OnePlus 8/8 Pro!
xavierica
Will they top up the pop up boxes? Quite interested in the 8 pro glacier green tho
Sent from OnePlus 5 using GAGT
xavierica
Pop up box no green. If wan get green is normal packaging with free sandatone case
Yea. Looking at the normal box for glacier green. I don't need the wireless earpiece but the karbon case do look nice. The sandstone one is not bad too
wunderluster
Actually now I am also looking at Mi 10 pro, it is very similar to 8 pro but right now q10 got $100 voucher so that makes it almost $300 cheaper.
Just want to ask all of you here what makes you choose oneplus 8 pro over mi 10 pro?
Tormented Soul
Now all the phones damn bloody similar in specs and performance outside of Samsung.
Mi10 Pro
Oppo Findx2 Pro
Motorola Edge Pro
etc
Wzierbovsky
For me, between the Mi 10 Pro vs Oneplus 8 pro; higher resolution screen (FHD is fine but my eyes do notice the difference to QHD+), the higher refresh rate (60 to 90Hz is more noticeable, but none of the reviewers have said they don't notice the 90 to 120Hz jump), dual-SIM on the OnePlus (not really keen on the China version of the Mi 10 Pro).
The jury on battery life seems to still be out there. A few tests have been conducted I think and early impression is that they roughly have the same battery life at their max refresh rates.
The price difference is indeed significant, but in my case, I'm willing to fork it out. YMMV.
Hafiz3113
There's a $100 coupon for Qoo10 currently and thought it'd be worth it to get one from there considering that the pop up is sold out. Anyone knows if 131plus from Qoo10 is reliable?
kuma-mon
For me the answer is simple. Mi 10 pro using miui, the experience u getting is not as nice as oxygen os. Also oneplus got good update track record. When google release android 11, can be sure that op8 will be the one of the earliest device to get the update.
Also oneplus is open to rooting and installing custom roms. So you can unlock bootloader and do all these. Mi 10 pro need wait quite long then can. Then again this is personal preference.
Anything_Whatever
I gave up looking at mi10pro after finding out the global set is only single SIM. That’s the deal breaker.
I know there are dual SIM models but not interested in export set China rom.
superio
Hi, how is oneplus 8 Pro compared to oppo find X2 pro?
Where can get a good price for the oneplus 8 Pro? Currently using oneplus 7t Pro mclaren. Dunno if it's worth the upgrade.
