JinHockie
I’m getting my house soon and explore home automation. Most of the discussionare on Android home automation. Anyone have info on Apple HomeKit?
plustwo
anyone have this situation before? my home gateway went offline in mi home app after internet problems a few days ago but never came back online. i manually powered off and on the gateway and the automation rules are working again but the device is stuck offline in mi home app.
Where did u get your lights from? U kinda have to buy a zwave controller from that region to ensure compatibility.
it's EU region, so any zwave controller will do?
can direct hoot to amazon echo or not or need controller?
I only have
-lights
-zwave door to trigger light scene
all sensor.
bullfrog
can direct hoot to amazon echo or not?
European zwave frequency is in the range of 868.4MHz. US/canada zwave frequency is in the range of 908.4MHz.
So no. Not possible from amazon USA. Best from amazon Germany and possibly UK.
Zwave devices cannot hoot directly to google home or echo. Not even with echo plus as the echo plus only supports zigbee. So you will need to buy a zwave controller. Echo or Google home should talk to the zwave controller which in turn, controls ur light bulbs.
Should I get back Homey or try Wink 2 or Samsung SmartThings Hub 3rd Generation ?
UI need to be ease of use and compatible with my current zwave stuff. Of course buying from EU or UK is a given la
https://www.smarthome.guide/best-z-wave-controllers/
bullfrog
Posted with my chat bot HardwareZone Forums app
I'm currently using a Samsung v2 hub bought from amazon USA. It works with my zwave devices that i purchased from Amazon USA.
The zwave devices connect to my Samsung hub which interfaces to my Homeassistant running on a pi.
If you are going the Home Aassistant route, i would actually propose buying a raspberry pi and get a compatible zwave usb stick for it.
Something like this possibly?
https://www.amazon.de/gp/product/B00...tag=sso0e07-21
I went the smartthings route only cos i bought that 2 years ago and only discovered HA 2 months ago.
So basically use the raspberry as a PC to power up/charge the stick?
What is the Home Assistant route? I check the webbie seems like support quite a bit of stuff?
BTW, is it true as long as zwave switch will be able to pair with the stick hub? The processor is it fast enough?
bullfrog
The raspberry pi will run hassio (home assistant) and hassio will interface with the zwave stick that is plugged into the pi. As long as ur zwave device meets zwave standards and not some proprietary method of communication, it should work with hassio and the zwave stick.
Home Assistant is something like smarthings, but a lot more feature rich. But its advisable to have some coding background if you wanna go the home assistant route.
Yeah , got coding la. but if do simple stuff, on lights when certain thing triggered etc la. No GUI for setup ah?
so maybe I need to unpair current devices, then buy PI and the stick, install hassio la right?
kennyboy
There's a GUI, but adding stuff mainly consists of editing a text file. But not very hard to learn. I setup my whole house in HA in an afternoon.
bullfrog
There's a gui. Has also a web app so ur phone can control the devices. But gotta edit a text file for configuration. Not too difficult then. Go for it!
Sorry..there are 2 steps
1) Pair
2) edit text file
Also how to make your stick and raspberry chio chio? Got pic?
your rasp is using linux?
btw, how is the speed of the rasp also any lag when you trigger your lights etc. raspberry can cope?
https://www.nabucasa.com/
Do we need to use the cloud stuff?
Also 32gb micro sd good enough hor and get the fastest raspberry right?
My router is just beside my smart home hub so I LAN it rather than wifi.
Back to my initial question for Aeotec or other Zwave hub as long as it's zwave and same freq the hub will be able to connect?
bullfrog
1) Pair
2) edit text file
it has an auto discover on start up. Haven't tried with z-wave devices (cos using smarthings) but it detected my Logitech harmony hubs automatically. If it doesn't detect, you may need to insert some settings inside for it to detect ur particular device. I had to do that for it to detect my xiaomi gateway and roborock vacuum.
After detected, then u configure it.
bullfrog
Optional. Cloud if u want to use its alexa skill. Otherwise, i understand you can also setup hassio to emulate a Philips hue hub so alexa can detect it and control ur devices like light bulbs. I didn't use the hue emulation as i have curtains and i may want to stop the curtains from fully opening/closing.
32gb sufficient. Ya, get the fastest. I also connected my pi to the lan port of my router.
Yes. As long as the, zwave stick is supported by hassio and the device u want to connect it to isn't using some proprietary communication method. Can also check the device if it is supported by hassio as well.
ok so need to pay $5 for alexa usage then?
can explain abit about the emulation?
MaoZeDuo
Hi, am I reading correctly that the aqara switch can support up to 800W hence it should support 5 sets of the 12W Philips LED?
bullfrog
If you edit the configuration.yaml file, theres a setting u can enter to enable emulation.
https://www.home-assistant.io/components/emulated_hue/
If the hassio is on the same network as alexa, just tell it to discover devices. All ur switches or lights should automatically be detected by it and appear as light bulbs.
I tried that route initially but my curtains didn't appear as it is identified as a 'cover' in hassio. While i could make a boolean switch to control the curtain in hassio so alexa can detect the boolean switch, a boolean switch can only be on/off. So the curtain would only open 100% or 0%.
Also i will need to say turn on/off curtain.
With the skill i can say open/close curtain 60%
But if u are only using lights or bulbs, u can use the emulation for alexa to discover and avoid the subscription.
from the link
A physical Hue Bridge is required for Philips Hue lights to function - this virtual bridge will not replace a physical bridge. Instead, it allows Home Assistant to represent non-Philips Hue devices to Amazon Echo as Philips Hue devices, which Amazon Echo can control with built-in support.
>> so for actual Philips Hue users, they need the physical bridge. For non users, can use emulator. am i understanding this correctly?
