OnePlus 8/8 Pro!
Amuroraysg
Never ask. Wait they test successful already then ask. By then just google and we can DIY
Finally some acknowledgement hope we got permanent fix.. even though mine now working fine but still worry next update may broke it..
zc_squash
gpay sg or default gpay if i’m not wrong gpay sg only supports ocbc for now ?
I tried both but I cannot add my uob credit card. Previously my card was added in Huawei p30 pro with no issue.
Sent from OnePlus IN2020 using GAGT
How to set GPay SG as default? On my 'Bluetooth & device connection > Tap & pay' settings, I can only see GPay but not GPay SG.
kryptonit3
default as in the one already installed app, you can either disable that and install gpay sg. no way to switch between gpay sg and default gpay under tap to pay.
Amuroraysg
Lol today out of sudden not working again.. back to old shiat.. read but keep spinning nonstop..
Did something mention bringing to Mr mobile and they will flash it to working firmware?
KeYoKe
Bring it to them for flashing. But they have yet to test if update will brick it again
kiryu86
i just change to 8 pro export set like 2 weeks now
loving it so far, coming from s10+
phone is smooth like butter
only thing is that lack of some useful feature like motion capture, gif capture , quick swap on pic for location , gallery unable to rotate, no sd card, 256gb may not be enough
apart from that, battery life can last me whole day of usage, screen is more vivid than samsuck , speker is loud n clear
gpay works without problem for me in latest update, whether is merchat buying or take bus n mrt.
but dun like it cuz need to unlock phone to use gpay, samsung pay not need,
athenodorus
Just need to wake screen for gpay.
Jordan
Then anyone who pick up your phone can just use gpay. The need to unlock is there for a reason
Posted from PCWX using ONEPLUS A6000
idiot444
is it worth to spend $100+ more for OnePlus 8, considering I'm planning to get the OnePlus 7T?
Usage is merely surfing, camera, social media and youtube. No gaming for sure.
kryptonit3
consider nord then.. cheaper than 8 since you don’t game.
xiaosen
my heart is with 7T more than 8, except the 5G capability which will come in handy when our network becomes available soon. Also the newer 865 chip which can last me another 2 years
855+ will last u another 2 years too. Either 7t or 8 pro. If budget go with 7t
twisti
No need to unlock when using G Pay on public transport and making retail purchase below $200. Only need to wake the phone
WhiteAnt
Op7t good enough even for gamers, I'm using op7 still v fast and smooth for daily operations
But you mentioned camera as a requirement? Like that you need to get Op8pro bc the only flaw of op7/8 is the camera with average photo so don't have too high expectation :o
I wouldn't recommend nord bc the camera will be a tier lower than op7/8. Another consideration is not sure if sd765G will lag after a year coz I dislike laggy phones :s22:
Vulpix
Moderator
Moderator
Whether the 765g will lag after a year is mostly due to the software, not the hardware.
Gixxerfied
I am having problem adding UOB credit card into Google pay. U guys have any issue? I using 8 pro 12/256, export set.
If it matters, I have no issue adding uob cc into gpay sg app or default Google pay on my op6t export set.
