Kitaro9202
- Aug 24, 2007
Update latest firmware my volte is missing need to reactivate again?
Yes need to activate again. Start from the step activating full port switch
ok thank kinda of lazy to do liao![]()
Same. Almost every update got to redo. Zzz.
I'm confused which one to buy. Usa set S20u vs Oneplus 8 pro. Only concern about s20u is the camera autofocus. Any recommendations? Thank you
I have both, if you don't care about camera(like me), you can go for Samsung SD (best all rounded), snappy and near stock android experience you can go for 8pro
Both insanely smooth and fast, one UI come with better gesture experience with one hand operation+ apps and better customization, battery slightly better than 8pro.
For screen display I found out S20u FHD+ 120hz is as good as 8pro QHD+ 120hz, instead I found the display quality on S20u is better than 8pro, and S20u nearly a flat screen, 8pro is just too curve for me.
8pro gave better gripping feeling as the body is narrow compare to S20u, but I prefer bigger screen for my device so this is another reason I choose S20u.
Thanks bro. I go with s20u then.
Another thing is that I found 8pro installed apps is way faster than s20u, both using same SD 865 and LPDDR5, not sure why the result different so much, is like I need to wait another 20sec for S20u to finish the installation.
Fingerprint sensor on 8pro is also faster and easier to unlock, although Samsung claimed ultrasonic, but I still prefer 8pro fingerprint unlock.
8pro face unlock do not have "Require Eye Open" option, where samsung have it
Btw only go for Snapdragon version, do not go for E version for s20u.
Thank you so much for your time. My 8pro order can't be cancelled already as the vendor starting to ship. I have no more choice than to love my new 8pro hahaha cheers! Stay safe everyone
Wont go wrong with either. Dont worry. Both are capable devices and each has their own pros and cons depending on what are your needs
For me volte got does not make any diff
Only see the icon come out like song
Yup, maybe 8pro is more suitable for you, everyone needs and want is different.
Saw news reported on google just now, currently 8pro awarded the best phone in the world haha
