OnePlus 8/8 Pro!
Venkatdommata
I am talking to them...
They flash the stock factory firmware provided by oneplus, it was working
They tested using ezlink app anyways. They say before downgrade, they tested scanning a ez link card via ezlink app, doesnt work. After downgrade it works.
Anyways, the stock factory firmware is not available to the public. If these steps work, have to bring to service center for them to flash for u.
But they havent try to upgrade back :s22: they will test and feedback to me. I will update here when got a reply from them
Great, thanks! Will wait for your reply before making my purchase. Can't believe best android phone of 2020 is struggling with this tiny issue :-D
igarashi
Must ask them test actual bus and Mrt. Tap in and out. Not test with ezlink card. And test upgrade also does it still work.
doreen27
Different topic:
To those asking about which TG to use. I'm currently using Zeelot. Very nice. Was planning to use this phone naked. But decided to do that at a later timing, hoping to use this phone for more than 6 months :s22: - so got a case for it too.
Paired it with a Spigen Liquid Armor. This case is just right with this TG combination. The case "wraps" over the TG - since this case is not really that tight on your phone. The only clearance you wounld need to look out is the top and bottom - luckily, mine was just installed right.
how much is the Zeelot and where you got it from?
WhiteAnt
How come only local set got this prob?
Global set no such issue right?
V strange :s22:
WhiteAnt
I suspect is some firmware bug ba.. might need to use a specific to do a full flash of firmware
Fr this, I think our local sets are not global version?
They tweaked it a little diff somehow 🤔
Confirmed is bug :o
IntimacyR
I am having problem adding UOB credit card into Google pay. U guys have any issue? I using 8 pro 12/256, export set.
Sent from OnePlus IN2020 using GAGT
kryptonit3
gpay sg or default gpay if i’m not wrong gpay sg only supports ocbc for now ?
IntimacyR
I tried both but I cannot add my uob credit card. Previously my card was added in Huawei p30 pro with no issue.
hellojeffo
Or you added the card to other mobile wallets/phones too many times.. there's a limit, and may need to request bank to reset
Sent from Samsung SM-N975F using GAGT
IntimacyR
Good point there.. maybe I should try to ask the bank.. thanks..
