Openwrt Router Firmware
H3C Magic NX30 Pro may not be as good as Xiaomi AX3000T, but the good thing is that it is supported by the official OpenWRT release now. To me is probably more suitable as an AP than being a router since it has only 256MB RAM.
https://www.zhihu.com/tardis/zm/art/664684454?source_id=1003
OpenWRT for H3C Magic NX30 Pro -- with official OpenWRT
https://ericclose.github.io/install-openwrt-on-h3c_magic-nx30-pro.html
OpenWRT for H3C Magic NX30 Pro -- with unofficial OpenWRT fork ImmortalWrt (more popular for mainland Chinese users)
https://blog.qust.me/nx30pro
https://github.com/immortalwrt/immortalwrt
I have just got an H3C Magic NX3 Pro from Taobao for RMB 179 + GST + Sea Shipment.
Note: I do not recommend this model. This is just an experiment for me.
Note: I do not recommend buying routers with 256MB RAM in general even though I tend to think they may be okay to be used as an AP. Lower cost models may not have good workmanship (eg: H3C Magic NX30 Pro).
Stock FW is based on a version of OpenWRT which seems to be not configured properly for OpenWRT.
I just tried the Chinese Immortal OpenWRT and it does not seem to be as good as Stock OpenWRT -- got too many packages installed which I do not use.
OpenWRT info
状态​
系统
主机名ImmortalWrt
主机型号H3C NX30PRO
架构ARMv8 Processor rev 4 (v8l) x 2 (1295MHz)
温度CPU:72.7°C, 2.4G:57°C, 5G:57°C
目标平台mediatek/mt7981
固件版本ImmortalWrt 18.06-5.4-SNAPSHOT r11814-ef0c86bdb0 / LuCI branch (git-22.323.17670-f9380b5)
内核版本5.4.224
本地时间Tue May 7 22:17:49 2024
运行时间2h 33m 2s
平均负载0.00, 0.00, 0.00
CPU 使用率(%)5%
Wired SpeedTest
Bash:
PS C:\work\speedtest\ookla-speedtest-1.2.0-win64> .\speedtest.exe -s 13623
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     2.72 ms   (jitter: 0.19ms, low: 2.48ms, high: 2.87ms)
    Download:   937.46 Mbps (data used: 467.0 MB)
                  3.58 ms   (jitter: 0.66ms, low: 2.11ms, high: 4.54ms)
      Upload:   944.44 Mbps (data used: 1.1 GB)
                  4.72 ms   (jitter: 0.71ms, low: 2.24ms, high: 9.75ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/ad0304d8-a0d7-4acc-9fc8-53265a6ebac7
Wireless speed 3m away, Acer Windows 11 laptop (2021 model), Intel AX201 wireless adapter
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.09 ms   (jitter: 1.13ms, low: 2.54ms, high: 4.60ms)
    Download:   695.09 Mbps (data used: 563.5 MB)
                  8.28 ms   (jitter: 7.35ms, low: 3.17ms, high: 230.47ms)
      Upload:   716.03 Mbps (data used: 1.3 GB)
                 22.07 ms   (jitter: 9.50ms, low: 5.55ms, high: 234.15ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/fd928653-b539-4725-8420-f47b8e0d6e49
If I run OOkla SpeedTest CLI client from within the router, upload speed is quite slow. Not so sure why.
Bash:
root@ImmortalWrt:~/speedtest# ./speedtest
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     1.46 ms   (jitter: 0.04ms, low: 1.43ms, high: 1.52ms)
    Download:   917.50 Mbps (data used: 413.9 MB)
                  3.44 ms   (jitter: 0.69ms, low: 1.67ms, high: 5.72ms)
      Upload:    31.02 Mbps (data used: 14.0 MB)
                  5.30 ms   (jitter: 0.47ms, low: 3.87ms, high: 8.40ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/965de483-8246-41a1-aa19-50a88e6404a1
ImmortalWrt mt798x project -- now I see why they want to customize OpenWRT
https://cmi.hanwckf.top/p/immortalwrt-mt798x/
https://github.com/hanwckf/immortalwrt-mt798x
Note: I do not recommend buying routers with 256MB RAM in general even though I tend to think they may be okay to be used as an AP. Lower cost models may not have good workmanship (eg: H3C Magic NX30 Pro). And it is better to avoid those very low cost models with no brand.
If you want to play safe, the GL.iNet models are safer bet but of course they cost higher. Xiaomi AX3000T (more useful as an AP) and Redmi AX6000 should be safer bet in terms of HW quality. But then the flashing of OpenWRT can be a bit tricky for Xiaomi models.
路由器型号CPURAMFLASH有线规格无线规格USB
360 T7/T7U/T7MMT7981256M128M SPI-NAND4*1GAX3000×
ZR3020MT7981256M128M SPI-NAND4*1GAX3000×
Cetron CT3003MT7981256M128M SPI-NAND4*1GAX3000×
JCG Q30 PROMT7981256M128M SPI-NAND4*1GAX3000×
GL.iNet GL-MT3000MT7981512M256M SPI-NAND1G(WAN)+2.5G(LAN)AX3000√
GL.iNet GL-MT2500MT79811G8G EMMC1G(WAN)+2.5G(LAN)×√
康佳 KOMI-A31MT7981256M128M SPI-NAND4*1GAX3000×
小米 WR30U/T/MMT7981256M128M SPI-NAND4*1GAX3000×
乐橙 LC-HX3001MT7981256M128M SPI-NAND4*1GAX3000×
H3C NX30 ProMT7981256M128M SPI-NAND4*1GAX3000×
CMCC RAX3000MMT7981512M128M SPI-NAND4*1GAX3000√
CMCC RAX3000M 算力版MT7981512M64G EMMC4*1GAX3000√
CMCC A10MT7981256M128M SPI-NAND4*1GAX3000×
安博通 ABT ASR3000MT7981256M128M SPI-NAND4*1GAX3000×
创联腾 CLT-R30B1MT7981256M128M SPI-NAND4*1GAX3000×
小米 AX3000TMT7981256M128M SPI-NAND4*1GAX3000×
TP-LINK XDR6086MT7986512M128M SPI-NAND1G+2*2.5GAX6000√
TP-LINK XDR6088MT7986512M128M SPI-NAND4*1G+2*2.5GAX6000√
Banana Pi BPI-R3 MiniMT79862G128M SPI-NAND + 8G EMMC2*2.5GAX4200√
磊科 N60MT7986256M128M SPI-NAND4*1G+2.5GAX6000×
GL.iNet GL-MT6000MT79861G8G EMMC4*1G+2*2.5GAX6000√
红米 AX6000MT7986512M128M SPI-NAND4*1GAX6000×
锐捷 RG-X60 PROMT7986512M128M SPI-NAND4*1G+2.5GAX6000×
Not related to OpenWRT but rather on the comparison of 4 low cost WiFi 6 routers based on Filogic 820, including Xiaomi WR30U and H3C NX30 Pro which support OpenWRT.
For those who want a bit better one, Redmi AX6000 is using Filogic 830 and the price is pretty okay.
https://openwrt.org/toh/xiaomi/redmi_ax6000
But if you want a working OpenWRT system out of box (customized by GL.iNet), then you can get the GL.iNet GL-MT3000 (Filogic 820, single 2.5G port) and GL.iNet GL-MT6000 (Filogic 830, dual 2.5G ports). The price is still quite reasonable.
A newer version.
主机名OpenWrt
型号H3C NX30PRO
温度CPU: 72.0°C, WiFi: 55°C 55°C
目标平台mediatek/mt7981
固件版本ImmortalWrt 21.02-SNAPSHOT r20540-f137a9ece7 / LuCI openwrt-21.02 branch git-23.098.38725-847bd6b
内核版本5.4.255
本地时间2024-05-09 08:44:58
运行时间0h 41m 34s
CPU 使用率(%)5%
OOkla SpeedTest CLI client from within the router, upload speed is now normal.
Bash:
root@OpenWrt:~# ./speedtest
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     1.76 ms   (jitter: 0.14ms, low: 1.63ms, high: 1.90ms)
    Download:   922.78 Mbps (data used: 441.2 MB)
                  2.97 ms   (jitter: 0.64ms, low: 1.71ms, high: 5.02ms)
      Upload:   937.40 Mbps (data used: 1.1 GB)
                  3.47 ms   (jitter: 0.48ms, low: 2.38ms, high: 9.94ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/7b10367e-db13-4db6-be92-1786ac8a50a6
Wireless speed test result: 3m away, Acer Windows 11 laptop (2021 model), Intel AX201 wireless adapter
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     2.49 ms   (jitter: 0.18ms, low: 2.32ms, high: 2.68ms)
    Download:   745.30 Mbps (data used: 384.1 MB)
                  6.89 ms   (jitter: 2.85ms, low: 3.04ms, high: 13.85ms)
      Upload:   895.18 Mbps (data used: 1.2 GB)
                 17.93 ms   (jitter: 4.23ms, low: 2.86ms, high: 35.03ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/44b4de2a-e305-4296-a726-9cf939eb7857
The above is using MediaTek wireless driver.
The following is using another firmware with OpenWRT open source wireless driver with MTK wireless acceleration turned ON. The speed seems to be lower. And it keeps losing the connection. Looks like this snapshot is too new to be stable.
SW/HW offloading are both ON as well.
主机名OpenWrt
主机型号H3C Magic NX30 Pro
架构ARMv8 Processor x 2 (66.8°C)
固件版本OpenWrt R24.3.30 / LuCI Master (git-24.071.74519-c79d23b)
内核版本5.15.152
本地时间Thu May 9 11:16:42 2024
运行时间1h 22m 55s
CPU 使用率(%)5%
OOkla SpeedTest CLI client from within the router, speed is now normal.
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     1.33 ms   (jitter: 0.14ms, low: 1.25ms, high: 1.51ms)
    Download:   923.89 Mbps (data used: 428.7 MB)
                  3.00 ms   (jitter: 0.58ms, low: 1.47ms, high: 3.88ms)
      Upload:   936.12 Mbps (data used: 1.1 GB)
                  3.46 ms   (jitter: 0.58ms, low: 2.06ms, high: 15.24ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/8cb40c35-0058-4d2a-a03c-0308267dfca2
Wireless speed test result: 3m away, Acer Windows 11 laptop (2021 model), Intel AX201 wireless adapter.
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     2.90 ms   (jitter: 0.67ms, low: 2.60ms, high: 3.88ms)
    Download:   626.79 Mbps (data used: 570.4 MB)
                  8.94 ms   (jitter: 2.12ms, low: 5.27ms, high: 15.96ms)
      Upload:   441.08 Mbps (data used: 399.0 MB)
                 12.34 ms   (jitter: 4.36ms, low: 4.92ms, high: 35.47ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/ab877b56-9050-4fab-8950-2bf2aab82ebf
Interestingly "iw list" command does not work with the following OpenWRT version.
Bash:
root@OpenWrt:~# ubus call system board | grep 'model\|description'
        "model": "H3C NX30PRO",
                "description": "ImmortalWrt 21.02-SNAPSHOT r20540-f137a9ece7"
root@OpenWrt:~# iwinfo | grep 'Hardware:\|PHY name'
          Hardware: 14C3:7981 14C3:7981 [MediaTek MT7981]
          Supports VAPs: yes  PHY name: apcli0
          Supports VAPs: yes  PHY name: apclix0
          Supports VAPs: yes  PHY name: ra0
          Supports VAPs: yes  PHY name: rax0
root@OpenWrt:~#  iw list | grep 'Wiphy\|TXQS\|AIRTIME_FAIRNESS\|AQL'
nl80211 not found.
nl80211 not found.
root@OpenWrt:~# iwlist ra0 channel
ra0       13 channels in total; available frequencies :
          Channel 01 : 2.412 GHz
          Channel 02 : 2.417 GHz
          Channel 03 : 2.422 GHz
          Channel 04 : 2.427 GHz
          Channel 05 : 2.432 GHz
          Channel 06 : 2.437 GHz
          Channel 07 : 2.442 GHz
          Channel 08 : 2.447 GHz
          Channel 09 : 2.452 GHz
          Channel 10 : 2.457 GHz
          Channel 11 : 2.462 GHz
          Channel 12 : 2.467 GHz
          Channel 13 : 2.472 GHz
          Current Channel:8
root@OpenWrt:~# iwlist rax0 channel
rax0      13 channels in total; available frequencies :
          Channel 36 : 5.18 GHz
          Channel 40 : 5.2 GHz
          Channel 44 : 5.22 GHz
          Channel 48 : 5.24 GHz
          Channel 52 : 5.26 GHz
          Channel 56 : 5.28 GHz
          Channel 60 : 5.3 GHz
          Channel 64 : 5.32 GHz
          Channel 149 : 5.745 GHz
          Channel 153 : 5.765 GHz
          Channel 157 : 5.785 GHz
          Channel 161 : 5.805 GHz
          Channel 165 : 5.825 GHz
          Current Channel:64
root@OpenWrt:~#
This one works for "iw list" command. The system is quite close to stock OpenWRT system which I like. However, the wireless speed of the open source driver is quite a bit lower than the vendor driver.
主机名称OpenWrt
型号H3C Magic NX30 Pro (NMBM layout)
温度CPU: 74.2°C, WiFi: 59.0°C 59.0°C
目标平台mediatek/filogic
固件版本ImmortalWrt 23.05.2 r27625-416c8c5c91 / LuCI openwrt-23.05 branch git-24.079.19999-26165fd
内核版本5.15.150
本地时间2024-05-09 18:21:58
运行时间0h 20m 31s
平均负载0.15, 0.20, 0.14
CPU 使用率(%)0%
Code:
PS C:\work\speedtest> ssh root@192.168.5.1
root@192.168.5.1's password:
.___                               __         .__
|   | _____   _____   ____________/  |______  |  |
|   |/     \ /     \ /  _ \_  __ \   __\__  \ |  |
|   |  Y Y  \  Y Y  (  <_> )  | \/|  |  / __ \|  |__
|___|__|_|  /__|_|  /\____/|__|   |__| (____  /____/
          \/      \/  BE FREE AND UNAFRAID  \/
 ImmortalWrt 23.05.2, r27625-416c8c5c91
        "model": "H3C Magic NX30 Pro (NMBM layout)",
                "description": "ImmortalWrt 23.05.2 r27625-416c8c5c91"
          Hardware: embedded [MediaTek MT7981]
          Supports VAPs: yes  PHY name: phy0
          Supports VAPs: yes  PHY name: phy1
Wiphy phy1
                * [ TXQS ]: FQ-CoDel-enabled intermediate TXQs
                * [ AIRTIME_FAIRNESS ]: airtime fairness scheduling
                * [ AQL ]: Airtime Queue Limits (AQL)
Wiphy phy0
OOkla SpeedTest CLI client from within the router, speed is normal.
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     1.63 ms   (jitter: 0.21ms, low: 1.31ms, high: 1.67ms)
    Download:   927.85 Mbps (data used: 419.1 MB)
                  2.98 ms   (jitter: 0.55ms, low: 1.28ms, high: 3.75ms)
      Upload:   936.93 Mbps (data used: 1.1 GB)
                  3.86 ms   (jitter: 3.10ms, low: 1.77ms, high: 226.22ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/a89299b5-45c2-4ab4-8bf9-ddbb8b1f5a84
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     2.70 ms   (jitter: 0.74ms, low: 2.40ms, high: 3.91ms)
    Download:   466.04 Mbps (data used: 757.9 MB)
                 11.43 ms   (jitter: 9.69ms, low: 2.83ms, high: 172.78ms)
      Upload:   438.62 Mbps (data used: 616.6 MB)
                 38.14 ms   (jitter: 16.34ms, low: 7.59ms, high: 320.29ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/d69cf12b-3cbd-407b-b773-f690c312d785
Crowd-sourcing the Wi-Fi Chip info?
Which I already done on ax3600 stock 23.05.3 :giggle:
From OpenWRT Forum
WLAN Hardware
Features
Example routerFirmwareContributor
All MT76xxTXQS/ATF/AQLSee ToH 523.05.3[3]
All MT79xxTXQS/ATF/AQLSee ToH 522.03.5[3]
Generic MAC80211TXQS/ATF [only]Extreme Networks WS-AP3825i23.05.3@account4538
IPQ4019TXQS/ATF/AQLLinksys MR8300 (Dallas)22.03.6@account4538
IPQ8074TXQS [only] 5Xiaomi Mi AIoT AX360023.05.3@dudez7
QCA9880TXQS/ATF/AQLExtreme Networks WS-AP3825i23.05.3@account4538
QCA9886TXQS/ATF/AQLLinksys MR8300 (Dallas)22.03.6@account4538
QCA9889TXQS/ATF/AQLXiaomi Mi AIoT AX360023.05.3@dudez7
QCA9984TXQS/ATF/AQLNetgear Nighthawk
X4S R7800
SNAPSHOT r25830-
8d934c1196
@tapper
QCN5024TXQS [only] 5Xiaomi Mi AIoT AX360023.05.3@dudez7
QCN5054TXQS [only] 5Xiaomi Mi AIoT AX360023.05.3@dudez7
Notes:
  1. Chip names are abbreviated to conserve space. Manufacturers: MediaTek start with MT...; Qualcomm Atheros start with QC... or IPQ...
  2. Features are:
    • TXQS: FQ-CoDel-enabled intermediate transmit queues
    • ATF: Air Time Fairness scheduling
    • AQL: Airtime Queue Limits
  3. All MT76xx and MT79xx chips have full support for the OpenWrt Wi-Fi Driver, as cited by @brada4, @greem, and many others:
Code:
Wiphy phy1
Wiphy phy0
I was hoping that wireless bufferbloat test will be good but actually it is quite bad.
OpenWRT virtual router (SQM, CAKE, 900Mbps/700Mbps) [2.5G LAN port] --
H3C Magix NX30 Pro running ImmortalWrt 23.05.2, router mode (Double NAT): no sqm measures
1) With default aql_txq_limit: F and F
https://www.waveform.com/tools/bufferbloat?test-id=bd819ed0-10da-472a-b2bc-2150e00df758
https://www.waveform.com/tools/bufferbloat?test-id=7c9efef4-9ee7-47d5-8349-e17ee7d64367
Bash:
root@OpenWrt:~# cat /sys/kernel/debug/ieee80211/phy0/aql_txq_limit
AC      AQL limit low   AQL limit high
VO      5000            12000
VI      5000            12000
BE      5000            12000
BK      5000            12000
root@OpenWrt:~# cat /sys/kernel/debug/ieee80211/phy1/aql_txq_limit
VO      5000            12000
VI      5000            12000
BE      5000            12000
BK      5000            12000
2) With reduced aql_txq_limit: C and F
https://www.waveform.com/tools/bufferbloat?test-id=e1f5e45f-862b-4b40-b846-43d4d537d7a3
https://www.waveform.com/tools/bufferbloat?test-id=ba9d2c16-20ea-453d-b8c5-c48af3220230
Bash:
VO      1500            1500
VI      1500            1500
BE      1500            1500
BK      1500            1500
VO      1500            1500
VI      1500            1500
BE      1500            1500
BK      1500            1500
Bash:
nl80211 not found.
nl80211 not found.
Interestingly this one has a bit better Waveform.com bufferbloat score.
H3C Magix NX30 Pro running ImmortalWrt 21.02 Vendor Driver, router mode (Double NAT): no sqm measures
快速转发引擎MediaTek HNAT
全锥形 NATBoardcom Fullcone
TCP 拥塞控制算法BBR
Test results: C C B C
https://www.waveform.com/tools/bufferbloat?test-id=7234be96-0dca-417f-ba8c-6640bbfba110
https://www.waveform.com/tools/bufferbloat?test-id=94c3012c-2d77-45be-aa03-8a238658413e
https://www.waveform.com/tools/bufferbloat?test-id=c17cea60-2f5b-455a-94e7-e7d03524e5f8
https://www.waveform.com/tools/bufferbloat?test-id=1b346fd9-5810-4f31-a543-a7a09787a30e
hwzlite
Bash:
VO      5000            12000
VI      5000            12000
BE      5000            12000
BK      5000            12000
VO      5000            12000
VI      5000            12000
BE      5000            12000
BK      5000            12000
Bash:
VO      1500            1500
VI      1500            1500
BE      1500            1500
BK      1500            1500
VO      1500            1500
VI      1500            1500
BE      1500            1500
BK      1500            1500
Hmmm.... what was the client's signal str (dBm) during these tests?
GlassDoor
imho... all these test are quite meaningless
they are all pre build.. and OLD... if not straight out ancient in openwrt speak
if you wanted old openwrt that are 2 years old.. might as well stick to vendor firmware
my suggestion.. stick to the latest snapshots.. clone out the official repo and build your own builds. customize until you song! this is where openwrt's value lies and where the learning can happen
for qualcomm and mtk chipset.. follow their network hardware offload developments as well
for ipq8074 based builds with 6.6.30 kernel with nss offload.. for kicks
1) sqm at 900mbps+ both upload and download
2) 80MHz wifi ax.. 850mbps+ upload, 900mbps+ download.. and this is on really conservative apple hardware
bufferbloat has never been an issue with or without sqm for openwrt... if the firmware developer knows what he/she is doing
there seems to be strong interest and development momentum on filogic 880
so serious considering getting BPI-R4 to play around
GlassDoor
biggest issue with NX30 Pro is 256MB ram.
will seriously limit it's stability and usefulness even as an AP
if looking for something dirt cheap just grab a used AX3600 from carohell... should be less than 50 no?
it will still run circles around NX30Pro
the best bang for buck for a high performance and yet in sync with the latest openwrt development and with full network stack offload is
Dynalink DL-WRX36. It's a IPQ8074 platform with 2.5G port and wifi 6.
Available in amazon us for us$70+ the last i saw.
biggest issue with NX30 Pro is 256MB ram. ATH11 is a memory hog!
I am not so sure if it is true that 256MB is a limit if using as an AP.
I bought the H3C NX30 Pro as an experiment since the OpenWRT experts says that TXQS+ATF+AQL will do wonders with bufferbloat testing. I do not really care about waveform.com bufferbloat testing results myself since Singtel has bad routing to the test server -- the score is not accurate. In fact, I do not care about bufferbloat since I do not see it as an issue for my use cases.
But this is just for comparison purpose -- I am supprised NX30 Pro with TXQS+ATF+AQL features actually gets the worst results from waveform.com bufferbloat test. The tests are near range test and the signal is strong. I get straight As from my Asus RT-AX86U and ZTE BE7200 Pro+.
Personally I do not care about wireless router with OpenWRT. I already set my main OpenWRT setup as Intel N100 Mini PC with virtual OpenWRT router + wireless AP (ZTE BE7200 Pro+ now, Asus RT-AX82U previously). Sometimes I also swap out OpenWRT with pfSense or OPNsense.
BTW, for serious SQM performance above 1Gbps (say 2Gbps or 2.5Gbps), x86_64 mini PC is the way to go. But I do not think SQM is really needed for my use case. So I do not care about SQM in reality.
My other network is with Asus RT-AX86U.
GlassDoor
and they say elephants can fly...
but seriously from a wireless perspective.. AX3600 with the latest openwrt is on par with my AX86u Pro
only advantage of AX86u Pro is that i can manipulate it to use chan 165-177 with tuf ax3000 as a wifi bridge
