zapper_hj
i got consider leave the power to the fan permanently on without a switch but i also got the thought to have a physical button to switch the fan and light off together( like a master switch/ kill switch haha), that's why i proposed that setup.
but my concern now is that since it gonna send signal via IR I am just worried that let's say I press the ON fan button then both fan will on together because they can be quite near(one in living, one in study and study is open concept) Can someone share some experience with me on that? Thanks
And also door lock from TB, anyone?
Elon Jobs
FWIW, my dumb KDK ceiling fan has been wired permanently on for past 8 years, controlled by Broadlink RM mini via IR, no issue thus far. 90% we turn on/off via Google home mini, 10% using e-control app.
How far apart are your two fans? If it’s ceiling fans, by their physical limitation alone they cannot be that near, and IR requires direct line of sight, like TV and soundbar. I do not foresee it being an issue.
Mecisteus
Calling experienced smart home and Asus routers guys.
Asus BT-10 should be to handle 30 devices right ?
Mostly are smart devices and they are Tuya compatible.
Had some bad experiences with zigbee. Not sure if its the hub. I have to power cycle once in awhile. So I am trying to avoid zigbee.
merriman
Gotta plant zigbee router/repeaters throughout the house to make the network more stable. If using zigbee lights/bulbs/LED controller, leave the power on permanently for then to act as routers.
Likewise for WiFi; gotta make sure ur wireless coverage is good through every corner of the house. Otherwise, will have bad experience also.
Mecisteus
My zigbee in current house is already in middle. But still 95% reliability only. Not too bad actually.
Next house, I plan to use wifi for all devices. Yes router is definitely in the middle. My worry is the max connections only.
kun1he2
I'm using 2 x Asus BT10 mesh with about 30 Tuya devices on 2.4GHz and a couple on ZigBee.
Must say that the BT10 2.4Ghz seems not as reliable as older routers - you may lose connection and sometimes need to reboot the BT10 and/or the problematic device to reconnect.
Btw, noticed that quite a number of the Tuya WiFi switches don't seem to sync their state immediately to HA (not using local tuya).
Weird thing is that when I view the device using the Smart Life app (without changing state), it will immediately show the correct state in HA. So most likely, it is the devices not updating their state to Tuya Cloud - and viewing them forces them to sync to cloud and then to HA.
For ZigBee, mine are Tuya sensors - noticed that they seem not able to reconnect automatically when say I bring the sensor out-of-range and then back in range. Have to remove the batteries and reinsert them.
Happen to have faulty ZigBee switches too which I'm reusing one for bridging the sensors which have poor signal strength with the ZigBee gateway. Helps very much with the stability.
merriman
Ur WiFi devices are local connection or need to connect to some cloud? Latency for cloud connected devices have to be taken into account also, see if u comfortable with it
Mecisteus
All are cloud Tuya or Smartlife devices.
Possible to do local ? I have not explored this
merriman
I'm using Shelly relays, controlled by HA. It's local WiFi connection. Control is instantaneous.
I also have some tuya WiFi devices, connected through cloud. Can definitely tell the response is not as instant as local
Mecisteus
Frankly my devices don't need instant response and I can accept.
As long as connection is not broken and continuous. Hence more interested in max wifi connections.
Can't really find such information on google for the newer routers.
The Asus ZenWiFi BT10 mesh WiFi system is designed to support a large number of devices. While there isn't a strict hard limit, it's generally recommended to keep the number of connected devices manageable to avoid performance issues.
In your experiences, which switches have you used ?
I already bought quite a number of Smatrul (wifi) for new house. Had used the wifi and zigbee in my current home. The wifi one works flawless. Zigbee is 95% reliable only.
kun1he2
I initially started 5 years ago with about a dozen Smatrul RF+WiFi - of which about 3 are not working properly, e.g. electrical buzzing, turning on randomly, unable to turn off, etc.
Bought some cheaper and tiny square non-branded switches to test, mix of WiFi and ZigBee, those are very bad - doesn't function properly after a few months.
Also, do note that Tuya cloud sometimes does go down - perhaps around once a year.
merriman
Yup as long as the latency feels acceptable to you.
I have about a dozen of shelly relays connected to wall switch. Local connection is solid when it's working. But I have already replaced 2 pieces in 2 years due to hardware issue(can't switch off).
I used 1 MOES non neutral zigbee switch, needed to replace after 2 years due to can't switch off
I used a non branded WiFi tuya switch for water heater. Needed to replace after 2 years due to faulty WiFi connection.
Other than that, I have more than a dozen non branded Tuya zigbee bulbs, LED controllers, relays. So far so good. Connection is solid. Fingers crossed.
Mecisteus
Non neutral Smatrul ?
Not sure if there were non neutral 5 years ago.
I guess many switches already improved by now ?
Mecisteus
haiz looks like the smart switches have shorter lifespan.
By the way, I bought all Smatrul touch versions. Hopefully can last longer.
The beauty about touch, the user has to be very gentle and precise when pressing.
I know some switches can get stuck easily if user is not gentle when pressing.
kun1he2
No experience with touch switches.
I’m mainly using those smart switches which you connect inline with the live and neutral wires between your wall switches and the lights.
I programmed them to default to ON when power is supplied, so that when Tuya is down, I still can control my lights using the wall switches.
Yes, same experience on switch failures, they become stuck in ON position and can’t turn off, or turning on randomly in the middle of the night.
Mecisteus
But the touch mechanism has possibility of electronics failure.
I believe the mechanical switch is also connected to a relay.
Mechanical or touch is just an interface. You still need to switch the relays.
Also human / mechanical vs electronics, I still think the latter is more durable.
Anyway it's just my opinions base on my electronics experience. I'm still new to home automation. Will monitor my setup.
kun1he2
Touch switch doesn't have the possibility of a mechanical fault.
IMO the switch is more reliable. Just my thought only.
Curious, do touch switches emit any clicking sounds when touched?
With the inline smart switches, it sounds like the mechanical relays get stuck in the ON position and cannot disconnect the output load when commanded to turn off.
Mecisteus
The click is only sound of relay switching.
I bought the Smatrul non touch version. I don't like the noisy clicking sound of the mechanical button.
I know the mechanical type won't last long. So I bought all touch versions.
I'm not sure of the other smart switches.
