wahjohreno
hi guys,
recently I order a z-wave module and samsung smarthing hub from amazon uk.
And I want to set up my Yale 4109 lock to be z-wave compatible
But I have problem adding the lock to the smartthing app.
I remove the batteries from lock, insert the module and put back the batteries, then I open the smartthing app and click add device, but it wouldnt discover the lock.
Anyone know the steps by steps guide to pair the lock with the hub?
I tried finding info from internet but cannot find any video or link that teach how to connect the 2.
So I really hope someone out there can help me
Thanks alot
Not all Z wave devices are compatible. Depends on region, and even so, it’s quite touch and go.
That’s why in the end I left it up to the pros to spec my house because all the things I initially proposed to them, they said will not work. The pros know what definitely works, and what works better than others and which version of softwares to stick to to avoid issues.
bullfrog
I had 2x aqare switches (neutral ones) used to control exhaust fans in the common bathroom and master bathroom. One lasted 6 months, the other lasted 3 months. So keep your fingers crossed!
Damn.. Thats a cause for concern
bullfrog
Woke up this morning to find my hassio ( home assistant) unable to communicate with my harmony hub
Then i saw this
https://www.reddit.com/r/homeassista...breaksremoves/
Seems Logitech pushed an update closing off local connections to it. Needed to downgrade harmony hubs firmware and block harmony from phoning home already.
Official statement from Logitech
We are aware that some customers using Harmony APIs which were never documented, nor supported Harmony features. While it is unfortunate that customers using these features are affected by this fix, the overall security of our products and all of our customers is our priority.
The register picked this up too
http://go.theregister.com/feed/www.theregister.co.uk/2018/12/19/logitech_harmony_smart_home/
SaLvAtoOo
Then i saw this
Shame on Logitech. But luckily there’s a workaround.... otherwise thrash it goes.
Jas007
can someone confirm that Xiaomi gateway can only interact with Alexa or Google Home via Home Asst (Raspberry Pi) ...
it CANNOT work directly without ...
Thanks
bullfrog
Thanks
Confirmed. The mihome skill for alexa does not recognise the gateway. I'm using HA because it doesn't.
iceJman
what's the intermediary to use for conversion?
IR remote switch module in case
"IR remote proxy" to control RF ceiling fan
iceJman
interesting setup. is there a guide you used? parts numbers?
U can get the IR remote module from aliexpress
US $2.79 | 1 Channel 5V DC Infrared IR Remote Control Switch Receiver Module Board For Home Device
https://s.click.aliexpress.com/e/cOnQNUNS
MaoZeDuo
bullfrog
For those still contemplating on using home assistant for your home interface, i say go for it!
Heres what my interface looks like now. At a glance i can see which lights are on
:s7:
Oh and a bit off topic but, Merry Christmas!
Elon Jobs
:s7:
Beautiful!!
I used to have a homey but it’s sort sort. Looking for a zwave replacement. I also have amazon echo. Looking for a cheaper replacement. Homey is close to $600. How to ensure my current zwave lights etc will be compatible ?
Can I bypass homey since I don’t automate much and use voice instruction. Thanks
Thanks
bullfrog
Thanks
Posted with my chat bot HardwareZone Forums app
Where did u get your lights from? U kinda have to buy a zwave controller from that region to ensure compatibility.
