an all-in-one control dashboard that also integrates with Google Home and Amazon Alexa, though requires some level of networking knowledge.
Integrates with Google Voice Assistant:
Want to learn more on Home Assistant can check out here:
https://forums.hardwarezone.com.sg/threads/starting-home-assistant-ha-for-new-users.6751695/​
balston_pig
Hi just starting out. Can I check if neutral will be required if I were to connect a 2 gang smart switch, 1 to a dumb ceiling fan and 1 to separate dumb ceiling light?
Probably looking at moes tuya sizgbee switches. TIA
crashed
I'm only just starting on my smart home journey was going to get all Aqara products (including door lock so I can use Apple Home) as it seems fairly straight forward in terms of integration with HomeKit, then using of HomePod in place of a sound bar, etc. Other integration using Home Assistant etc seems too complex for me and would need a lot of reading up :/
elvintay07
Suspended
Is there wireless IR blaster? I thought all need wire for power?
elvintay07
Suspended
Can someone share whether IKEA hub can control Aqara switch since they are also zigbee hub? The Aqara m2 still using micro usb. Haha! I prefer the USB C version
TenOhmOnly
The IKEA controller (hub) and the Aqara controller (hub) cannot communicate with each other.
For beginners starting with smart home automation, you can begin with one Aqara controller (hub) and its compatible end devices (aqara wall switches, relays, temperature sensors, etc.) within their ecosystem.
Some people may also start with the Tuya Smart Life controller (hub) and its end devices. When you are ready to advance your home setup and mix and match different brands and models of Zigbee end devices, you will need to set up a Home Assistant (HA) controller (hub). As mentioned, it is open source and can help you expand your smart home setup by integrating with IKEA, Tuya, Aqara, or hundreds, even thousands of products on the market. Your imagination is the limit with smart home automation using HA. With HA, your existing Tuya, IKEA, and Aqara controllers are no longer needed, but don't discard them, as they may be useful in the future as repeaters, and you can reuse Tuya, Aqara, and IKEA devices too.
Check out @TanKianW posting the you are ready to go HA.
TenOhmOnly
Aqara M2 can do infrared.
TenOhmOnly
There are already switches available that do not require a neutral wire (please check the current limit). These switches will work with a 2-gang setup (for a fan and light, assuming speed control is handled remotely). Note the potential danger, as mentioned by some members: when performing maintenance on a fan connected to a smart switch, make sure to shut off or isolate the power to prevent accidental activation.
Additionally, connecting a fan to the same power source may cause LED lights in your home to flicker when turning the fan on or off. If you hire a Licensed Electrical Worker (LEW) to do the wiring, they should be able to advise you on how to remedy this issue.
TenOhmOnly
Regarding controllers with MicroUSB or USB-C connections, once you have installed them, you don't really need to worry about it and leave them connected indefinitely. It's not like a phone charging cable that you move around frequently.
TenOhmOnly
I came across a new set from China for only RMB 459, which is not a bad price for a modification. If anyone is interested in getting their hands on these Aqara G4 doorbells (please note, proceed at your own risk!!!).
When you open the chimer, you will notice the microSD card slot is missing. You can solder your own, but be aware that there are also 7 diodes and 7 resistors missing. You'll need micro-soldering skills, and using a microscope is recommended.
Next uboot, there are 3 pads for TTL serial (115200) Tx, Rx, and Gnd located above the antenna connector. You can use telnet to expose the rtsp. As for the external doorbell, the existing PIR sensor's performance is subpar, as mentioned. You can replace it with a PIR sensor W216B for wider and better coverage.
pisonic
Hi folks, new to smart home automation. Quick check - if I am going towards HomeKit so I can get the china version of the aqara hub and the China version of the devices.
thanks in advance
katty91
thanks in advance
would still be better to be on global server for the full experience on aqara app.
Smarthomesolver has a video on aqara p2 veri tempting
