SaLvAtoOo
- Sep 2, 2000
anyone tried hooking up the aqara light switch to water heater that use wall switch?
you need to use this... so far, i only find this to b 16A rated
Sharing, no WiFi, no problem.
https://www.cnet.com/news/hubitats-smart-home-works-without-the-internet/#ftag=CADf328eec
openhab is much betterSaw this too. Game changer
i asking only.. if someone tried before cannot then i dont bother opening up alreadyhow?
the power rating not high enough i think
@ralfale yes its iffft only
later i dig to see if i can share the applet here
EDIT: https://ifttt.com/search/query/somfy
if asia pac, look at australia. somfy have score good results with integrators in state victoria
they only finalise announcement in march 2018. back then was just still sorting technical issues. then in jul / aug 2018, they are officially launched.
They sign a collaboration contract in oz, so technicality issues they will sought very hard to resolve it else the contract will fall thru without renewal
I was looking into SmartThings to replace my existing hub and I stumbled upon Hubitat. From their forum, it seems that the community is growing positively with community-developed device handlers. I think one of the key advantages it has over SmartThings is localised device control, i.e. commands do not have to go through the cloud.
Unfortunately, they do not ship to Singapore. After speaking to Bruce (Chairman of Hubitat), he had made it available for shipping to Singapore. However, they only have it in UK and US z-wave frequencies (Singapore has moved to Korean z-wave frequency).
Since my existing z-wave products are on EU frequency, I had placed order for the UK version of Hubitat. For now, I'm waiting for its arrival from US, will share more once I gotten my hands on it.![]()
Not sure if this is the right section to post. I need to find the best solution for my issue. Basically I wanna have a single universal remote that controls my LG TV and Singtel Fibre TV set top box. The complication is that my set top box is hiding inside a cabinet in my TV console that doesn't allow for a normal infra red signal to pass through.
Any suggestions?
why cant you buy a pi and run openhab for less than half the cost?I was looking into SmartThings to replace my existing hub and I stumbled upon Hubitat. From their forum, it seems that the community is growing positively with community-developed device handlers. I think one of the key advantages it has over SmartThings is localised device control, i.e. commands do not have to go through the cloud.
Has anyone bought this smart plugs before? It has a 4x sockets and can be connected to Alexa, IFFT and Google home. The square plug has energy monitoring. I just tried it and it works very well. THe app to connect is smart life, has both android and iOS version.
https://www.tuya.com/
I do have a pi, but not much experience on openhab.why cant you buy a pi and run openhab for less than half the cost?
i jumped straight into openhab with no experience and managed to get everything up and running in 1h.. many resources on their forum which functions like stackoverflowI do have a pi, but not much experience on openhab.
I will prefer a turnkey solution as far as possible. I took a quick look at https://www.makeuseof.com/tag/getting-started-openhab-home-automation-raspberry-pi/ and I do not think it is an endeavor I like to embark on.![]()
what is the price? seems like single point of failure if too high. rather buy 4x smart plug. also prefer to avoid anything that goes through china cloud![]()
edit: this instruction is from 2015.. now 2019 just download the snapshot and flash to sd card and run from there
Did you buy this locally? how much is this?![]()
