Kitaro9202
- Aug 24, 2007
I have use a type c connector to 3.5mm jack but got no sound came out
Phone showing earpiece connected
For people whom use hotspot alot and having phone calls at the same time will make a big difference bro
Icic bro I seldom use Hotspot ahah
Did you up the volume?
Thanks bro. I go with s20u then.
The latest update can feel the battery life difference finally.
Just received my 8pro, updated to latest firmware 10.5.6 but the security patch is only 1st Mar'20. Is this correct?
My op6 is on May'20 security patch already.
You misread it. Security patch is also May 2020.
The GMS package is March 2020. 10.5.10.
Thanks bro.
I use oneplus updater, there's another update to 10.5.10 now on May security patch.
