bluez
Aqara rocker switch, is a gateway/hub required to operate with Alexa & Google Home ?
think i might have made a mistake thinking it can work without one ... like the Sonoff one ...
TIA
I made another mistake thinking that all xiaomi products can be used with google home but realised mi gateway and aqara switch can't, at least not natively. Now exploring home assistant but it feels complex.
SaLvAtoOo
actually HA is not too hard to start.... there's lots of tutorial and videos you can learn....
viix
Yup I agree! I think is the novelty to try out voice control first. I think as I get tired of Google, I will explore using sensor to activate the scene.
Thanks man
Plan ahead. Not many hubs has sensor capabilities. I don't use switch often now. Mostly motion and lux level activated that I'm no longer used to turning on switches outside of home..
viix
Too cheap to be true.. dunno can trust or not.. I am using tp link lb110 atm, looking for lb120 also.. but no offer leh..
Is the Yeelight reliable?
https://s.lazada.sg/s.YfM4
Yeelight bulb so far ok. I had problems with the 3 ceiling light for my storeroom and toilet. The light goes off after sometime and cannot turn on with the hardwired switch due to some firmware problem. Heng recently it was discovered and fixed but kind of disappointed with it.
bullfrog
You need the xiaomi gateway. However its not too complicated to add the gateway into home assistant. You can use ur computer too but it needs to be on 24/7. Better to get a pi for it.
I did it first via my desktop but have just received my pi. Planning to port over my settings to it today.
Didn't really feel happy running Home Assistant on my desktop cos Windows update restarts my desktop. While i have scripted HA to start automatically, i prefer to have it running uninterrupted.
viix
anybody here using roborock s50 robot vacuum? mind tell me if yours is connected to which server? and did you update to the latest firmware? about to get one so I like to know beforehand. thanks
SG Server. new firmware has virtual boundaries and saved maps so now can map areas no to go to.
bullfrog
Just wanted to update my Aqara with neutral switches, all 16 of them still working fine for 4 months. Looks like those that recommend the neutral wire version are correct on their durability.
bluez
Haha ya time to explore more. Will be here asking for help more often. Spend too much on these stuff to give up now 😂
bluez
Anw, anyone had tried out xiao ai? My parents can't really speak english and since I've invested in mostly xiaomi stuff, wondering if i should try it out.
I saw google pushing out chinese language for google Taiwan but I can't seems to get it.
tecnica
I got my smart bulb yesterday.. seems like that is noticeable lag before the bulb receives my command.. not too sure why but my tp link bulb does not lag this much..
pustefix
When you said receives your command, I am assuming you are using voice. If you used voice then it has to go through Google server and Yeelight server before reaching your light, of course there is lag. Try to use commands that use local network only. If I am not wrong, most automation in MiHome app is using local network only.
I am using HA and have Aqara motion sensor to trigger the Yeelight bulb and it is almost instantaneous.
onionhead
is homey a quick and easy fix as a hub to control devices?
my ideal world would be where i can control my switches & lights that are fitted with Shellys, TV, Aircon and set IFTTT commands on only 1 app.
the industry is so fragmented that im getting a headache just trying to understand it. I checked out Home Assistant but it looks like its more on setting IFTTT commands?
bullfrog
Actually, home assistant doesn't primarily use IFTTT. You need to install a web server at home. This can be via raspberry pi or on ur desktop pc.
All controls are done locally as it is the pc/pi that interfaces directly with ur devices over ur local LAN. Cloud only comes to play should u decide to use the alexa skill or IFTTT.
tazy_tazy
I'm also waiting to get a homey to save time...
noocky
Curtain motor
Anyone installed curtain motor for your place?
Am currently looking at these 2
xiaomi aquara curtain motor + track + xiaomi gateway
and
dooya curtain motor + track
which one will you all recommend?
Understand that both these products can work with Alexa?
tecnica
I know the command goes through at least 2 servers hence that will be some lag.. but the latency for yeelight is noticeably longer then my tp link bulb..
