OnePlus 8/8 Pro!
igarashi
Just test after yesterday Local upgrade > Downgrade 10.5.12 aa > 10.5.13 aa OTA Full update. GPay not working on bus.
Guess will also stick with 10.5.12AA for the time being.
firegazer
Why not downgrade straight to 10.5.13 AA? I think it may work thou I didn't try it.
Sent from OnePlus IN2023 using GAGT
igarashi
i can't find the downgrade version for 10.5.13 AA.
yesterday i tried with the Full update 10.5.13 AA but it won't allow to install.
Kitaro9202
Unplug my phone 90 min hour ago and my battery from 80% drop till 59%abit ridiculous
Posted from PCWX using IN2023
athenodorus
Same as me lor. Better to not do any updates already unless some other ppl can confirm it works for oxygen 11..
Keep testing it until quite dulan already haha.
igarashi
ya. But Armuro he update .13 can work.
Need check how he do it.
karloil
Everyone, I'm very new to OnePus. Can anyone point me to an article/resource so that I can read what you guys are talking about?
tc4237
Just another phone. Most people here having the local set (AA version) are experiencing nfc problems at bus/mrt gantries. Export sets seem to work fine.
karloil
Thanks for the reply. Yes, I was also reading the same.
I don't really use GPay, but I do use EZ-Link. But I was able to read several EZ-Link cards with no issues. But gantries will of course be totally different. Have yet to try
Where can I get a primer on how to flash the firmware? Not sure if I previously got the correct XDA thread. I'v been reading almost half this thread and so far, trying my best to catch up.
karloil
Different topic:
To those asking about which TG to use. I'm currently using Zeelot. Very nice. Was planning to use this phone naked. But decided to do that at a later timing, hoping to use this phone for more than 6 months :s22: - so got a case for it too.
Paired it with a Spigen Liquid Armor. This case is just right with this TG combination. The case "wraps" over the TG - since this case is not really that tight on your phone. The only clearance you wounld need to look out is the top and bottom - luckily, mine was just installed right.
athenodorus
Why do u want to flash since u don’t use gpay and doesn’t have any issues? You should try to use gpay and see if your set has issue with it then decide. Otherwise if no issue should just use as per normal ma.
karloil
No intention of flashing it now - but I want to learn more regarding firmware flashing for OnePlus.
Amuroraysg
10.5.12 aa > 10.5.13 aa is OTA Full update right ?
i get error unable to update 10.5.13AA ota and ask to download full
Incremental as the size of my update is only few hundred MB... I am doing it over the air not using local file..
I notice my problem started when I turn on face unlock and won't fix even I turn it off.. so now I am using fully finger print only and so far no problem with any sort of payment since
igarashi
ohhh... same when do OTA mine is 2000mb version. OTA Incremental version it fail to update.
Venkatdommata
Oneplus official store dropped me a message saying that NFC issue is fixed and it's software issue. So I will make my purchase of oneplus 8 pro this weekend mostly. Hopefully it's worth the wait.
Vulpix
Moderator
Moderator
Did they really fix the problem already?
garychengjw
very doubtful statement from them. only those with current set able to test it out.
KeYoKe
I am talking to them...
They flash the stock factory firmware provided by oneplus, it was working
They tested using ezlink app anyways. They say before downgrade, they tested scanning a ez link card via ezlink app, doesnt work. After downgrade it works.
Anyways, the stock factory firmware is not available to the public. If these steps work, have to bring to service center for them to flash for u.
But they havent try to upgrade back :s22: they will test and feedback to me. I will update here when got a reply from them
