for those using xiaomi switch i have 2 burnt and based on xiaomi forum there are others with cases as well. they can cross sell their smoke alarm alr....
The part of the burn is where the trandsformer is...
So far, I have 4 spoilt switches over the span of 1 yearbut none of the components were burnt when I open it up..
Hi has anyone experienced failure of Xiaomi Aqara wall switch both single and double switches (non-neutral)?
I have it installed for all of my light switches, and within 3 months, already 5 switches have failed to on, including 1 with burnt resistor that melted / burned the plastic housing.
Just wondering if it is just me or is it a common issue.
Just wondering about the burnt xiaomi wall switches... could the reason being china using 220V but here we use 230V?
Hi guys, I opened up my light switch and it looks like this.
Currently about to start renovation. Does this mean neutral wiring is there already?
I see only live and ground. No neutral.
Tell your electrician to run neutral to all ur light switch points. I'm about to do my reno and the electrician quoted me 60 bucks each switch point.
I'm now considering to buy the xiaomi aqara with neutral since nobody has experienced any burnt switches with those so far.
Looks like ground (connected to the switch housing) and live (brown) wires. Is it a 2-gang switch? Neutral wire is blue in color.
Mine quoted $40... after reno still can pull?
I know there's the aqara with no neutral required. What is the difference between these two?
I got a feeling its the non-neutral models that there is some loop function within circuit that transformer is trying to dissipate the heat but fails.
Anyone ran neutral wire and has also burnt aqara switch?
From my deduction neutral type may not have such issue.
I've installed since mid feb and so far so good. Will be monitoring mine...
The problem is, Xiaomi due to its brand presence has sold so many of such switches and in the grand scheme of things, the number are cases are actually small.
The switches are the same, I just wonder what other variables are at play here.
Current is constantly on... perhaps?
One of my 2 gang is connected to a fan cum light and the other to Phillips hue strip... when i hit the fan switch... my Philips strip will flick once... this happens every time both switches are left off for awhile... anyone experience the same?
Or simply they didn't sell enough neutral switches so you don't see users reporting their failures.
