ferbulous
Hi Bros
Just starting my smart home journey and my place is being renovated now. I'm pulling neutral wires for all my switches and planning to use Google Home. Would like to confirm my understanding of the below from reading the thread so far and get everyone's recommendations
1) Aqara Global switches still doesn't have an option that supports dimmable lighting. Is there a good alternative?
2) Aqara also still doesn't have a boiler/water heater switch. Is there a recommendation for an alternative? One that's grey would be great.
3) Aqara child devices are now region locked so taobao stuff can't be used here if I want to integrate it with Google Home. Haiz, there's a taobao sale now, D100 only going for about 1/3 of SG price.
4) Other than aqara, is there another brand you would recommend?
Thanks in advance
probably a combo of aqara + tuya
1) tuya dimmers
2) any aqara switch + contactor should do it for boiler/water heater switch
3) if you use homeassistant with aqara, don't have to worry about these nonsense region lock devices.
TanKianW
Hi Bros
Thanks in advance
If you are going the HA route, be prepared to spend lots of time reading up and trouble shooting if you are not sufficiently tech savvy/literate.
Feel free to check out my guide here, before deciding:
https://forums.hardwarezone.com.sg/threads/starting-home-assistant-ha-for-new-users.6751695/​
pustefix
After asking about ceiling fan integration with Home Assistant, decided on PO Eco ceiling fan. The fan was installed yesterday and I had it integrated with Local Tuya custom integration. Didn't go with the official Tuya integration because it is cloud based, prefer local control. The configuration takes some time, basically select the fan platform and select the DPS number for speed control, direction, etc. All is working fine now and my automations are updated with the new entity. So for those looking at smart ceiling fan that integrated well with HA, can look at PO Eco, may not be cheapest but quite hassle free.
Lambee
If i have smart lights in the house using smart app and voice control, i can group all the smart lights say in living room to 1g normal switch since the switch has to be always on, then kitchen to 1g normal switch. I don't need to have each type of light to have 1g, or else living room i will have like 2 sets of 3g normal switches.
Is this concept of just have 1g switch to stay on, a good idea?
Tornesoul
does the wiring matter if my whole house is smart switch? e.g.
used to be switch A can only on lights A
now how can switch A turn on light B,C,D,E e.g?
ferbulous
That’s usually how it is with smart lights.
If you need to toggle from light switch, easy way is slapping wireless zigbee switch top of the normal switch.
Or use wall switch with decoupled/detached relay feature (shelly/aqara h1)
pustefix
However, I think there is still the physical limit of putting so many wires into the 1 gang switch.
mizumi
Just finished setting up my Mitsubishi AC with Broadlink RM4 mini. I noticed when turning AC on using Broadlink, the AC temp setting in the Broadlink app shows 23c. Is this setting stored persistently by the AC, or does the remote send all the settings and modes to the AC whenever it's turned on again? Compared to If you use a traditional AC remote, when turning on AC, the remote shows the last used setting.
pustefix
The remote send all the settings to the AC every time.
Tucksoon
Hi guys,
I'm looking for a Smart Home vendor to help me automate routines at my going-to-renovate house. I chanced upon Home-A-Genius which has this all-in-one solution in form of a hub.
What do guys think of this solution? Thanks.
Revolution
For lights with app and scene controls:
Maybe you can check out offerings from the Tuya ecosystem which integrates with your Google Home. They might have some newer scene control switches with LCD touch-screens. I have never use one of those, since I only purchase their on/off light switches which I integrate with HA. From my experience, most Tuya products tend to be of poorer quality but at a more affordable price. Sonoff imo is "better".
The scene control lights and wireless press switches which I have actually used since Day 1 are from Philips HUE lighting systems. Though comes with a high upfront cost but I had mine for >6 years and still running. Their ceiling lights are also expensive and the LED driver might die on you (I had 1) after 5 years but you can find a replacement on taobao to manually replace it (Don't bother getting from Philips, they are not stocking it!) I recommend LED driver from this Taiwan company call "Meanwell" or “明纬”.
Another premium alternative will be the Lutron eco-system.
*Being someone who has been automating light scenes for >6 years at my smart home......I can say it is totally worth the investment! Once you get used to it in your everyday life, you will love it and wonder how you can do without it.​
Hi TanKianW
thanks for sharing this info, I’ll try to find the leg from meanwell….
i enquired about Lutron but maybe I was visiting the wrong shops , they seemed not keen to market it. Except for a home automation company who was using control4 which was quite premium but pricey.
got busy with the renovations of late, almost wanted to go with the Philips hue line of lights for ease but agree they are expensive, didn’t know they break so soon.
now I hope my sol lights will last altho they give 5 yrs of warranty ….
Revolution
Hi guys,
Hi Tucksoon,
It’s a fix for ppl who are not so diy or able to understand how to get started with HA
im also taking up their solution,
Essentially I feel it’s like a HA with a skinned interface?
As I feel with my limited layman knowledge, it works exactly like the HA.
Revolution
Well, due to inflation and Singaporean insatiable demand for smart devices, and sleek looking ceiling fans, it just gotten more expensive. :LOL:
It wasn’t this bad when I bort mine 6 years ago.​
It got really expensive recently.
Even w a 40% lobang, i found it to be still pricey.
So also went ceiling fanless as we are 要美,不要命。。。 hahahaha
but on a more serious note, spotted similar looking fans at mega at Kallang when I visited them for confirmation of my kitchen appliances.
Tucksoon
Hi Tucksoon,
Thanks bro for your advice. Sent u a PM for a chat.
TenOhmOnly
aiyah...cross the bridge, you can find more and cheaper fan.
TenOhmOnly
Hi Tucksoon,
they install backdoor in your HA boh :?
TenOhmOnly
Hi TanKianW
oh btw... there are alot of fake meanwell online, hope you get from authorised /legitimate seller.
TenOhmOnly
i.e. your smart switch A, 'may' requires neutral depending your choices on type of smart switches on current market.
Light "B,C,D,E," can be a dumb bulb/LED and it can also be smart bulb (always powered) too, hence wiring need to plan carefully. There are many variation as you may even want dimming too. :unsure:
TenOhmOnly
wow this huge crouching tiger hidden dragon is ugly (my personal opinion) 😅
