D I need extra hardware to connect to zwave and zigbee?
a model 3b is around $55
For ceiling fan with light, when connected to light switch,
Is it possible to on either 1 (light or fan)?
Or both will be on when called?
As morning is bright, don't need light. so just on fan.
Night time then use light+fan.
Edited: Saw somewhere that I have to wire ceiling fan and light separately, to 2 light switch to control them separately. Anyone have any experience with this?
where to find this price? amazon 70+. is there a local distro or something?a model 3b is around $55
Guess it depends on your fan. Usually turning on the fan will on the lights too. What you can do is to leave the fan switch perpetually on.
Using broadlink/rm pro you can tell alexa to turn on the fan or lights accordingly. You can also use the routines in alexa to manage the brightness of the lights too.
Its not very elegant though. I knew this from the beginning so i setup my home to use its own lights and not get a light attachment with my fan. Hence i can individually control lights and fan via their respective switches.
Yeah.. You're right. But if i go with the internal dns setting, i probably have to wipe my hassio and install haspian instead. Then i can run a dns server on it (i think). I may walk down that route one day.. But not in the near future. Lazy to rebuild after i just built up my HA
For those who are using Xiaomi Gateway, do you have any problem with recent firmware? My version is 1.4.1_161.0143 and it was updated few days ago. Within a day of running, it will fail to response and I could not turn on/off any switch. Sometimes restarting the gateway will get it to work for a while before the problem reappear. To make matter worse, I also recently change my router and I have another Gateway with same firmware that doesn't seem to have this problem. I am at a lost what is the problem here, still debugging...
Talking to myself (i know) but i just worked around my router issue by installing Dnsmasq on my hassio and setting my hassio's ip address as my primary dns on my router. All works now. I can finally access from inside and outside![]()
Wow. What is this 'inside and outside' thing about?
bro, u powered up liao!
There are reports that the latest firmware is not working with HA, so do not update if you can:
https://community.home-assistant.io/...to-ha/65720/44
how much will a raspberry pi for running ha cost?
May i know what you use the pi for for HA when there is broadlink already running? Have a spare 1 sittting around , thought of utilizing it for HA
Ok edited my message, just read further down the thread from bullfrog that Pi is for integrstion with Hassio, but hassio is already a GUI interface to link up home assistant right? Where is the play coming from the pi ?
Actually smart switch requires electricity to remain connected and ready to turn the lights on. So you can imagine it having to draw power to remain connected and yet keep the light circuit open to keep the lights off. How exactly it is done is clear in the following website.
https://www.vesternet.com/blog/why-smart-switches-cant-be-used-without-neutral/
That is why there is a lower limit to the power the light can be connected to the switch.
3W energy saving lamps / 5W LED lights / 16W fluorescent lamps
Anyway now knowing that live wire only smart switch have to resort to such method, I prefer to use the neutral version.
The Xiaomi Live wire only switch face issue such as flickering of low powered LED lights even in off state, and as shown here a few switches spoiled within a short period of time.
Not sure if neutral switches have a better reliability, or is due to low in SG as the light switches in BTO and HDB is live wire only.
