Actually just google there are a few threads on xiaomi forum about this issue.
Using mine for only 2months
http://bbs.xiaomi.cn/t-13668199-1-o1#comment_top
I'm not sure if the one with neutral is ok, I saw a few threads with people posting about this issue, those with pictures are all having no neutral switches.
Just becareful with these switches, but they burnt with a very foul smell so Incase it really happens it should wake u up from ur sleep...at least I was woken up by it.
I’m not sure if the one with neutral is ok, I saw a few threads with people posting about this issue, those with pictures are all having no neutral switches.
The part of the burn is where the trandsformer is...
So far, I have 4 spoilt switches over the span of 1 yearbut none of the components were burnt when I open it up..
Cheaper to hire a maid to do all these for u....so there is some sensor that sense for sunlight and bring down blind automatically? how does it know how much sunlight is too bright or is the right amount of brightness that you dont like?
how does it decide how dark then it turn on light by how much?
how does it decide when there is someone in the room and when to turn on and off by itself?
how does it decide when you are in the house and turn on the radio to the right channel for you?
Can it sense for rain and close the window and sliding door at the balcony for you?
Yes.
Btw, when did your switch got burnt?
recently after using for about 2mths... 2017 nov batch.
thanks for flagging out this issue. Will be monitoring my switches.It's been almost 4 months for me. Also, is it the 1 gang or 2 gang that went faulty for you?
for those using xiaomi switch i have 2 burnt and based on xiaomi forum there are others with cases as well. they can cross sell their smoke alarm alr....
thanks for your detail explanation,
for me i just want a simple on off switch that can integrate with Alexa.
My neighbors intro me Sonoff, is it good? from what i see it look quite primitive as compare to Lutron.
In Sg there's not many such product that was brought in.
I actually likes the Lutron 2 way dimmer switch, it allow me not to hack for corneal hard wire. I was wondering if there is anymore such product that was produced by different company?
Sonoff cheap and seems easy to install but i read somewhere they lack safety in some areas... not very sure about this thou also hope to hear more opinions on sonoff!
I hope their curtain motor wont end up like this
that look very badly burnt. I've installed a couple of them (the neutral cable) for my flat.. hopefully this situation will not happen.
I got 3 gang sonoff touch. However, I've yet to flash them.
