ihuazai2
anyone using aqara curtain motor with alexa? Can it work with alexa echo plus direct or need to buy additional xiaomi gateway?
IF need gateway, is the xiaomi v2 gateway or aqara hub better?
Thanks!
bullfrog
Thanks!
I am using with alexa (not plus). I initially hooked it up via smarthings, but i eventually bought the xiaomi v2 gateway as it was getting too complicated to configure smarthings for my aqara switches as well.
The mihome alexa skill does not work xiaomi gateway. For Alexa to work, i also setup home assistant on my desktop computer.
ihuazai2
oh my.. maybe dooya motor + RF broadlink would be better choice if wanna use alexa to control curtains?
tecnica
SaLvAtoOo
Are you guys trained electricians or do you hire someone to help you rewire?
i'm not trained or certified.. but you can easily know how to do with some read up.
for me, i have 3pin 13A switch next to most of my light switches... so just tap the neutral wire over...and it's done... no need to pay electrician.
for my storeroom light, i run a neutral wire from the light to the switch as it's not consealed.. just have to add another neutral wire into the trunking (from the light to the switch)... $0
tecnica
Haha I also have 13A 3pin plug beside most of my light switches but I dun dare to do..
AsusEpoxy
hey bro, looks like smartthings + Aqara didnt work out for u as well? ur my last beacon of hope leh
bullfrog
Yeah. There's a limitation with the aqara dual switches and smartthings. I was reading up about it when i was about to configure them. It seems smarthings cannot query the state of the second switch.
Using the xiaomi gateway, i can see the state of each dual switches on my phone.
It also allows better control for the curtain motor.
With home assistant, alexa can control the switches and curtains. I can now tell alexa to "open curtains 50%" and it does that perfectly. I couldn't do that with smarthings.
pustefix
Where do you find the thick cables that are used in the trunking? I don't think I see them in my neighborhood DIY store.
ihuazai2
got xiaomi gateway v2, any issues with it being on china server?
bullfrog
Not with the switches or curtain motor. However there is a problem with roborock 2 vacuum which I bought locally. If i update the vacuum to the latest firmware, it wants the mihome app to be on the sg server. I had to factory reset my roborock and ignore it's firmware update notification. Then only can it work with the China server.
SaLvAtoOo
i got the cables from choo chiang... but they only sell 1 roll and not by metres... i tink some bigger neighbourhood stores can buy by meters but not cheap...
bullfrog
Just now I went to pry open the trunking.. haiz only see one blue wire within the bunch of cable leading to both the 13A 3-pin plug and light switch..
Posted from my million dollar ivory tower using HardwareZone Forums app
Blue is usually for neutral. However alot of electricians never follow colour code. I suspect that cable is actually ur live wire.
But if u have exposed trunking, its quite easy to lay the neutral cable, tapped from either ur 13A plug or from ur ceiling light.
tecnica
Haha cannot be.. got a lot of red wires but only one blue and one yellow.. I think better leave to the experts cos I have colour deficiency and I dunno how to terminate the points as well..
Mayb can implement in this house?
http://www.asiaone.com/multimedia/gallery/japanese-style-4-room-hdb-bto-apartment-whampoa
Sent from Sony Z4 using GAGT
Z_Dash
Sorry bros.......wanted to check if anyone had used Xiaomi Gateway with other smart switches?
My home has constraints which many switch are 3-gang.......while xiaomi has only 2-gang max.
Creating additional holes is not an option sadly so i gotta check up with light switch like Broadlink TC2.
