that look very badly burnt. I've installed a couple of them (the neutral cable) for my flat.. hopefully this situation will not happen.
I got 3 gang sonoff touch. However, I've yet to flash them.
sonoff require neutral?
To consider Sonoff, certain things you need to take into regard
1. Does your light switch have neutral? Assume you're talking about Sonoff T1 UK here. It needs a neutral line. Sometimes it might be worth to lay a neutral line if its a new home though.
2. Cloud or local? Sonoff is cloud ready right out of the box. If you choose to do local without depending on cloud, you can do so via firmware flashing which needs some tinkering. needs more effort,but not impossible.
What Sonoff does offer is flexibility. Its not as nice and polished as Lutron for sure in terms of aesthetics, but on a price point its cheaper as well.
Got it sorted with some helpThink the electrician that wired my home during the renovation made it a bit confusing.
Actually just google there are a few threads on xiaomi forum about this issue.
Using mine for only 2months
http://bbs.xiaomi.cn/t-13668199-1-o1#comment_top
Ask you all HA pro ar, are u all using only 1 app that can control all the appliances using different form of signal (IR, RF, wifi, zigbee, z wave)?
Or need to use many different apps to control? Like fan got own app, switch got own app, light got own app??
But the Smartthings no IR and RF right? How u control these 2? using another hub ar?I using smarthings.
Wah chor leh...I will go for the diy routeI am using Control4
Another noob question ar, the product must be listed in Smartthings then I can use Smartthings to control right? Lets say I buy this China product which is not listed under Smartthings then I can't pair them up right? Even though the product can be controlled by Zigbee?
DIY is fragmented still, so you need to put in effort.
Smartthings can control unlisted products, just need to input the appropriate device handler then can liao. its the finding the appropriate DH that is difficult. Pairing too.
Also allows smartthings and Alexa to manage my IR devices configured in Harmony much better than Harmonys silly restrictive 'activities' limitation.
Anyway all my IR devices can be managed via smarthings through HABridge that talks to Harmony which is an intelligent IR blaster.
Can share how to use Smartthings to control Harmony to control IR & RF? Cos I thinking to buy Smartthings and Harmony like as my hub like many of u all to control all the product using diff signal.
But HABridge thingy seems v chim to me leh
Any easier way of controlling Harmony via Smartthings?
Ultimately my objective is to use only 1 app (maybe Smartthings app) to control all things.
Anyone tried Homey yet? Seems like this 1 can control Zigbee, z-wave, wifi, IR, RF, Bluetooth sia. Like full range liao
Yep. Its not too bad la. Really depends on ur setup. I have 2 harmony hubs controlling my aircons, tvs, fans, etc.
I also have a usb hdd connected to my computer in the study sharing out the drive on my network. I download all my shows into it and cast them via chromecast to any of my TVs around the house. So this computer is always on 24/7.
Anyway, the computer runs HABridge in the background. Its a java app that allows much more granular control of my Harmony hubs. Also allows smartthings and Alexa to manage my IR devices configured in Harmony much better than Harmonys silly restrictive 'activities' limitation.
Wah steady lah bro! Thanks for offering your help! If I go with this option cfm find u![]()
But actually what's holding me back is needa on computer 24/7. Just bought my new PC so don't really wanna stress it too much by turning on 24/7.
Anyway bro, have u tried to link based on the article below? Can anot 1 ar?
support.smartthings.com/hc/en-us/articles/205653834-Logitech-Harmony-Home-Hub
Hmm ok i will research about that also then.u can jus buy a cheap raspberry pi then
I can't remember if I have before. But the integration with Alexa and harmony only allowed one to control via activities.
I find using activities very restrictive cos you can only have one activity running at one time.
Many a times, we will want more granular control which harmony activity doesn't offer.
Leaving your PC on 24/7 is actually okay. I've been doing that for years. Just turn off ur monitor when u not using. I don't think leaving in on but idle actually stresses it out anymore
