OnePlus 8/8 Pro!
P R N D
Since discount much, it is worth to buy 6 month warranty for $20
Sent from Mercedes-Benz E250 using GAGT
twisti
Using export OP8 china version with global rom which i bought yesterday. Took 2 bus rides and an MRT ride today using Google Pay. No problems. Detection is instant.
hanadulset
No issues using G Pay on public transport. Mine is CN OP8 running on "AA" ROM. Using G Pay that came pre-installed
xavierica
What is your model number?
Mine is IN2023 (Local set) also running on AA ROM but facing issue with public transport
Sent from OnePlus 8 Pro using GAGT
igarashi
Same IN2023 model (Local set) running on AA ROM not working too...
P R N D
Wow that's good.
But why some users here can't use it?
Strange.... strange....
kryptonit3
those have knowledge on flashing roms their previous oneplus devices, can try doing that on their local set to see if it resolves this issue. so far only local devices 8/8 pro facing such problem
xavierica
U mean reflashing the ROM? 10.5.10AA OS? Or to a custom ROM from xda
kryptonit3
ya probably do a full wipe, rom less and reflashing it or normal wipe and reflash global AA OS on top. i can’t see why export no issues and only local sets having this problem.
nexusscion
Mostly it is a software issue that they need to fix it. I actually use my Samsung watch if I really need to take bus or mrt.
xavierica
I had no issues w gpay on bus when I was on 10.5.6AA. I could try a flashing custom rom to see if it can work
kkyeap
anyone here can teach me how to configure OP8 to use TPG network? i can't detect TPG for some reason. my Old OP3T is fine with same TPG sim card.
Wl319l
Hi bros and sis, noticed mobyshop going for 1149 for 8pro 8gb variant. Considered ok the price? According to them is hk shipped over and global rom. 6 months warranty
Wl319l
Most places are selling 8gb and 12gb $100 difference. $1149 sounds decent. You can probably find slightly cheaper if you check Carousell. But tbh just deal with the shop/platform you most comfortable with.
Yeah, probably old fashioned but I prefer seeing a physical store tho. Haha. Seems like moby has been around for a while, should be safe. Thanks man/sis!
lawreo2002
APN: TPG
I tried. But still cannot .... Not sure what I did wrong? I am on local set 8 pro.
Sent from OnePlus IN2023 using GAGT
