doofie
sounds like u need to add a resistor to increase the load so the light does not flicker
darn... anyway, gonna try out on another room and see if it's the switch problem. If it still doesn't, will try on my parent's place as well. Seller was willing to test for me but i've to bring it down. So might as well do my own troubleshooting first.
plustwo
what's the hack for connecting mi gateway to singapore server? all my devices are on sg server but the gateway can only be detected on china server
doofie
yeah, thats why i've all my devices on the china server instead. but so far the instructions are in english. EXCEPT the universal remote one, the interface is in chinese words.
bullfrog
Unfortunately, as of now, there's no way to get the gateway onto the sg server.
The hack i used was to setup Home Assistant and added my xiaomi devices to it. I have my roborock, aqara switches and curtain motor all controlled by HA so i don't have to keep switching servers on the miHome app
plustwo
does the universal remote function like orbivo's ir cube? how does it integrate with google home controls? i'm using orbivo to control ac but only can on/off cannot control temp. if xiaomi can i will buy immediately
pustefix
If I am not wrong, there is no single ON control for air con. Basically the IR signal contains all the information in your remote to switch on the air con. The ON signal for 25 degrees auto fan is different from 25 degrees low fan. Hence when training the IR blaster, set all your settings on remote before training. In other words you can not have single control for temperature, fan, etc.
plustwo
you mean the remote clones the signal from the real remote? but i saw the ui pics looks like they let you control it like a remote?
bullfrog
The challenge will be telling Google home or Alexa to change the temperature to whatever you want it to be. The app in ur handphone can be programmed (as the image showed) but that doesn't translate to having Google home or alexa using those settings when instructed vocally.
Usually it's just to turn on or off a device.
So you will need to somehow create a script that does a pre-determined set of instructions when u tell it to turn on.
plustwo
google assistant doesnt support scene control for mi home right?
doofie
have no idea how is orbivo's ir. But i know in broadlink i have to programme it to a lamp in order for google to rec it. But for xiaomi one, you can't do that even. Thats why i'm exploring HA and see if i can get google home to work with it.
plustwo
how to add more than one mi home account to google home? have some device on sg server some on china server. or need to go through home assistant?
Jas007
Aqara Wireless Switch ...
couldn’t get the Dpuble Rocker to pair
it blinks 5x and then stops ...
pairing failed
tested, battery is not weak
switch is next to hub
didn’t have issues pairing the Single key version
at wits end ... think 5 blinks then stop is resetting the switch ... tried pressing single buttons, tried pressing both, each time it blinks 5x then stops ... pairing fails
Jas007
update : succeeded pairing after whole morning trying after ...
i changed the battery !
funny thing is i used an old battery and the blinking was not visible but just as i was about to despair noticed the app reported pairing was a success
PS : a search on google yielded many others reporting this same pairing issues
