pustefix
did anyone tried installing aqara switches? I bought 1 and tried but i couldnt get it to work. My LED light keep flickering. anyone having same issue?
I've 3 Aqara non-neutral switch connected to 9W LED bulbs or T8 tube. They are all working fine for the past 5 months or so. A few days ago, one of them started to flicker in the off state. If the switch stop working, I think I will just change to WiFi bulb and normal switch. That combination seems to be more reliable for me and has less dependency on the hub.
pustefix
For those who are using Xiaomi Gateway, do you have any problem with recent firmware? My version is 1.4.1_161.0143 and it was updated few days ago. Within a day of running, it will fail to response and I could not turn on/off any switch. Sometimes restarting the gateway will get it to work for a while before the problem reappear. To make matter worse, I also recently change my router and I have another Gateway with same firmware that doesn't seem to have this problem. I am at a lost what is the problem here, still debugging...
I think I've resolved the issue that I am seeing and you will not believe what is the fix. It is the order which I power on my 2 gateways. Here is the background:
I've setup gateway A first and a few months later gateway B. If there is a restart, I will power on A first then B. Due to some issues recently, I reset gateway A and re-setup. Now if I power on A then B, the whole system will not work properly after a few hours. On MiHome app, gateway A and devices attached to A will appear offline. On Home Assistant, I still get sensor data from gateway A but I can't turn on/off switches, it seems that it can still read but not write to gateway.
I power on gateway B first, then A and the whole system is working fine after more than 24 hours. I tried to search for this issue but found nothing about the order of powering on gateway. Anyway just a note for user with 2 or more gateways if you get problems, maybe try powering them in different order.
doofie
looks like the flickering is a common issue. Furthermore i'm using the neutral switch version.
doofie
thanks, i'm actually thinking of getting another 2 hubs. lets see if i face the same problem too
bullfrog
None of my switches flicker. You might have a defective switch or a bad connection/ wire too.
Try snipping off the ends of ur wire, stripping it again and reconnecting. Be sure to off ur mains first!
I saw my electrician do that during my reno when the switches didn't work or had intermittent connections.
bullfrog
Which is the cheapest smart plug that is compatible with Alrxa?
Get a plug thats sold locally for our standard. I think challenger sells both wemo and TP-link. I tried a china branded plug with UK head (ordered through ali express) but the connection to my wifi was flaky.
Shawny88
Thanks! Is it cheaper to get it online, say from Amazon uk or lazada, qoo10?
doofie
thanks. are you also using aqara? and LED lights too?
bullfrog
I'm using aqara (w neutral) switches. Have about 16 of them in my house. No flickering. My bulbs are regular LED bulbs. I do have a few regular LED strips too that some of my switches controls. No flickering as well. What's important for those is the appropriate driver based on the strips length.
bullfrog
True to that. But buying 10 plugs at one go is a lot of $$$$ considering one cost more than $20
Thats also true. However if you noticed, some of us have encountered defective devices. Especially the aqara switches without neutral. The burn from that i would imagine is quite bad.
But then again the TP-link/ wemo power plugs do seem pretty reliable from reviews. Ultimately, your call. I can't speak for those as i am using Samsung power plugs. I decided to splurge as i wanted smaller form-factor plugs
Shawny88
Thanks. Will wait for 12.12 sales. Hopefully have good deals
doofie
wow... 16? thats alot. All no issues? any defects at all?
AsusEpoxy
sounds like u need to add a resistor to increase the load so the light does not flicker
