kun1he2
anyone tried zigbee rain sensor with solar charging
wondering how accurate is it before considering automation with blinds etc
Interesting device indeed - are there other similar ones that you found?
I'm currently using a tuya zigbee water leak sensor which eats CR2032 batteries.
Doesn't work very well coz when the rain stops, there's intermittent on-off detection due to water still left on the sensor - probably also why it eats battery.
Devilsire
My friend is using Aqara water leak sensor but it's not entirely accurate as the floor might still be wet even though the rain has stopped.
yeah i have a few models of the water leak sensor too, which is more for one-off detection of water leak or flood (i use as alarm for kitchen cabinet plumbing & discharging/filling of washing machine laundry water) instead of rain monitoring.
this model i believe it have parameter readings of the "connected voltage value" to better determine if its raining
Now this is where things get interesting. Since this device uses exposed conductivity traces, when water falls on the sensor board, it bridges the gaps between these conductive traces, changing the resistance and producing a measurable voltage change. The value is reported in mV (millivolts) and has no use case as is, unless you are an expert in this field.
whats best is it comes with solar charging of inbuilt rechargeable battery :ROFLMAO:
triface
Hey all, spent the last few months looking through smart home content to gear up for my own reno but still kind of lost.
Here is what I understand:
- It's better to run neutral wires during renovation to open up options (so we probably will end up doing that)
- In a situation where there is no neutral wire, even if the lights are smart, it would still be possible to use no-neutral smart switches to on/off
- There are some niche products that also allow dimming even without neutral but generally dimming requires neutral
- Prices vary but I saw a quote of $31 to run neutral wire to each switch (not light)
- We were gifted a Z-wave hub but there's no reason why we can't just get a Zigbee hub so we can use all the products too. End of the day everything will be centralised within an automation platform. I briefly looked into this and it looks like Tuya's Smart Life app is out because it can't do Z-wave, which leaves Google Home. SmartThings. Alternatively, can go with Samsung's SmartThings since it does both Zigbee and Z-wave.
Am I misunderstanding anything?
We also recently outfitted some of our rooms with Sol Luminaire lights. By any chance anyone knows how they communicate with smart hubs? I checked with Futurahaus (worked with them to set up their studio) and they said Sol's lights are "radio frequency", but I know for a fact Sol tested their lights with the same hub we were gifted which uses WiFi and Z-wave. So... Z-wave? I know some products use 433MHz but documentation and conversations with them haven't led to anywhere.
merriman
Usually the first decision is to decide which integration platform you will ultimately use. That decision itself will drive the brand and hardware purchase decision.
Z wave, zigbee, WiFi is just a matter of communication protocol. It's normal to have a mixture of them working together. Z wave is not so common with not many devices using it.
Switches fitted with neutral wire will operate more stable. There have been reports of hits and misses with non-neutral smart switches. Issues of light flickering when switch is off, switch going offline when connected to DC fan set at low speed are some of the issues shared by users, though it differs case to case basis.
Good luck in ur smart home journey!
triface
Thanks for the advice! Haha yes I keep coming across the advice to decided on the integration platform first, but part of the choice was made for us because we were gifted the Z-wave hub and a bunch of other Z-wave products. At least it wasn't a mix so I can start properly with Z-wave!
Elon Jobs
The important question I have if I were you will be why were z-wave devices gifted away?
elvintay07
Suspended
Depending how many light and fan point you have?
If your room only has a ceiling fan + light combo, you only need a 1 gang switch.
Generally 1 switch per room is sufficient, MBR maybe 2?
Living Room between 1-2 depending on the number of lights you have and if they are grouped or separated.
Kitchen 1-2 depending if you split dry and wet / yard area.
The correct approach is to plan the lighting first then decide how you want to connect the switches. Don’t do smart then sacrifice the fundamentals of lighting. I went to my friend’s house. All smart system but the lighting are so badly done.
triface
It was part of the standard gifts that they gave to every unit in the project because they had a whole schpiel about the project being smart, green, etc etc.
Agree, but I think also important to have an idea what smart features we want and the protocols used. There would have been an alternative scenario where we had no idea what was required with the smart home and ended up with lights that couldn't be integrated into any platform and we had to use a separate app to control them.
Luckily our ID is handling the lighting haha so I just need to worry about the smart home stuff!
elvintay07
Suspended
Then might as well hire a smart home integration specialist. ID do 1/2, you do 1/2. Later got issue
merriman
Since you are doing up the smart home stuff yourself, it's also recommended that you involve yourself in the electrical planning (especially the switches) as it will impact your smart stuff planning; number of gang, location of LED strip power supply/controller, number of wires for LED strip, hide some switches away from sight, etc etc...
And also the lighting hardware, as you might want to have some smart lights around.
ZacharyA
Why are you telling me?
I only answered how many switches are typically required. Whether 1 gang 2 gang or 3 gang can always swap out easily.
And depends if wires are concealed or exposed trunking. It's not difficult to add lighting points and that is another question altogether.
hkchew03
Generally true. First is to research on platform you want. Zigbee/Zwave etc serve the same thing with some pro/con. All of these including wifi are radio frequency. 433Hz are normally used as remote controllers due to limited bandwidth, zwave operate at about 900Mhz, zigbee/wifi/bluetooth are all at 2.4Ghz.
Simple google search say that Sol Luminaire run off wifi on Tuya platform (they might offer more than wifi), if so, you don't need a hub for wifi.
Generally neutral switch are known to be more durable, less problematic and double as a router, if you are doing wiring, it is highly recommended. Otherwise non-neutral will work as well, just with slightly more limited device choices.
Dimmer isn't exclusive to neutral switch, its basically a resistor or you can have a smart light with wireless/remote dimmer.
Colaice
Hi, I bough Aqara smart door lock D100 for my main door, any recommend smart gate lock can link with aqara door lock D100 or homekit?
jeremytan9393
hi all,
am new to this home automation thingy. Just collected my 4room bto keys and am looking at non-neutral tuya smart switches + tuya smart downlights.
May i check with the experts here if this 2 combo will work? Have read a lot of mix reviews. Will this 2 work if the tuya smart downlight is more than 10W?
Am looking at this combo due to my parents having the habit of switching off the dumb switch manually. Which will result the smartlights not working.
On the other hand, I am keen to also have the option to dim and change the colour tone of the lights.
Hence, looking at non-neutral tuya smart switches + tuya smartlights, but not sure if it will work.
hkchew03
hi all,
If you parents switch off the smartswitch, the light will not be on. You can create automation to switch it back on, but if the downlight is suppose to be on 24/7, might as well skip the switch.
jeremytan9393
Yea, so looking at smart switch + smart lights. Any idea if this combo will work? Or will it work better if i run neutral wire to all my smart switches?
hkchew03
Oh cus am afraid if it is a dumb switch and my parents switched it off, i cant on it remotely.
I will be able to do that if it is a smart switch?
You already use a smart switch + light, so why would it not work remotely? But that would mean you need to remotely turn on the switch before you can modify your smart light settings, ie 2 step process.
ZacharyA
Yes you need both.
If you use a dumb switch and it is turned off by your parents, there is nothing you can do for your lights, smart or not.
If you use a smart switch, they can turn it off a million times and you can still switch it on remotely.
But why would you need to switch it on remotely if it has been turned off? That's the question. Presumably you are not at home? Unless you are home and want the lights to be turned on without walking to the switch to turn it on.
Regards to your ability to control color temperature and brightness, yes you need a smart light then.
It's all about educating your parents, if you use a PIR or presence sensor to detect movement or presence to control the light to be on / off, then they don't need to do anything once nobody is in the area. The light will auto turn off.
And if someone is within the area, the light will come on again.
If you think they are comfortable with using dumb switches and will turn off "accidentally" due to their habit, then use both smart switch and light. Otherwise, use a dumb switch and leave it permanently turned on, and control the smart light directly to turn on / off -> Which your parents will have difficulties unless they install an app and control it.
