ericsoon72
any recommendations for home automation setup?
I have been reading about control4 system. Any recommendations for control4 installer or distributor?
keith
I ask ziptrak, they ask me to find the one who install. The one who install does not know how to connect to smarthome.
interesting reply...
you got both your zip-blind and motor system from the same local installer ?
hkchew03
Base on Ziptrak side, seems like only compatible with Somfy via wifi. Chance are you will not have tuya compatibility unless there is matter, but most end devices only support 1 protocol.
keith
Yes. Only 2 type to choose from.
there are several ziptrak installers in SG, and yes most support two motor brands.
i am using Ziptrak + Somfy combo but didnt connect via their bridge due to price / need.
it is possible to obtain similar bridge (sourced from other side of planet) for about a third less thou i suspect might have region locked server.
while for the other (Chinese) motor, I was also informed that its wifi - capable too.
in summary, your installer should be the one setting up for you, if you are getting the whole setup from them.
zerodddd
Hi
It seems like you bought your own hub/bridge and successfully paired it with the somfy motor. May I know if your connection is via RF433 or other advanced protocol (wifi/ zigbee /matter)? If via RF433, when you control the blind, does the APP on your phone report the position of the blind?
Thanks
Slavor
Hello, been a while since I posted here for my home Reno lol.
Just a question from me: Has anybody managed to pair back their Aqara D1 switch from Taobao with the global M2 hub? I accidentally reset my switch and the Aqara app region lock my switch liao. Even manual pairing doesn’t work anymore…
hkchew03
Hi
Thanks
I don't own ziptrak, but usually curtain motor has only remote (RF), or remote+zigbee/matter/wifi etc. If yours is the prior, there will not be an app to begin with, if it is the latter, then there would be position info in the app.
hkchew03
Aqara has region lock, Global hub will not recognise China device.
zerodddd
Mine is the former situation. I asked my zip blind supplier how I could control it on my phone. He showed me a third-party RF hub, together with an APP called Tuya. He also mentioned that there would be another solution which were Dooya authentic RF hub + Dooya APP. Obviously Dooya ones cost much more.
I eventually learned that RF device + a hub may work out. But I would never see the blind position on my phone. This is due to the uni-direction but not bi-direction communication between the controller and the device.
I then asked why did not my blind use Dooya motor with built in wifi or zigbee functionality. The supplier never answered this question straightforward.
keith
i have sourced and check the same brand same item, just different series and from different region.
connect via Amazon Alexa. this was one of the reason i choose Somfy over Dooya.
note, i only did my study, not the actual setup as i dont need the wifi control.
I cannot afford a 3m window "stuck" at open position , esp when no one is at home + it rains...
if pple's at home, just use the remote. LOL
side, if you have zip blinds, do rem to weekly exercise the motor and also balance the fabric.
hkchew03
If yours is only RF version, there is no way to use smart app. Smart app with universal RF controller can only emulate your original RF controller, but it will still not receive position data of your curtain etc. If supplier do not even know if there is zigbee or wifi, chance are it isn't there.
AshtonLeo
Hey Guys, want to check if anyone have any recommendation for the wall socket that match the mowe grey mausklick color?
AshtonLeo
Anyone have any review on Philips Wiz GU10 bulb? Initially wanted to get Hue but Hue need Hue Hub to operate. I only need ard 5 bulbs to go with my mowe switches and Google home.
I did some check and it seems Wiz might be better for my case since i only need 5 and its alot cheaper lol.
Noob here so any advice will be good. :)
ZacharyA
Aqara E1 Wireless (ZigBee) Remote Switch
Great for activating scenes and group actions using a single press of the button (Eg, turning on the A/C, turning on the fan and switching off the lights with a press of the button). This ZB device from Aqara (China) easily integrates with ZB2MQTT on Home Assistant and supports single/double button press actions (exposes) for toggling/activating your daily routines/automations. Since it is wireless, you can install it anywhere, such as just by your bedside, so you can easily activate the pre-set scenes or group actions with a press of the button when going to sleep or waking up.
there are 3 commands actually.
single press, double press, press and hold.
I'm using it for my MBR
Mecisteus
Can anyone share the typical cost of neutral wires (conceal) installation ?
