OnePlus 8/8 Pro!
Anything_Whatever
Oneplus Z or maybe renamed Oneplus 8 Lite with SD765G is .... Akan datang status... going to launch in India soon...
FF to 1.54...
xavierica
New update OOS 10.5.10 is out! :s12::s12:
Changelog
System
Optimized the touch and interaction experience
Optimized the expanded screenshot user experience for some scenes
Optimized the power consumption performance of the system, battery life extended to be longer than ever
Optimized the wireless charging stability, providing better user experience
Optimized the pocket mode to reduce mistouches
Optimized the unlocking animation, making the unlock transition smoother
Updated Android Security Patch to 2020.05
Updated GMS package to 2020.03
Message
Added the “Delete” button in the notification bar of incoming messages
Added keyword whitelist option in SMS blocking settings, the messages with the specified keywords will not be blocked
Camera
Newly added H.265 HEVC codec to reduce video storage size seamlessly, capture and shoot more without compromising on quality
Added auto ultra-wide-angle lens feature when shooting at close range to improve the picture quality of edges
Optimized the click animation for camera shutter, boosting the smoothness of photo-taking experience
Improved the shooting experience with camera and improved stability
Network
Network improvements for Europe Operators implemented (EU only)
Improved the stability of communication
Improved the performance and stability of Wi-Fi transfers
Optimized network latency for online games and improved the smoothness
garychengjw
Same changelog for OP8 but it's OOS 10.5.9 :s13:
Changelog
System
Message
Camera
Network
Aikon
Yes it's still there. OnePlus announced that the previous global update to disable it on the global version was a mistake.
I just doubled checked it by looking at my Apple TV - yup can still see all those sexy chips. :s8: no change.
Need to re-do VOLTE and wi-fi calling though as that is gone. Just updated that too.
dappercivility
Now that you have tested I will go update it too. Have been holding off doing updates :s13:
:s8:
no change.
dappercivility
Just now after update no more photochromic filter. Now when I went to see again its there. Confirmed just now don't have.....
How did you lose it bro?
I used the photo chrome filter... Then looked at a kuro Pixel TV android box and 2nd Gen apple tv I can see thru it. But not other devices though, which I also couldn't before the update anyway.
Kitaro9202
New update
Posted from PCWX using IN2023
nexusscion
Thanks for sharing it still works on the color filter. I didn't bother to re enable the volte as it cause issue with making conference/merge calls after. This is something that needs to configure on the Telco side as well after doing some research from op forum. I don't want enable now at the expense of losing conference calls feature for my daily work :(
