Z_Dash
Sorry bros.......wanted to check if anyone had used Xiaomi Gateway with other smart switches?
My home has constraints which many switch are 3-gang.......while xiaomi has only 2-gang max.
Creating additional holes is not an option sadly so i gotta check up with light switch like Broadlink TC2.
tecnica
SaLvAtoOo
are u ok with combining 2 switch to become 1? that's wat i did... for eg, kitchen used to have 2 switch to control 2 lights + toilet.. so total 3 switches...
i combined the 2 kitchen light to 1 switch and the toilet to another....
Z_Dash
Not using as xiaomi aqara only has 2 gang but I have many 3 gang switch.
Ooh.....effectively making 2 gang usable?
But my lights were designed by my home minister......can't touch sia. :(
Z_Dash
Any bro can advice?
Or bros on xiaomi gateway purely links with aqara switch?
AsusEpoxy
Any bro can advice?
yes , so far xiaomi hub only works with their ecosystem stuff
however xiaomi switches can be used with other hubs such as homey,smartthings,hassio, but that's not what you are trying to achieve though.
pajamasguy
Is it possible to link Google Home with Xiaomi Air Purifier 2S (the one with the display)?
It shows up on Alexa but I cant add it to Google Home
Thanks in advance for your replies
tecnica
pajamasguy
Guys I am looking into LIFX bulbs, can check other than amazon selling slightly cheaper than the official site, is there anywhere to purchase it?
Also I have this ikea bulb socket:
I am not too sure abt electrical specs, can advise if can use with the LIFX bulbs?
TIA
This Ikea lamp uses E14 bulbs which LIFX do not have currently but I heard they will release e14 soon.
If you are buying the bigger size bulbs, you will need to look for E27 bulbs. US uses E26 which is slightly smaller so choose E27 when buying from LIFX site.
pustefix
I've a 3 gang switch and I intend to do the following:
- Use a smart light for 1 of them and a Xiaomi wireless switch to control it (not the neutral/non-neutral wall switch, just a stick on switch).
- Use 2 gang switch for the other 2.
pajamasguy
good idea also
bullfrog
That means ur smart bulb is going to be always powered. You have no physical switch and must rely on ur db box to cut the power. Changing the bulb will require you to turn off at the breaker.
I would link two lights to one switch and the other light to the second one. Cheaper solution as well
tecnica
dirtytrunks
Hi Bros, having a headache with my Xiaomi gateway now. Just set up the gateway and tried to add my neutral light switches (double and single) as sub devices. None of them were able to connect even thought I long pressed till the blue lights were flashing. Anyone can help?
Edit: tried connecting an aqara cube as well but couldn't detect, so I doubt the switches aren't the problem. Any one can share their experience?
