boliao45
You cant run kyla app directly from google assistant, but you can add the ir cube by linking your kyla account under settings -> home control -> +
For creating custom command, try look under routines. Routines allows you to chain a few different actions with a single command phrase
can i check with yall, how do i get google assistant to run Kyla app ah?
cant seem to create custom command..
plustwo
anyone knows how to control more than on/off for ac for orvibo app? in homemate i can create scenes that control temp etc but in google assistant all i see is cool/hot/off.
boliao45
Unfortunately, orvibo didn't integrate scene control for GH. You could try your luck giving Aztech feedback so they can pass it along to orvibo for updates later. That is provided they never ignore the suggestion at all.
plustwo
is this integrated for kyla? is there scene control for ifttt or something?
boliao45
Like i said before, Aztech is just a rebrand of orvibo, you can try writing in to them for feedback and hope they pass along the mesaage.
And there's no plan for ifttt integration at all, from Aztech support...
AsusEpoxy
1. Samsung Home Connect is pretty much the same thing as Smartthings except that it has wifi and KR Z-Wave built in
2. I personally went for US Smartthings. Most Z-Wave stuff here are UK frequency, so you will need a UK Smartthings. That said and done, it all depends how much you are gonna spend on Z-Wave. That said, Z-Wave light switches are among the most expensive ones. Everyone has a different cost analysis, so you have to decide yourself.
3. If you wanna plug in and play and forget... not really a gd idea cos they were not supposed to play well with each other. Some reported success and others have nothing but frustration.
4. Aqara hub is simple. However if you are chinese region app averse, not really good as Mijia and Aqara's base is still predominantly chinese based.
5. Google Home is playing catchup with Alexa. However G is the big brother, they can prob afford to throw more money than Amazon.
Hi all
I have some noob questions on aqara and hubs, am buying the aqara switches. also planning to get the vaccum
1) with the new samsung home connect being sold, would you all recommend it over a smartthings hub?
2) are you all purchasing the UK smarthings hub?
3) has the experience been good with using smartthings to control the aqara switches? ie are the device handlers working well?
4) should i just get the aqara hub? But i understand it can only work with alexa and not Google home
5) between alexa and google home, what is the better path? alexa is not officially availabe in Singapore, but it appears to be incorporated in more things on the market
Really hoping for help from all the experienced brothers here. thanks v mcuh in advance!
SaLvAtoOo
those intending to buy the xiaomi aqara wall switch without neutral... u have to think twice. a lot of mine (without neutral) broke down within a couple of months. in the end, i rewired and run netural wires to the switches and changed to the neutal version. it's more stable now.....
AsusEpoxy
yeah...same situation here... so what did u do with the remaining still working non neutral switches?
SaLvAtoOo
For those interested in smart blinds/curtains, this looks pretty good and easy to install.
https://youtu.be/rUWimvBEeZc
i'm using brunt blind engine... bought it during it's kickstarter phase... unfortunately, it doesnt work with my blind...
1. the chain needs to be continuous looped kind... cannot work if your chain uses extension bead.. (i.e: to merge 2 ends to make a continuous chain)
2. the weight of my blind is too heavy, my blind is too big...the motor cant lift the blind..
so have to becareful when buying....
SaLvAtoOo
I have a few switches that are consealed within the wooden cabinet and I can’t wire a neutral wire. So the switches (without neutral) become their spares lor. Haha.
New home owners should wire a neutral wire to their switches when doing reno...
MaoZeDuo
Major work to rewire?
Elon Jobs
Good point to take note of! Thanks for sharing. These devices don’t come cheap so we got to do our homework and manage our expectations before purchase.
fern76
RE: Need neutral wire?
I got my tracks from this seller.
https://s.click.aliexpress.com/e/cGeZ3DvQ
Really helpful and answered all my questions. Just tell them u want to connect the xiaomi aqara motor to it. Seller will know what u need and everything sent fit perfectly.
Hi there,
Thanks for the link.
Does the Xiaomi agara motor need a neutral wire?
I am currently looking for motorised curtain tracks for my new home. I had the house rewired but was quite silly and did not think to ask electrician to pull the neutral wire.
Now that the false ceiling is up, I believe it might be too late. :(
Initially was thinking of using MCO Home light switches which would have needed the neutral wire but from reading online forums, found that the RM Pro can connect to switches which cost way less and do the same job. So decided not to waste money on getting neutral wire since only the MCO Home switches needed it.
Does anyone have good motorised blinds to recommend?
Please let me know.
TIA!
bullfrog
Hi there,
Please let me know.
TIA!
Regarding the xiaomi motor, it uses a 3 pin power socket. Maybe ur electrican can bury the cables in the wall and install a socket near where the curtain rail should be?
fern76
Thanks for quick reply.
I already asked him to have points for the curtain motor. Just confused by the neutral wire factor. So basically only lighting points have 2 wires and the rest have 3? :s11:
