The neutral will need to be from the same circuit.Any electrician ? I need a 2nd opinion.
When adding neutral wire to a balcony switch, can pull neutral wire from closest light point which is in the living room ?
Possibly, but only you or your electrician will know.That's what I thought too.
My electrician said can take from another light point.
Or its possible both light points are from the same circuit.
I am also quite late and new to this smart home thing.Good day and need advice from all the experts here as I am very new into smart home and planning to make my new house "smart" in a way. I did some research and read on quite a number of posts here and have some questions and hope everyone here can help me this newbie
1. if i have ceiling fans and light together (not smart version but they have their own app), how can i control the light separately from the fan? eg. using smart switch but only on the light not the fan or vice verse or together. Or can i connect the wire to 2 gang smart switch, one for light one for fan. Or can i change the LED to Mijia compatible so that i can use it on HA.
2.Saw that some product can learn the IR from remote and then turn on and adjust the aircon or fans. if I have 2 aircon/fans unite that is close in proximity, will it on the 2 AC/fan together?
3.I saw from some that we can buy Aqara switches and device from TB and the hub must be global and it will work in our region, can anyone tell me is it still the same?
4.If i got smart products that is from different brands is it more advise to use HA instead of Aqara hub? I planning to buy most switches and sensor from Aqara. But I am afraid HA is too difficult for me (my IT skills only limited to DIY PC, excel(simple VBA with the help from chatgpt), IFTTT and no knowledge on coding)
5.I am planning to get the smart door lock from TB from Aqara as well, anyone tired it before to have someone install in SG? Understanding that the need some special bracket to make it works due to the different of door standard in SG.
6. lastly what to take note and do during the renovation especially on the electrical points installing part.
Thanks everyone and hope I can make a "smart" home with all the helps from all the bro and sis here![]()
1. Don't think it's possible to wire lights and fans seperately to a 2 gang switch.Good day and need advice from all the experts here as I am very new into smart home and planning to make my new house "smart" in a way. I did some research and read on quite a number of posts here and have some questions and hope everyone here can help me this newbie
by industrial "standard" your fan is already considered a smart fan since it uses app to control. Does it have a remote?Thanks for the enlightenment
The fan that i am getting is not as smart tho they have their own apps to control it but what i trying to achieve is to control the light and fan separately using the smart switch so that i can control it separately using the switch or app.
Based on what you guys shared, meaning even if i buy a switch and i still need a relays to achieve having the light and fan on/off separately?
Switch or relay doesn't really matter in this case unless you have way to integrate the fan app together with the smart switch/relay ecosystem.
yes it does have a remote and app. So do i have any way to achieve what i need?![]()
s what Devilsire said, use universal remote to learn the RF/IR and duplicate the remote with a wireless switch. But this will be semi-smart at best as the smart app will not be able to tell state of the fan/light.yes it does have a remote and app. So do i have any way to achieve what i need?![]()
Use a 3 gang switch.Thanks for the enlightenment
this is only possible if both are in the same ecosystem or through a universal remote.Use a 3 gang switch.
Gang 1 to ceiling fan.
Gang 2 and 3 are unconnected and SW configured to switch fan and light individually.
Not possible this way ?
He is doing for a new home.this is only possible if both are in the same ecosystem or through a universal remote.
Thanks everyone again.Use a 3 gang switch.
If that's your plan, I feel should just leave the power to the fan permanently on. Then gang 1 set as virtual switch for fan on/off. Gang 2 set as virtual switch for light on/off. This is so don't need to worry if someone else switch off the power to the fan, which render the virtual fan and light switches non-functional.Thanks everyone again.
I am reading quite a bit and i think the option is this one which also Devilsire pointed out.
So my plan is actually to get all Aqara product first.
Using a 3 gang switch, 1 for the power for ceiling fan light, gang 2 and 3 unconnected as virtual button for on/off of fan and light separately it via the IR blaster from M2 or M3 hub after learning the IR from the remote of the ceiling fan light. Will it be feasible? And i am curious will both fan on and off together because i have a open area study room connected to living room and each will have the similar ceiling fan light.
btw anyone try install Aqara door lock ftom TB?
IMO I don't see anything wrong with fan incoming going to gang 1. Its like a master switch.If that's your plan, I feel should just leave the power to the fan permanently on. Then gang 1 set as virtual switch for fan on/off. Gang 2 set as virtual switch for light on/off. This is so don't need to worry if someone else switch off the power to the fan, which render the virtual fan and light switches non-functional.
