IceX
check that u dedicated a ssid with same settings (i.e including security type eg. WPA2/3? , 2.4g for IoT)
some newer routers/brand eg. wifi6 may have a separate IoT channel for u to set 2.4g ssid
i checked my tp link router settings and the security settings is WPA2-PSK[AES], need to change that? Yes my this new router is wifi6.
Devilsire
M1's AX72? inside wireless setting there should be a IoT Network. Most older IoT devices are under 2.4g and WPA/WPA2, so set that 2.4ghz network with WPA2-PSK+WPA-PSK security. SSID and pw must be exactly same as old 1 including caps
IceX
yes the AX72.
I checked the wireless setting, no IoT network. only 2.4ghz, 5ghz and guest network. hmm the security settings I see that is available under 2.4g is
WPA2-PSK[AES]
WPA2-PSK[AES]+WPA-PSK[TKIP]
WPA3-PERSONAL
WPA3-PERSONAL+WPA2-PSK[AES]
WPA2-ENTERPRISE
WPA/WPA2-ENTERPRISE
If i choose the WPA/WPA2-ENTERPRISE, it has what radius server ip,radius port and radius password. not sure if correct to choose that.
Devilsire
yes the AX72.
WPA2-PSK[AES]
WPA3-PERSONAL
WPA2-ENTERPRISE
WPA/WPA2-ENTERPRISE
IceX
ah ok I've now set up the IoT network settings. But it still didn't worked.
Do I need to use a different ssid name for my main networks from my IoT network? currently its the same name
KayElf
Any recommendation for rain sensor? Those water leakage sensor will works the same way?
y0nGsAn
Hi, can i check does it make sense to have smart switch on HOB and Hood? My hob is 32A and not many smart switches support this.
Alphas
The 32A switches are high current. Why is there a need for smart switch on a hob and hood?
hkchew03
Ok. Sorry noob here trying to figure out how to setup a smart home. I suppose heater 20A i can use smart switch?
Yes, there is 20A smart switch specifically for heater. But i see little benefit if using instant heater, useful for storage tank.
mc_007
Can ask a noob qn:
Want to have smart downlight that can control color and brightness via app. Do I need to pair it with a dimmer switch or smart switch or dumb switch?
Thinking to have about 6 for my living room which needs 3gqng. But if dimmer switch, how do I pair?
Thks
jikilan
Anyone using point one eco wifi fan that successfully turned it become ZigBee/matter based? And what did you use? Can share?
I have frequent new added device notifications with random mac addresses into my home network. All very short life. Is it an expected behavior under matter?
wacko
Can ask a noob qn:
Thks
use with dumb or smart switch, regular dimmer switches will not work.
Devilsire
Can ask a noob qn:
Thks
can consider combo zigbee bulb + dumb switch for normal usage + voice/app control, and a wireless zigbee dimmer switch for physical tuning.
ferbulous
Can ask a noob qn:
Thks
Like others mentioned, dimmer switch won't work with smart downlight
Easiest way is just keep the dumb lights always on or use smart relay like sonoff mini with matter and enable decouple relay option.
Then, add wireless zigbee switch/dimmer configure automation for dimming/color change to the smart light based on clicks (1x/2x click, long press etc)
mc_007
Thanks.. went to DIYovation and the sales there said that i can use dumb switches with the smart dimmer lights. Will connect to Zigbee hub and use App/ Google to tune the colour and brightness.
