jeremytan9393
thank you everyone for their inputs, really appreciate it.
Can I ask 1 more quick question..
I am running neutral wire to all my switches, hence for ceiling fan with light can it work in a tuya 3gang smart switch with other lights on the 1st and 2nd gang? Will it overload?
Or better for me to seperate the ceiling fan with light lighting point out from the 3gang into a 1gang on its own?
Also, do I need to use a heater 30/40A tuya smart switch for it? Or a normal 1gang smart switch will do the trick, as there might be current spike during the kickstart of the ceiling fan.
-nyox-
Need some advice, trying to link my dooya blinds motor to a smart app. However I read that this requires a bridge? How does that work?
Currently using Moes, are they compatible?
hkchew03
Is your blind zigbee? bluetooth or what? and Moes zigbee gateway? If both are zigbee, and compatible to Tuya/Smartlife, then it will work.
ZacharyA
A switch is a switch, unless you are talking about loading high powered current like built-in oven, storage heater, aircon compressor. The 3 gang smart switch can work with most / all lighting point circuits (lights / fan). Why will overload? The power draw for lights are so low, between 10-20w to 100-200w? Not even close to 1kW.
Not necessary. Otherwise, you should do all switches in your house 1 gang for each light / fan point?
Why would you need a 30/40A switch? Smart or not is another issue. Go read up the specs of your ceiling fan. You only need high amp switch for storage heater / induction cooking hob / built-in oven. AC most go for 20A isolator.
Your ceiling fan as big as the ones in MRT station?
fool1988
Hi All, want to check, if I bought one Outsmart Zigbee Bluetooth Multimode Hub, can I connect the hub with Outsmart RF/Infrared WiFi Universal remote + MOES RF/Infrared WiFi Universal remote all on Tuya apps, and work with Google Home to voice command remote turning on all RF / IR devices? Even work offline?
Currently It was working fine without Hub, however, most of the time, it have some latency and sometime when Tuya app having some issues, it will not work properly. By adding the hub, will it resolve this issues and make it more stable?
hkchew03
Adding hub does not make Tuya local.
noobzpro
Hi all interested to do abit of home automation.
Mainly lights, curtain motor, ziptrack.
My friend told me to buy home assistant green? And pair with aqara stuff? Any guide on this? Aqara can buy from taobao cheaper?
Thanks
hkchew03
Thanks
Realistically, if you are unable to google for answer, I would avoid home assistant. Its a platform for people who enjoy thinkering and researching. A single update can break everything.
TanKianW
A single update to break everything? Hah. 😂 That sounded a tad exaggerate.
The platform has since gone through so much major updates, overhaul and matured so much from when it started. Breaking everything with a single update is pretty rare now.
In fact, I even suggest that it is mature enough to replace all your proprietary cloud based iOT platform if you can watch a few YT tutorial to get up to speed. It is seriously worth considering if you have been too afraid to touch it in the past. Hey, even the favorite SG iOT YT-er Alex Teo is clearly onboard now.
Feel free to check out my thread at the networking section for those @noobzpro starting out:
https://forums.hardwarezone.com.sg/threads/starting-home-assistant-ha-for-new-users.6751695/​
hkchew03
Feel free to check out my thread at the networking section if you are starting out:
exaggerated maybe, but just recently few months, update of z2m break lots of automation including scene switch etc. No need to sugarcoat here, HA just isn't for someone who couldn't bother to google or research.
TanKianW
Just providing another perspective. Not trying to sugarcoat. No need to actually.
Best practice, read the release notes before any updates. Regardless of veteran or amateur.​
TanKianW
**A Preview to Privacy Focused, Localized Voice Assistant: Home Assistant Voice (Preview Edition)**
A potential candidate to replace your Google Home, Alexa and Xiaomi voice assistant which is actively developed by the HA team. Hardware is running ESP32-S3 SoC and XMOS audio processing. Initial setup requires the connection to your mobile BT or your HA server with the BLE proxy set up prior. I have a BLE proxy setup using ESP32, so it auto-discovered on my HA as soons as I power it up.
Take note that some quirks still exist, since it is a "preview product", like not recognizing your voice command if you don't speak clearly. But overall, it is still pretty well polished and a good "first" voice assistant product from the HA team! When it works, it is slightly faster than Google Voice Assistant. One of the reasons could be that my home network (WiFi) is already pretty snappy and well-optimised, so the difference is about 1 to 0.5 seconds at best. From the video demo, you can see, it is really snappy. But the cool thing is that this works locally, even without the internet or connection to the cloud. For the tinkerers, worth a shot to try one and support the HA team at the same time. If you are self-hosting your local AI server/clusters (Eg. Ollama or exo) or subscribed to OpenAI, you can link it up to your HA, will greatly improved it's "intelligence". Have fun.
My simple testing:
justpee
Hi all. I'm planning to build my own smart home for my new BTO. I'm an iPhone user and would like to use Apple HomeKit as my only smart home app because of its beautiful interface. I have a few questions, and I hope some pros here can help me out:
  1. Since the Apple HomePod supports Matter, does that mean all Matter-compatible smart devices can be connected directly to the HomePod?
  2. I'm planning to buy the Aqara G3 Camera Hub as my CCTV and IR blaster (for my air conditioner, TV, and KDK fan), which also functions as a hub. In this case, will all my Aqara devices connect to the Aqara G3 Camera Hub first, with the hub then connecting to the Apple HomePod? Or will all my Aqara devices connect directly to the HomePod instead?
  3. If I want to use Philips Hue for my lighting, do I need to buy the Philips Hue Bridge before connecting it to Apple HomeKit? Or can I connect Philips Hue lights directly to the Apple HomePod or Aqara G3 Camera Hub?
Mr_Farmer
for those with ceiling fans with weird RF frequency like RF411, what controller do you use? All of the RF controllers support 315 + 433 only
hkchew03
1. depends if it is your devices is bluetooth/wifi etc. Homepod probably only support wifi.
2) same as 1, otherwise its to Aqara hub and then exposed to homekit.
3) again, we back to the same topic at least for homepod, Aqara is more of close system, the hub doesn't recognise non-aqara devices or at least non-matter compatible devices.
