You can use broadlink RM Pro to transmit RF signals.my fanco fan uses RF411. are there any RF controllers that support this?
Rm pro only support 315 and 433mhz tho. Np 411. Using my prolink RF, at most can only program a single command.You can use broadlink RM Pro to transmit RF signals.
I've used it with Homebridge on Homekit to control my Fanco fans.
so...what you plan to do ?so there's this window that i would like to fix a sensor too because rain will get in if i didn't close it
however this window also has a magnetic insect screen installed
anyone in the same boat can advise ?
no forecast. just simply remind myself or have someone at home to close the window esp.so...what you plan to do ?
1/ forecast in coming rain, so it send you alert sms/ whatsapp etc to remind you close window ?
2/ install a rain/ water detector, trigger send you alert sms/ whatsapp etc to remind you close window or even close the window automatically ?
I pull NEA weather every 5min at specific 3 locations near my place seletar , if the results contain keywords like 'rain' , 'showers', 'thundery', from any 3 locations it will send notification as reminder.no forecast. just simply remind myself or have someone at home to close the window esp
Just found this amazing item on AliExpress. Check it out! SG$50.88 15% Off | Casement actuator Window opener Electric Motor Automatic Close/Open Skylight/Greenhouse Window operator Optional Wifi Tuya Alexa
https://a.aliexpress.com/_mrj9OeM
Read HWZ Forum Rules!
I have similar question too. I am looking to build Apple Home based smart home. I would like to use mostly Aqara products on light switch, curtain controller, smart lock.
1. I do not have a solution on normal (dumb) dimmable light, as aqara switch cannot dim the light. May I know anyone has experience and have any suggestion?
2. Anyone suggest to use wifi air con? How does the apple home control air con? Do I only need a IR signal (eg aqara hub) or do I need the air con to be wifi enabled?
many thanks
Thanks.1) Aqara has bulbs that are dimmable and can be controlled in the Home app. Else Hue is the other option but will need the Hue bridge.
2) I use ambiclimate for ac but it's not Home enabled. Need homebridge. Using aqara hun to control ac is not a good idea as you'll need the hun and it's IR signal to be in lime of sight. Means each room to have one hun. Quite costly.
Cheaper will be broadlink IR blaster hub. But too many things laying around just to control ac for me.
Assuming you’re using homekit with aqara, you could grab dimmer switch that’s compatible with homekit/matter.Thanks.
Indeed I am looking to control the normal dimmable light, using smart switch. However Aqara don’t have smart switch that can control normal dimmable bulb.
I found some brands which seems good (eg Lutron) but seems they only have US version (110v) and not 220v for Singapore. Please let me know if there is any ok brand and model!Assuming you’re using homekit with aqara, you could grab dimmer switch that’s compatible with homekit/matter.
Not sure for any commercial dimmer that’s available out there yet.
or use homebridge as mentioned in previous post, and just grab any tuya dimmer.
Us market definitely have more dimmer option than eu/uk it seemsI found some brands which seems good (eg Lutron) but seems they only have US version (110v) and not 220v for Singapore. Please let me know if there is any ok brand and model!
also May I know how to incorporate the tuya dimmer to HomeKit? If I use tuya, that means I cannot dim the light using apple home?
many thanks
i like your reply ...i think in short run HA, everything inside one box settle all the issue, such as regional lock, limited devices based on one brand, etc more over it even cheaper in long runUs market definitely have more dimmer option than eu/uk it seems
just have homebridge installed on mini pc/arm board like raspberry/banana/orange pi.
It exposes your devices to homekit, and you can control them using the home app.
another option if you like to tinker stuff, you can make the device works for homekit natively.
For example this one, replace the chip with esp32-c3-12f, install tasmota on it. Then just pair to homekit with matter.
