pajamasguy
i mean when you buy online.. china seller usually don't list this info. no neutral wire still can use but not safe right?
Neutral or Non-Neutral switches has nothing to do with safe or not safe.
To tell which type you are buying, look out for these key differences -
Non-Neutral
Model no. - QBKG04LM (1gang). QBKG03LM (2 gang)
Load - 800 watt maximum
Has words like "Single Fire Wire" meaning only one Live wire needed.
Neutral type
Model no. - QBKG11LM (1 gang), QBKG12LM (2 gang)
Load - 2500 watts maximum
Has words like "Zero Line and Firewire" meaning it needs Live wire and Neutral
Neutral types are generally cheaper compare to Non-Neutral.
I suggest that you buy straight from Aqara's official Toabao store - aqara.world.tmall.com
for the latest revision
pajamasguy
anybody here using roborock s50 robot vacuum? mind tell me if yours is connected to which server? and did you update to the latest firmware? about to get one so I like to know beforehand. thanks
plustwo
anyone knows why when i try to add mi home to google assistant it just goes to the previous screen without adding anything?
Aesunited
Hi everyone, I just started on my HA journey. I was kind late for HA sadly as my BTO reno was completed 6months back. Too late to pull and conceal neutral wires. I don't mind simple modification with thin casing. I had read through quite alot this thread. I really learnt alot.
My HA plan is to use Google Home to control my living room ceiling lights, dining light and kdk fan with light, entrance light and master bedroom ceiling light. I wish to have 3 main scenes setting, "Reach Home"- entrance light on, corridor light on by voice, "entertainment time" - off entrance/corridor light and on living room lights plus fan, "going out" - off all lights
I think the key is with my wall switches. I hope to ask for your recommendation on this. I read on Broadlink RF compatible switches and Sonoff wifi/RF switches. I think I need to use broadlink rm pro to control them. Hope any kind soul to help with recommendations and share if you have similar setup with switches.
Thank you!!!
pustefix
If you are going to do it on a daily basis, I think using sensor to automate the scenes make more sense, e.g. when front door is opened, then motion detected near door = "Reach Home". I've tried using voice to control some lights daily and found it a hassle, now if I can't use sensor to trigger it, I will place a wireless button to turn on/off the light. I seldom use voice to control it.
Aesunited
Yup I agree! I think is the novelty to try out voice control first. I think as I get tired of Google, I will explore using sensor to activate the scene.
Thanks man
tecnica
Jas007
Aqara rocker switch, is a gateway/hub required to operate with Alexa & Google Home ?
think i might have made a mistake thinking it can work without one ... like the Sonoff one ...
TIA
AsusEpoxy
TIA
Aqara switch is zigbee, not wifi, you will need the Mi Gateway.
