TanSG
“31st January, 2024
Dear Ambi Climate Users and Partners,
As I sit down to pen this message, it's with a heart full of mixed emotions. After an incredible decade of innovation, learning, and shared aspirations, the time has come for us to bid farewell. With a heavy heart, I announce the termination of all Ambi Climate services, effective March 31, 2024, as we move towards the winding down of business operations at Ambi Labs.
Julian Lee, CEO”
Anyone else also using the Ambi Climate smart aircon control?
I have used it for the last 6+years and have been extremely happy with it. Sad to see it ending up as a useless door stopper once the company shuts down their web server on 31 Mar 2024 that the gadget is dependent on to function
hkchew03
“31st January, 2024
Julian Lee, CEO”
Maybe time to consider Home assistant with HVAC hack if you are using Starmex.
elvintay07
Suspended
Moes use Tuya, open source platform, they product might just be rebranded for all we know.
They will work the same, just comes down to long term durability.
Actually China has quite a lot of rebranded product. The new one can do like matter (google, HomeKit, Amazon etc) but all need neutral cable
hkchew03
Yes many rebrand, but one thing for sure, Aqara manufacturer their own and for xiaomi.
Devilsire
Moyes, Smatrul, Aubess etc all are rebranded Tuya oem (same as the tons of smaller brands like Avatto, Onenuo etc)
if not wrong,
Zemismart make their own, but using tuya/smart life app
Sonoff/ewelink and Aqara restricted to their own app (thou some can hacked/integrate with HA if not wrong)
anyway i just ordered a matter-zigbee gateway hub, where it said its able to better integrate Zigbee devices to function on third-party platform like homekit/google home. Hopefully its able to unlock fuller functions and integrations for scenes/automations
xxnewbiexx
Just curious, why do some of you choose ZigBee over wifi? I am a newbie in HA but so far in my experience, using ZigBee in HA is more troublesome, why not just use all the traditional smart wifi devices?
Devilsire
https://koble.sg/4-reasons-zigbee-home-automation/
https://www.iottechtrends.com/zigbee-vs-wi-fi/
most impt is independent reliance from internet. eg if router spoilt / down, network down, your smart devices all crippled instantly where u might not even be able to switch on/off manually when in need :ROFLMAO:
2nd advantage is lower or less occurance of latency/lag/delay since it'll be over a direct "local" network instead of trigger>internet/cloud>activate device/scene etc
hkchew03
With wifi, your router will take the load and considering each household easily have over 10 devices, your other device that utilise wifi speed might be affected. For any battery powered device like motion sensor and door magnetic sensor, zigbee offer one of the lowest if not the lowest power consumption for longer lasting battery life.
IMHO, zigbee is way superior compared to WIFI for smart home usage.
You might want to try Z2M instead.
hkchew03
if not wrong,
Issues is with Tuya open system, anybody can make smart devices base on its protocol and rebrand it as they like.
As for integration with HA, as long as its zigbee, the chance of integration is quite high. I have tested sonoff plug and some sensor with no issues on Z2M. Aqara should be the same. But it makes little sense to buy Aqara due to premium prices for HA unless you like the design. Durability of might be better, but who knows for sure?
ezihome
Actually I find using zigbee devices is very convenient. From HA, jus enable the network to allow other devices to join, and that's done. As long as it's a zigbee device, regardless the brand, can integrate with HA mostly.
Whereas for WiFi devices, have to depend whether HA do have official integrations for that particular brand device.
That being said, I used Shelly WiFi Smart relays for all my wall switches and they are absolutely rock solid. HA has an official integration for it. These devices are connected to local network and doesn't need any cloud service for it to work in HA.
daniel_83
Wifi devices will be slower and consumes more power
example my open/close sensor at my door, takes about 6 secs to activate the scene (turn on ceiling fan + TV)
if it is zigbee, it would be almost instant
(but in this case, a delay is good since i will take time to walk into my living room anyway)
hkchew03
With HA? Scene of Tuya integration? If that the case i think the delay is largely due to cloud base rather than zigbee/wifi difference.
Devilsire
I believe he meant exactly that, as WiFi devices will have to rely on cloud based commands/scenes which is prone to delays.
whereas for ZigBee devices, they can comm instantly via local network
Sent from Poco F5 using EDMWER app!
hkchew03
Not all wifi device need to go thru cloud, there are tuya local integration, esp etc. cos he mentioned scene and remote, so I'm guessing it's HA as there no local integration for universal remote at his moment.
I have done localtuya with wifi switch, but it's just too much trouble compared to zigbee, at least for HA.
ezihome
Not all WiFi device go through the cloud. In HA integration documentation page, it will state IoT class for the respective integration.
For example, I have some tuya (WiFi) devices integrated to HA via the official Tuya integration, with IoT class of cloud push. For this case, it depends on Tuya cloud server to send and receive commands. There is a discernible lag of about 1-2 secs after activation.
On the other hand, Shelly (WiFi) devices integrated to HA with IoT class of local push. For this case, the integration does not depend on any cloud service to work; all commands are sent and received through local network only, controlled by the local HA server. The devices react instantly without any lag, and will still work even when ISP is down.
