OnePlus 8/8 Pro!
rootz
Interestingly,
Lazmall official shop sells local set at 1398 for 256GB
Other platforms eg
- Qoo10 - export sets with 12 mths for 1447 (256GB).
- Carousell - official shop selling 1518 (256GB)
Just sharing.
FreedomzEvez
Then my answer to u is go with non pro
Save the 300 bucks. Economy not good due to covid bro
And also:
30hz difference u cant really tell unless u pixel peep. And 60h to 90hz is good enough and conserve battery life as 120hz is taxing on battery. Comparing 90hz and a 120hz side by side of course u will notice a difference. But if u dont compare 2 phones together u wont really notice. U will notice more difference moving from 60hz to 90hz definitely
Im using pro version, no issues with display and think no one else here having issues as well. Definitely will have some green tint at super low brightness as i need to set expectations right, that is the downside of ANY amoled panels, but how often do u use your phone at lower then 10 percent brightness? Only when u are in bed at night.
Since u dont need the better cameras, off you go with op8
Thanks, just bought off shopee with the discount vouchers
kryptonit3
actually 8 cam is pretty good, other than the 2mp macro lens. do consider 855+ and 865 post image processing, there are difference too on their colour tone. been doing some comparison with 11 pro. it is surprisingly decent and not as bad as previous 7 and 7 pro standard.
Posted from PCWX using IN2013
leowweiqi
Not saying the 8 camera is not good but paying 250 more just for the faster chip but can't use 5g and 2 cameras like not worth it
KeYoKe
But i will spend additional just for the latest phone. Partly because im a tech geek. Just my 2 cents.
Those dont really chase newest tech and dont mind older phones can get the 7t too la. Its still a good phone nevertheless other the the ugly camera module at the back
leowweiqi
6mths difference only. Not that old ba
oakleyducati
Hey guys. Maybe a bit of a dumb question. For those who bought from Lazada direct. The warranty is from your email invoice date?
